double crankset and single speed drive train?
commu*ist spy
I've just got my alfine 8 built up, and have just realized what a royal pain in the ass it is to get the lock ring in there for the rear sprocket. I thought I could be on a tour, encounter a mountain, and easily swap out the rear with a 20t or 22t to get my lowest gear ratio equivalent to a 34/28. NOT SO!!
So I'm taking a new approach. the crankset I'm using is a triple. I currently have a 1/8" ss chainring in the middle. I'm wondering if I can put another 1/8" chainring on the inner bolts to make a double. I'm not going to bother with putting in a front shifter. The small chain ring is only there for the steepest climbs. When that happens, I can just jump off my bike, align the chain on the smaller ring, and pedal on.
I'm a little worried about chain offset on my single speed chain. I'm guessing this won't be a big deal, but double checking.
Also, I will be running a spring tensioner on the bike, and the jump from the big ring to the small ring might be a lot for the tensioner to handle. I'm running 46t on the front. Can I run a 36t on the inner ring? or even 32?
Bikes: Kuota Ksano. Litespeed T5 gravel - brilliant!
I'm not digging this plan. I think the changer is generally included just for the conditions you describe, without the grimy hands.
I think there's something about the Alfine 8 that I'm not getting. It's a IGH? so you can't use a changer?
Bikes: 2013 Rivendell Sam, 1996 Bianchi Milano, 1994 Trek 820
Quoted: 13 Post(s)
Liked 8 Times
Why are you using a 1/8" chain and chainring when Shimano IGH cogs are 3/32"? You could be using a derailleur chain, double jockey tensioner (one that takes up shifting slack) and FD with your triple crank. You'd have to replace that 1/8" middle ring with a proper derailleur mid, of course.
Bikes: Priority 600, Priority Continuum, Devinci Dexter
Quoted: 685 Post(s)
Liked 55 Times
Surly used to make a double cog called a "dingle" for just such a thing as the OP. Do they still make it? Might be worth a look.
commu*ist spy
I still don't want a FD though, because if I do, it'll have to be a clamp on down tube shifter, on an oversized carbon fiber down tube, and that'll be a pain in the ass to find, and mess up the glossy finishing. I'll just step off the bike and do the chain swap manually. I'll rarely do it anyway.
commu*ist spy
I can, just don't want to. Want to keep the bike as simple as possible.
commu*ist spy
Well, I guessed that simplicity is part of the appeal but still, do you have to go back to the dark ages? A shifter for your front derailleur could be very elegantly accomplished but probably not if you're completely opposed to an additional cable.
commu*ist spy
ANYWAY, the original question is will the spring tensioner be able to handle a jump from 46t to 32t? Will the chain will have enough wrap around the cog?
Quoted: 13 Post(s)
Liked 8 Times
If you're going to manually move the chain, then the SS chain will work, so long as the chain line for both chainrings is pretty good—1/8" chains weren't designed for a lot of sideways flex. Definitely try to get a 1/8" ring for an inner—stainless steel, of course. 1/8" chains don't play well with 3/32" alloy rings, and dumping the chain off the inside ring can result in frame/paint damage and a locked drivetrain. Get a Deda Elementi Dog Fang or something like it anyway. They're cheap insurance for less than half an ounce.
commu*ist spy
BITD, I got a 3 cog cluster for my S-A 3 speed, and fitted a cottered triple crank & still used the 1/8" chain it came with.
3 by 3 by 3 ... a 27 speed .. used 3 levers to change gear combinations.
thats 14 t.. same as most road doubles ,so a chain tensioner with 2 pulleys with a distance between the 2 pulleys like a regular RD
should be adequate.
you can always use an old MTB RD as a chain tensioner if you need more slack .
should be adequate.
Señor Member
Quoted: 649 Post(s)
Liked 293 Times
FWIW, the Alfine model chain tensioner is designed to allow a double chainring setup, but you need a derailleur chain.
the Bushing 3/32" type was used by all the Pros, etc. before companies like Sedisport
introduced the bushingless chain , now all derailleur chains use that design ..
it begat the whole more 'speeds' the merrier thing, beginning with the 6 in the space of 5, and 7 in the space of 6 ..
Quoted: 4236 Post(s)
Liked 2,949 Times
That's an interesting concept that I hadn't heard of before, but it seems like you'd need to travel with a wrench and some latex gloves at all times. Not the end of the world, I suppose as I do that anyway.
Bikes: 1996 Eddy Merckx Titanium EX, 1989/90 Colnago Super(issimo?) Piu(?),1990 Concorde Aquila(hit by car while riding), others in build queue "when I get the time"
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
greasy finger front shifting the smaller chainring can even be on the outside. ( a Brompton bodge done on their older style 50t chainring cranks )
but if you are buying a new double crank use it as it comes ..
Constant tinkerer
This whole thread is a royal mess. Chain tensioner, manual front shifting, swapping cogs... Why not just stop screwing around and put a derailer drivetrain on? They use these handy little things called shifters that can be mounted on the downtube or the bars. And they give you all the range you'll ever need if you use a triple up front. The system will also be lighter than an IGH.
What am I missing here?
I have a 2 speed Planetary geared crank . and the chain never leaves the chainring,
just the crank arms turn at a different rate than the chainring ..
Not quite there yet
Bikes: A bunch of old steel bikes + an ICE trike
My BSR 3 speed + MD gives an 18~80" range, the direct gear is a 58"..
This is another one .. It shifts with a Cable Patterson Bike - Rocket Fast Shifting | Cannot Throw a Chain
Over drive when engaged , chainring turns faster than the crankarms ..
Surf Bum
Bikes: Lapierre Pulsium 500 FdJ, Ritchey breakaway cyclocross, vintage trek mtb.
Quoted: 13 Post(s)
Liked 5 Times
Interesting concept but comes with quite a weight penalty!
Thirst is stronger than the rules. - Stars and Watercarriers, 1974
commu*ist spy
