Lube chain without getting on my knees
old newbie
Bikes: Specialized Roubaix
Quoted: 541 Post(s)
Liked 359 Times
I don’t have a work stand-yet. Today when I put my bike on the carrier mounted on the spare tire on my jeep I saw the chain looked a little dry.
Instead of taking it back to the garage to lube it I had a bright idea. I moved it to the outer carrier clamps and lubed the chain on the carrier.
There is a lot of things I can’t do on it since it’s a little tall but I can lube my chain without my knees feeling like gravel crunching.
old newbie
Quoted: 541 Post(s)
Liked 359 Times
It made washing it easy too. I rode thru some wet silt that was across the path for about 40’. The stuff was everywhere.
Likes For pepperbelly:
Quoted: 1182 Post(s)
Liked 833 Times
The bike rack is also good for installing my bike's front rack at the start of a tour. My wife's and my bikes were carried on the roof rack, and our daughters' bikes were carried on the hitch rack. I needed to remove my bike's front rack prior to putting my bike in the roof rack.
Likes For Doug64:
Just Pedaling
Bikes: YEP!
Quoted: 334 Post(s)
Liked 522 Times
I mounted an old bike carrier of the variety that goes in the hitch receiver on the end of a wood work bench and use it for working on my bikes. I can lay out tools and parts on the bench for ease. I use velcro straps to cinch the top bar to the carrier so it can't move around on me.
Likes For SpedFast:
Quoted: 874 Post(s)
Liked 2,290 Times
I can see how that might be helpful for some maintenance. As a wrencher , I prefer an adjustable height bike work stand.
Likes For Kabuki12:
Quoted: 5224 Post(s)
Liked 3,584 Times
+1 I've definitely done some minor maintenance, such as cleaning & lubing, while bikes were on the back of the car
related - for a while, I used an old bike rack as a work stand. strapped it to our patio railing
Likes For rumrunn6:
Likes For boozergut:
your god hates me
Bikes: 2016 Richard Sachs, 2010 Carl Strong, 2006 Cannondale Synapse
Quoted: 1254 Post(s)
Liked 1,286 Times
...presuming you have a shop.
Sadly, I am garage-less, so my workstand is kept collapsed in a closet and only comes out -- to the front porch, usually -- when it's time for some serious maintenance work.
So OP's suggestion to use the car rack is quite appealing, genuinely appreciated. It's easier to take my bike to the car than it is to pull my workstand out of the closet!
Likes For Bob Ross:
Liked 3,584 Times
no I did not power wash the bike but did give it a rinse. I was there for the car's undercarriage
Likes For rumrunn6:
Quoted: 6196 Post(s)
Liked 4,810 Times
As we get older is it really a good idea to make it easier on ourselves? I might would look at difficulty squatting or bending down on a knee as a indication we don't squat often enough.
Likes For Iride01:
My bikes are parked in a garage in the basement of our condominium tower. The garage has upper and lower racks, the upper racks slide out and can be tilted down. For bike maintenance, I simply hang the bike by the nose of the saddle on the upper rack. It wiggles and moves a little, but it works for things like adjusting the brakes and derailleur, and cleaning/lubing/replacing the chain.
Likes For 50PlusCycling:
Quoted: 427 Post(s)
Liked 700 Times
You could turn the bike upside down, on grass or a rag under the seat and bars, to prevent scuffs. Just don't apply so much lube that it drops onto the bike-or apply to one chain section at a time while holding a rag under it to catch drips.
Likes For freeranger:
old newbie
Quoted: 541 Post(s)
Liked 359 Times
I did notice white spots on my driveway from the wax lube. I use White Lightning.
Likes For Billlyy:
