Dynamo powered Cree LED's electrical Q's
PanGalacticGargleBlaster
Bikes: Upright and Recumbent....too many to list, mostly Vintage.
Quoted: 20 Post(s)
Liked 8 Times
I'm looking at parts to build myself an LED headlight to be powered by a Sturmey Archer Dynamo hub. The hub is rated at 3watts at 6V. I was thinking that I'd use a single Cree MC-E as the main headlight. It provides 430 Lumens at 350mAh.
I have some knowledge of electrical circuits, but this is my first try with LED's
Please correct me if I'm wrong.
My idea is to simply wire the LED to a 350mAh buckPuck or similar and plug that into my Dynamo hub.
My question is regarding adding more light. When I want to add more LED's (for taillights lets say), Am I better off to wire the taillight up to its own driver and run two connections out of the Dynamo, or is it best to get a driver that has some room to grow and add on to that?
I'm also getting confused trying to calculate the total forward voltage of the system if I were to use 2 or 3 LED's on one Driver. All I can figure is that I'd need a boost driver rather than a buck, but I'm not sure whether the 3watts my hub can put out will be sufficient for that.
any help is much appreciated.
Randomhead
Liked 3,713 Times
You need to reconsider your choice of leds with that dyno. If you use it in parallel, your hub doesn't have the amperage, in serial, you don't get good low speed performance. The buckpack doesn't do what you need either.
I'm using a triple cree xp-e with my Shimano. I threw together a voltage doubler circuit just to get it working, now I need to do a better job.
I have one of the Sturmey Dynos. I'm thinking about just using an XR-E on the front and rear.
There are some good threads on Candlepower and the MTBR light forums.
put our Heads Together
Bikes: a mountain bike with a cargo box on the back and aero bars on the front. an old well-worn dahon folding bike
Scott
Bikes: Too Many
Martin has dynamo LED circuits and information.
https://pilom.com/BicycleElectronics/...lectronics.htm
Randomhead
Liked 3,713 Times
dynos act like current sources, so you can probably get more than 3w out of it.
The Cree MC-E puts out 500 to 700 lumens at 2.5 amps. 350 mAh would drive it on low.
An XR-E R2 might be better for your use.
