Converting a disc wheel
Bikes: Witt Custom / Cinelli SuperCorsa / Raleigh Cross, nothing original / Very old Bianchi Mtn Bike
Can anyone tell me if it's possible to convert a hed front disc to be used for the rear? I've searched around and can't seem to find an answer.
Thanks
Thanks
Bikes: Steel geared. Steel Fix.
Ummmmmm, its possible, but I wouldn't do it.
The front disc would be built and rated differently to a disc back wheel. I reckon even if you could do it the torsion placed on it would break it.
I thought that might be true, but apparently HED trispoke wheels are interchangeable.
Run What 'Ya Brung
Do you have a picture of it? If it has threading anywhere on the hub, I think it can be done with a Hed track axel conversion kit.
It's an old photo
Bikes: Cannondale R500, Specialized Hardrock
A surly fixxer with a HED rear works perfectly, although the chainline is greater than 42mm.
Have you done this? I got a reply from HED saying this was not possible, but they didn't really explain why. I'm curious if it's a problem of structural integrity, the complexity of modifying the axle, problems with the chainline, etc.
It's an old photo
As I said in my PM, please note that I'm not talking about a HED front.. I used a Surly Fixxer with a HED rear and for my application it worked perfectly.
Another suggestion: you might want to find an older disc wheel on eBay that takes a thread-on freewheel. You can thread a cog right on (but no lockring.. so only use this on a track where they aren't strictly necessary). Some even have track threads on the other side. I saw plenty between $150 and $300 when I was searching several months ago.
I didnt figure a new thread was needed, so i will resurrect.
I just bought a hed disc rear, Does the surly fixxer work on all rear heds? or is it just some years?
Before I buy a surly fixxer i would like to make sure i can do it. Thanks.
