Replacement Cotter Pin?
So, I've got hydraulic disc brakes that use a cotter pin to hold the pads in place, problem is that when I last went to clean the pads, my pin snapped. Is it safe to just use some spare wire to fashion a new pin? If not can anyone make some recommendations? Thanks in advance!
Quoted: 136 Post(s)
Liked 57 Times
It's good it snapped while working on it as it was fatigued and could've snapped during a ride with you losing your pads. I've used a cut-off bobby pin or section of a large size paper clip in a pinch. Later, you can get a new cotter pin from a shop (they prob have a bunch for free or buy a pack at you local hardware store.
Goodness, I didn't know those were called cotter pins as well. My first bike had cotter pins in the cranks like these. I was wondering how you'd fit those in brakes!
If what you have is what I'm thinking of, I've always called those split pins, and they're easy to pick up at hardware stores or somewhere like eBay.
Quoted: 696 Post(s)
Liked 910 Times
Replacements should be available from your local hardware store or nearest home center.
Likes For Ghazmh:
Droid on a mission
Quoted: 317 Post(s)
Liked 281 Times
Two different assortments from Harbor Freight if you need variety, lots of size options
Likes For JoeTBM:
Quoted: 6222 Post(s)
Liked 4,830 Times
Sure you can probably use a piece of wire. But something like stainless safety wire might be better. But it also depends on if the cotter pin or clip fastener was the only thing fastening them or was just for additional safety.
Quoted: 514 Post(s)
Liked 452 Times
I wouldn't trust a piece of wire for too long, unless maybe it was cut from a coat hanger. Your local shop should have a box of spares under the service counter.
Let your bike be the tool
Bikes: '66 Raleigh Carlton, '70 Ron Cooper, '95 Bianchi CD'I, Zonal Frame with Xenon gruppo, Carbon Frame with Record Gruppo, Columbia Twosome, Terry Classic, Bianchi SX, Gravity SS/FG
Quoted: 339 Post(s)
Liked 316 Times
Never try to teach a pig to sing...
Likes For cranky old road:
...two peoples separated by a common language. https://en.wikipedia.org/wiki/Cotter_pin
Likes For gearbasher:
Friendship is Magic
Bikes: old ones
Quoted: 26437 Post(s)
Liked 10,397 Times
...I opened this thread, expecting to find some discussion about cottered cranks on bicycles. i discover it is about disc brakes on bicycles. Now I will be depressed for the rest of Sunday.
Liked 4,830 Times
And maybe about which jargon or colloquialisms we should abide by!
Quoted: 569 Post(s)
Liked 594 Times
In industry we have several kinds of cotter pins, split, R-clip, split ring, etc., all called cotter pins because they do the same job as those on old bicycle cottered cranks they prevent axial movement.
Sr Member on Sr bikes
My most recent reuse/repurpose/recycle of an old, unused bicycle part. Made from and old blade spoke to replace a lost pin on my lawn tractor mowing deck. — Dan
