eyelet screw size for racks?
Quoted: 4835 Post(s)
Liked 3,966 Times
Those are standard toe-clip size screws, the most common size and thread on a bike. I want to say M5x 0.8 but I have had them confused with M4s forever so I'll let the next poster call that out. (The info is all over the place. Not hard to find. The most common metric screws at Ace hardware will be those.
Likes For 79pmooney:
Mad bike riding scientist
Quoted: 6238 Post(s)
Liked 4,246 Times
Stuart Black
Stuart Black
Likes For cyccommute:
Cantilever believer
Quoted: 554 Post(s)
Liked 1,908 Times
Likes For RCMoeur:
Liked 3,014 Times
do not use anything but the appropriate sized hardware. This is why standards exists, & should be more invoked into the bicycle industry.
-Oh Hey!
-Oh Hey!
Likes For Troul:
Quoted: 2730 Post(s)
Liked 488 Times
A m5 hole is drilled a bit larger than a 10-32 hole, but the threads per inch are almost identical. A 10-32 bolt should thread into a m5 hole but a m5 bolt shouldn’t fit into a 10-32 tapped hole. Since the M5 hole is bigger, there is less thread engagement (I believe the standard atleast for imperial is 75% thread engagement) so the bolt will feel “sloppier,” the location is less precise and the connection not as robust.
That being said, for most applications 10-32s will work just fine (until they vibrate loose) Some people prefer not to deal with communist metric stuff.
edit: could an advantage of 10-32s be that they are less likely to fully bind/sieze when they rust because there is less thread engagement?
Likes For LarrySellerz:
Quoted: 3560 Post(s)
Liked 2,976 Times
Likes For smd4:
Cantilever believer
Quoted: 554 Post(s)
Liked 1,908 Times
I just posted this elsewhere at https://www.bikeforums.net/22962937-post6.html :
For attaching items to most bicycles, in my experience most fasteners are 5x0.8 or 6x1.0 metric threading. A selection of bolts in lengths from 10 mm to 30 mm should fit most needs, along with nylon-insert nuts. I would not recommend using common USS sizes like 8-32 or 10-24, as they may not fit well and probably will not thread well at all into most eyelets or fittings.
Locally, I buy them in bulk from Copper State Bolt and Nut in 100-packs. 100-packs are big for most casual users, but I end up working on a lot of bikes. One option would be to buy a 5 mm or 6 mm bolt assortment, and then invest in a near-lifetime supply of nuts.
I personally prefer hex head bolts for most uses. It seems many bikes and accessories use button head socket (hex) screws, but many of these require a 3 mm hex wrench, which can easily round out under higher torque.
Nearly all threaded fender/rack eyelets on bicycle frames are M5x0.8. A few are M6x1.0, but they are an exception and probably outnumbered by no-thread eyelets.
Quoted: 1062 Post(s)
Liked 665 Times
#10-32 would be equivalent to 4.8 mm x 0.794
For a low number of engaged threads it would fit and only be a bit sloppy. A drawback is needing yet another size of allen wrench. And it would be an odd size to find in a typical household.
My advice about all threads is make sure they go in easily with your fingers before using any tools. That way, you can stop and investigate if you notice that things aren't going well.
https://www.boltdepot.com/fastener-i...-diameter.aspx
Liked 4,246 Times
Stuart Black
Stuart Black
Liked 4,246 Times
Liquids are even more confusing. Quick, without Googling, how many teaspoons in a quart? How many cups in a gallon? How many gallons in a hogsheads? Or a barrel? Now how many milliliters in a liter? (Hint, it’s in the name)
Stuart Black
Stuart Black
I bought a bag of M5 x 0.8 x 12 and M5 x 0.8 x 14 Stainless Socket Head Cap Screws from https://belmetric.com/
They work for all the eyelets on my bikes.
I've used Bel-Metric for over 30 years (back to when I was working as a mechanic.) They have had everything I've ever needed (metric or automotive-hardware related). They're only 10 miles from me, so I can order and pick up at their warehouse same day. Pretty sure everything on their website is in stock (although my needs have never been that obscure.)
I see that they now have black stainless fasteners- I don't need them, but might be nice on darker bikes.
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12839 Post(s)
Liked 7,763 Times
Quoted: 830 Post(s)
Liked 1,679 Times
Finding metric hardware isn't exactly like searching for the Holy Grail. Much easier than finding some of the "specialty" bolts.
Old fart
Quoted: 3598 Post(s)
Liked 3,423 Times
Twelve pennies to the shilling actually works well, since 12 is divisible by 2,3,4, and 6, while 10 is only divisible by 2 and 5.
Likes For JohnDThompson:
Quoted: 7666 Post(s)
Liked 3,529 Times
The problem wit using a slightly loose bolt for a rear rack is that under heavy load and a lot of vibration, the screw could end up making the hole even bigger.
Likes For Maelochs:
Liked 2,976 Times
Randomhead
Liked 3,714 Times
The inch has been based on the metric system since before I was born, and I'm retirement age.
So the call is coming from inside the house.
Liked 2,976 Times
Bikes: Merida Speeder
Quoted: 233 Post(s)
Liked 165 Times
One world, one system for all? Sure sounds like communism to me. I mean, sure, the US decimalized its currency, but that has been shown to have been a communist plot, to insert a fifth column of decimalization into US society, before the main metric communist invasion.
Liked 2,976 Times
Oh.
Cantilever believer
Quoted: 554 Post(s)
Liked 1,908 Times
I will keep my conscience clean by continuing to purchase my metric fasteners from free market sources.
Likes For RCMoeur:
