Which would you choose?
New build: all other things being equal (groupset, geometry, components, and aesthetics), if you had to choose between hydraulic disk brakes, or a lighter (by 1.5 lbs) bike with caliper brakes, which would be preferable?
Is it raining? What wheels am I running? How are the aesthetics equal (would the caliper bike have decorative rotors and the rotor bike have decorative calipers), and related, what style of frame and headset are we using, and what is the color scheme? What are the particular brakes? At what altitude is the 1.5lb difference measured, and where will I be riding the bike? What am I using the bike for (i.e. racing or solo riding or cooperative pacelining)? What tires are being used? Does the bike have full-length fenders? Is the bike just being used on the road, or is gnarly off-road descending in its future?
I would go disc...I value the wider range of tire sizes that it accommodates purely from a comfort perspective. I recently made this switch and ride 28c Schwalbe Pro Ones as daily drivers (31.7mm at widest section). Thru axle and flat-mount disc make removal and re-installation of the wheels a breeze - something I value given that I often travel with both wheels off.
On aesthetics, it depends on the specific frame...I really like the sparseness of the seat-stays on my Domane wherein there is no cross-brace where a traditional caliper would sit...I think it looks fantastic how the wheel/tire just lives inside the large gap:
For some more traditional (non-endurance frames), I can appreciate the aesthetics of the compactness of a direct-mount caliper brake.
Administrator
Quoted: 11969 Post(s)
Liked 6,646 Times
I don't need disc brakes. Simple.
Bikes: 2015 Jamis Quest Comp
Quoted: 270 Post(s)
I would do it if money were no option...the weight penalty is not big in my mind...my bike weighs 22lbs, and I don't feel like I am hindered much on climbs.
Quoted: 20810 Post(s)
Liked 9,456 Times
Hydraulic disc. More tire clearance, lighter-effort braking, awesome modulation/feel, performance that doesn't diminish in foul weather, and it's easier (for me, at least) to justify nicer wheels because rims are no longer sacrificial.
Quoted: 7652 Post(s)
Liked 3,473 Times
I might be looking for a new touring frameset ... so discs for that.
Otherwise ... rim brakes. I already carry enough weight which doesn't help my performance.
Bikes: 2013 Synapse 4
Quoted: 70 Post(s)
If I could have gotten a disc brake copy of my bike I would have.
Bikes: S-Works Tarmac 2017 - TREK Madone - Cannondale CAPO
Quoted: 206 Post(s)
Rim. TRP or EEbrakes improvement over RED or DA on carbon? Anyone have experience?
Bikes: 99 Klein Quantum, 2012 Cannondale CAAD10 5, Specialized Tarmac Comp, Foundry Thresher, Fuji Sportif
Quoted: 98 Post(s)
Just had to make this decision when purchasing my S-Works. I went with caliper brakes. Lighter weight, more wheel choices, I don't ride it in the rain (well... not by choice) but mostly, where I live it's pretty flat. If I were riding in mountain areas, I would have chosen disk. My gravel bike is disk and I've had other disk bikes. I have nothing against disks, but I also have nothing against calipers.
pan y agua
Quoted: 1447 Post(s)
Liked 727 Times
Unless you're planning on running tires wider than 28mm, caliper setup every day.
Modern road calipers stop just fine, and 1.5lbs is a lot of weight.
If you're going to use the bike on dirt/gravel roads, or are doing loaded touring and want wider than 28mm tires, then discs become a viable option.
You could get lost and die.
You could hit a tree and die.
pan y agua
Liked 727 Times
You can run 28 mm tires with caliper brakes.
GOOD disc brakes because then I can get carbon disc wheels. Not a fan of carbon/rim setups. Entry level disc brakes are terrible, so caliper would be good in that case.
pan y agua
Liked 727 Times
Makes sense to me.
So I can add 1.5 lbs to the bike and increase its aerodynamic drag, so I can then buy expensive carbon disc wheels, so I can decrease the weight of the bike 1/2 a pound, from the 1.5 lbs I added, and decrease the aerodynamic drag with the deep sectioned carbon rims to offset the drag I added with the discs.
Makes sense to me.
Makes sense to me.
pan y agua
Liked 727 Times
5lbs change in air pressure is going to make a bigger difference than rim material.
and in my experience right pads, right rims, caliper brakes work well on CF rims.
Bikes: Basso Luguna, Fuji Nevada
Quoted: 4261 Post(s)
Makes sense to me.
Makes sense to me.
Can everything but weight be equal now? Last I considered a disc road bike price was very different between disc and caliper brakes. I'd be surprised to be able to buy a both an Ultegra caliper and Ultegra disc bikes for the same price. I would have expect that to be upwards of a $500 difference.
Actually, no.
Note I said 28c tires - not 28mm. 28c Continental GP4000IIs measure 30mm...Schwalbe Pro Ones measure 31.7mm.
I originally bought the direct-mount caliper of the Domane SLR. I needed to use the barrel adjusters to get anywhere close to clearing the tire through the caliper for quick wheel removal (note my original comment re: wheel removal). It was on this basis that I switched out to a disc version. I transport my bike regularly with the wheels removed. Discs free me up from all of the hassle of clearance issues.
