Chainring and crankset questions
Hi Guys,
Wife and I have Bike Fridays with a
Cranks - Alloy triple 170mm 30/42/52 130/74 bcd 119mm
Big chainring sometimes gets damaged in transit, so was thinking of carrying a spare.
Couple of questions:
1. Will I need to raise the FD if I put in a 53 instead of a 52?
2. When I see online, I see 52T chainrings in the same BCD [130] as 'double' and 'triples'. What's the difference?
https://www.chainreactioncycles.com/M...?ModelID=34733
https://www.chainreactioncycles.com/M...?ModelID=34734
3. Currently bikes are 8 speed, so can I put in a 9 speed or 10 speed chainring?
Really appreciate any help here.
1t adds to the circumference & so to the diameter, so perhaps, yes..
what is the difference? 1/2 inch.. the pitch between chain pin centers.
the chainring tooth has to be cut thinner for a 10 speed chain,
so ever-so slightly less surface to share the wear load of the chain..
you can add one of bike Friday's big chainguard discs to a triple
adding a spacer outside the outer chainring..
I have a chainguard outside the outer chain ring on a touring bike,
and a chain minder to catch over-shifts on the inside..
So ... no missed FD shifts.
Quoted: 2026 Post(s)
Liked 1,096 Times
1. Yes , you will have to raise the fd if it is currently close enough to the 52T ring. A 52T ring has a diameter of 8.28" and a 53T is 8.44" so the radial difference is .08" or about 5/64".
2. A "triple" middle chainring has ramps and pins on it's inside face to assist the shift from the granny ring to the middle. A double inner ring does not need these shifting assists on it's inner face.
3. If you use 9 or 10-speed chainrings with an 8-speed chain, the probability is the chain will rub on the outside ring when in the middle ring.
