Flat on trainer
Flat on trainer
I just had a flat tire on my trainer. I was making sure the tires were at the correct PSI and the valve broke off of my front tire. Has this ever happened to anyone else?
Yes, I still check the PSI on the front tire on the trainer. I don't want to have it get low and end up with a pinch flat later from the weight on the tube on the block.
Lost
meh, it happens. better it happened at home than if you were on the road.
https://less-than-epic.blogspot.com/
The flat really had nothing to do with the trainer. But sure sometimes you kill a valve. I ride 6 days a week and check pressure before every ride. In the last 10+ years, I could count on two fingers the number of valve fails I've had. So it's not a regular thing.
Also chances of pinch flatting on a front wheel on a trainer are pretty much non-existent.
Quoted: 2952 Post(s)
Liked 3,106 Times
Quoted: 139 Post(s)
Liked 33 Times
Back in the 80s, I only had a frame mounted pump. Once of those that attaches directly to the valve. I had the valve positioned at the floor. Bike tipped over and the valve snapped. I purchased a floor pump and even now I position the valve at the top of the wheel where the physics of levers is less likely to bite me.
C3 H6 O3 ACID
yeah...trainer had nothing to do with it. Valve just finally had enough and that's the end. Get some new tubes and ride more. Youre fine.
Bikes: 2011 CAAD 10
HAd it happen on a ride to work once. For some reason I had no spare. Had to call the wife for a ride to work.
Be happy it was on the trainer. Same thing happened to me in a mountain bike race last year. Pinch flat - change tube - kill valve - punch self in face - run 3 miles back to the start with my bike. Tubelsss MTB now.
