Cadence for large cyclists
Quoted: 2700 Post(s)
Liked 486 Times
Hey guys, today on the group ride I had 2 people tell me that I should be in a higher gear. I'm a very large guy (240-250 lbs) and they say im powerful enough to push a higher gear. Ive heard spin to win, and my question is should larger people push a lower gear than lighter people? I don't feel like I was spinning THAT fast, only like 120 rpm (im guessing don't have a cadence meter)
Likes For tempocyclist:
Klaatu..Verata..Necktie?
Quoted: 10436 Post(s)
Liked 11,912 Times
Likes For genejockey:
Quoted: 338 Post(s)
Liked 408 Times
Impossible to know cadence without measuring.
Anyway, available research suggests self selected cadence is the optimum between metabolic efficiency and muscular strain... in other words, no sense in trying to deliberately manipulate it.
Lots of good data saying self selected cadence is usually going to be the most efficient, do what feels right. But, 120 seems high and 60 would seem low - measure what you are really doing.
I'm 220 lbs and I used to be a big chain ring. 60 RPM grinder. On group rides everyone was at higher RPM, so on one ride I consciously rode in lower gears and got my average RPM in the flats up to 70 (still lower than most others) and it actually felt better, as in less fatigued at the end. I've worked to push up my natural cadence up to around 75 average but it doesn't want to go much above that - and I'm fine with that.
Quoted: 7652 Post(s)
Liked 3,479 Times
"Everyone who sees how I ride and wants to help me ride better told me something, but I don't like it. Can you guys tell me something else?"
Likes For Maelochs:
Quoted: 1074 Post(s)
Liked 295 Times
That about self-chosen cadence is a so-so thing.
I am consistently slightly faster at my ”natural” cadence, at around 75.
However, for any ride longer than 30-45 minutes, it will leave me with aching knees the day after.
”Forcing” myself to a cadence of 85+ will leave me fit to ride the next day too.
Otherwise, ”ain’t broke, don’t fix”.
Sometimes there is no appreciable difference between ”good enough” and ”better”.
Likes For Reflector Guy:
Expired Member
Quoted: 3674 Post(s)
Liked 5,437 Times
Sup Larry! Don't let those poseurs tell you how to ride. They're just jealous of your pro cadence.
Likes For shelbyfv:
Quoted: 20810 Post(s)
Liked 9,456 Times
Likes For WhyFi:
Quoted: 2333 Post(s)
Liked 2,097 Times
1/2 your weight is the correct cadence. You're GTG
Likes For GhostRider62:
Quoted: 479 Post(s)
Liked 277 Times
I thought it was your annual income divided by 3 plus your age.
Seriously though, this is all moot (some of it should be mute) until you're able to accurately measure your cadence. Yes - natural, comfortable is good. But, new cyclists are often uncomfortable with, or at least unaccustomed to higher cadences. 75-95 seems to be normal range. 120 is high... also likely not accurate.
I've heard big guys (assuming big legs) shouldn't spin a high cadence... something about all that rotating mass, etc. I've also heard the Democrats colluded with the Jews to start forest fires with space lasers... so, not sure how valid the source was.
Likes For Zaskar:
Quoted: 581 Post(s)
Liked 921 Times
Whatever is comfortable. I would be interested what your actual cadence is, though - 120rpm is so fast that I am a little dubious, but not so fast that it is impossible, especially if casual observers are telling you to slow down. 120rpm would be two full revolutions per second, so one pedal will hit the top of the stroke twice for each steamboat you count.
Please get a computer with a cadence meter to confirm and report back.
Liked 11,912 Times
I'm a big guy, though not as big as I used to be, and I generally spin in the 95-105 range, though I find it easier to put out higher power if I spin at 105-110 - like in structured workouts on the trainer for example. When I started riding about 25 years ago, I spent some time learning to spin at a higher cadence, because at first it doesn't come naturally. It only took a couple weeks, and after that I've never had to consciously think about it.
Quoted: 590 Post(s)
Liked 445 Times
I also got told my cadence was too high (which at the time was maybe 95-100 while accelerating, but about 90 sustained on the flats), at which point I responded that I thought theirs was too low
Quoted: 2484 Post(s)
Liked 2,956 Times
Here's a guy with big legs who seems to think working on increasing his cadence is a good idea:
Likes For Trakhak:
Quoted: 3241 Post(s)
Liked 2,512 Times
The question for the OP is: Is the bike starting to buck like a bronco when you are spinning at that cadence? Are you bouncing around in the saddle and having to hold on?
On a related note, In the 41, if someone is spinning slower than agerage 41 poster, they are "doing it wrong" and need to increase their cadence. By contrast, if someone is spinning faster than average 41 poster, they also are "doing it wrong" and need to slow down their cadence. Amazing!
Liked 2,956 Times
Question for the bigger cyclists reading this thread who own a smart trainer: what cadence do you tend to maintain for most of your indoor riding?
Liked 2,512 Times
People are build differently and have different engines/drivetrains.
Likes For seypat:
Likes For teejaywhy:
Thread Killer
Quoted: 3148 Post(s)
Liked 1,713 Times
Perhaps predictably, my on-road cadence is usally in the 85-95rpm range when producing power, but overall (for a whole ride) is, of course, highly variable, so Strava usually shows ride average to be around 80rpm and max around 120rpm. I usually group ride as well, so that contributes to pedaling speed variability.
As my knees have been feeling better (less painful) over the last season, I’ve found myself dropping cadence and upping torque, because I can generate pretty good watts at lower RPM and keep my HR lower, saving the top end headroom for when I need to haul my tremendous mass uphill. When my cadence is high, HR runs higher, too, so even at moderate power levels, I’ll fatigue faster doing 98rpm than I will at 88rpm.
Likes For chaadster:
Liked 11,912 Times
EDIT: For some intervals, like VO2max intervals, I find spinning in the 105-110 range makes it easier to put out the power. I also find this on the road, that I can put out more power longer on things like 1/2 mile 2-3% climbs at higher cadence.
OM boy
Bikes: a bunch
Quoted: 517 Post(s)
Liked 645 Times
thought I might say something humorous ... nothing comes to mind... LOL!
so
cadence, all up to you... dividing the work load into more chunks (rpm) is a good thing. Except in real world, as you rev up, there is increasingly greater power loss because the the muscles start counteracting each other. That's what 'training' helps broaden - the range where the power loss is minimized as much as possible.
Every one is a bit different, but not hugely different. Over the years, the common conception developed is a range of rpm which seems optimum for most riders... it's out there.
Only you can decide (without being hooked up to an ergometer& ventilometer) what is good for you...
If you can get to 140 without signficant 'bouncing', on the road, then 120 might still be comfortable. Unless you're using some cadence meter, the number you may believe you're doing may not actually 'be'.
Anyone else's numbers don;t matter... especially if you're 'pulling' and they're having a hard time staying on your wheel...
Ride On
Yuri
so
Ride On
Yuri
Likes For cyclezen:
