Curious: what is a gravel bike?
Quoted: 2604 Post(s)
Liked 1,934 Times
I may get a gravel/all-road bike in the near future, but what people use them for seems to be all over the place. So it seems like a good subject for a discussion. (I'd say poll, but I'm not sure I can get multiple questions on one poll.) I doubt there will be a consensus, but the spread may be interesting.
What's the roughest road you'd consider riding on a gravel bike before you go to a mountain bike or fat bike? Bushwhacking, single track, double track, old road that's not maintained, gravel road that sees a road grader every election year, rail-trail, or something else?
How big a tire does your bike handle (or do you want it to handle)? 2", 47-48, 42, 38, 35, 32 mm?
If you take a load, how do you handle it? Bar bag, frame pack, seat bag, rack trunk, panniers, or a backpack?
What about lighting? Battery powered lights, just a blinky or two in the rear, full dyno system, or never ride at dark?
Quoted: 581 Post(s)
Liked 921 Times
Most new gravel bikes are kind of a cross between a road bike and a rigid 1990s mountain bike... drop handlebars and room for (what are now considered) narrowish off-road tires ~2"+-.
They also generally have modern technology such as hydraulic discs and often 1X drivetrains with a monster sized cassette, although some have 2X drivetrains.
Anyhow, that's what you get if you are in a bike shop looking to buy a new 'gravel bike'.
If you were to find a commonly ridden piece of gravel road and survey what types of bikes people are actually using as 'gravel bikes' then there is no one clear answer. My 'gravel bike' is an older road touring bike with medium/wide tires and mini-V brakes. My buddy rides his cyclocross bike with cantilevers. I see rigid mountain bikes and hybrids doing lots of gravel miles too. I notice fewer folks on full suspension bikes, and my personal experience is that fat bikes aren't ideal for long gravel rides, but I'm sure loads those bikes are used too.
Some people obsess over what are the ideal wheel sizes and handlebar shapes, but everybody has a different opinion, and if they are actually putting their opinion to use and riding then their opinion is correct.
Likes For ClydeClydeson:
Quoted: 446 Post(s)
Liked 1,045 Times
I think most "gravel" bikes tend to have wider tires for rougher terrain and lower gearing than road bikes, but not as low as MTB gearing. After that, anything goes.
Likes For prj71:
ignominious poltroon
Quoted: 2245 Post(s)
Liked 3,448 Times
I think the one distinguishing feature of a gravel bike is that it resembles a canonical drop-bar road bike, but can accept wider tires (say 35-38mm) that make off-pavement riding more pleasant (or possible).
For example, the current Trek Domane would qualify. There are of course many purpose-built gravel bikes, but they might be less capable on paved roads.
Attributes like disc brakes and lower gearing really help, but I wouldn't consider them defining characteristics (but would insist on them for any of the off-road rides I do). Disc brakes also allow fitting 650b wheels with wider tires.
It should be able to handle most non-technical single track and very rough, steep, unpaved fire-roads to get the full potential, while ideally not presenting a huge on-pavement penalty.
staring at the mountains
Bikes: Obed GVR, Fairdale Goodship, Salsa Timberjack 29
Quoted: 394 Post(s)
Liked 197 Times
Some gravel bikes are speckled with mounts so you can load up with bags and disappear up the Colorado Trail for a month (i.e. the Canyon Grizl). Some gravel bikes are essentially a pro-level road racer with big tires (Aspero, I'm looking at you). Some bikes try to do it all (Specialized Diverge maybe?).
One way to get a feel for what a particular bike's intentions are is to look at its marketing materials. Picking on Canyon for a sec, the Grail video shows a man reaching the end of pavement, shrugs and lets some air out of his tires and happily forges ahead on the dirt road in front of him. The Grizl video has bags, single-track, hike-a-bike, and camping. Could you go bikepacking through the woods on a Grail? Of course. Is it meant to? Eh, probably better suited for the roadier side of the spectrum. But nobody's gonna stop you, either. You can also get a notion of its intended purpose by the tires specc'd. The Grizl comes with 45mm Ramblers --dern near a full on mtb tire. The Grail has the Schwalbe G-One R in 40mm --a gravel race tire. For what it's worth, I have plenty of pavement between me and dirt roads/trails, so I chose something roadier with 38mm GravelKing SS tires (it does fit 50mm rubber if I wanna push its limits on rockier, more mtb-ier terrain). --And I have a "proper" mountain bike for the occasions I purposely head for technical single track. That's what works for me. May not be what you're looking for.
You have to do some soul-searching to know what kind of riding you prefer: where and how you'll want to ride it, how the new bike fits in your current lineup, and try to narrow it down from there. One way to think about it is a 'gravel' bike is kinda a modern 'anywhere' bike. --But you have to define your own 'anywhere.'
Likes For superdex:
Sunshine
Quoted: 10971 Post(s)
Liked 7,498 Times
If I can't comfortably ride a road on 43mm tires, I will just ride a different road. I suppose I would slap 50mm tires on the bike to do some epic low maintenance ride if the opportunity presented itself, but for all actual riding in reality, a 43mm tire is great for my weight, speed, comfort, and road conditions.
For lighting, I use the same lighting I have for any other bike- a garmin varia in the rear and a cygolite in the front. They both attach/detach quickly so I just move them when needed and ride.
If I rode crazy 350mi fravel races in March, then maybe a dynamo powered lighting system would be best.
Likes For mstateglfr:
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
Gravel bike is anything you want it to be. I guess the question is, what to you want it to be? In the most Generic terms, it is a drop bar bike that can take 33mm or larger tires. But like with road bikes, you can get a touring bike, and endurance bike, or a sprint bike. Add to that a fatter tired mountain bike.
For terrain, I'll pick the tire size more than I pick the bike. With the right tires, the bike doesn't make too much of a difference.
Load - I like not to ruin my aero. I hate a bike that acts like a sail into a headwind. For commuting, I'll use a messenger bag (low center of gravity, no sweat on my back), longer trips frame bag(s). If I'm going big (and slow) and self contained, nothing beats a set of Ortlieb's.
Likes For chas58:
I like bike
Bikes: Roubaix Comp 2020
Quoted: 267 Post(s)
Liked 283 Times
I bet if Strava ran a data analysis on all the miles in their database done on so-called gravel bikes they would see that 95% of those miles were on pavement. Personally for me it is a lot of work to get to good gravel riding, it takes 1+ hours in the car each way. So I'm yet another 95%-er.
Anyway, in practice most people are using gravel bikes as road bikes with occasional gravel riding thrown in. Kind of like how SUVs today are doing 99%+ road miles. There is nothing wrong with that, but to me it doesn't make a lot of sense to own two different bikes when two wheel sets will do the job.
Liked 1,934 Times
I don't think any of this really answers the question "what is a gravel bike," because the lines that separate mountain, gravel, CX, all-road, road plus, and adventure have blurred to the point of meaninglessness. Add to that the concept of "underbiking," and the distinctions become even less clear and important.
I had to smile when you brought up underbiking. A while back I was riding the Blue Ridge Parkway, and at the end of the day there was a couple hundred yards of gravel driveway to the campsite. I rode my touring bike (32s) up the driveway, passing a half dozen other riders who'd decided the gravel was too much to ride, so they were walking. I'm sure there are riders who would think nothing of riding 25s up that driveway, but there's also the "brought the wrong horse for this course" mentality!
Liked 1,934 Times
Most of the fire roads I've seen in the southern Appalachians tend to be decades old, with washed out gullies that are hard to hike. Are the fire roads near you better than that?
Quoted: 2333 Post(s)
Liked 2,097 Times
A gravel bike is the construct foisted upon us after selling us a mountain bike and then endurance bikes.
On a road bike, 28 or 32mm are plenty for most gravel where I live. For tougher stones, I ride my road bike with 650b x 38mm compass extra legere tires. If anything is technical, it is Mtb although I do wonder what I would race on the Tour Divide had I not had my injuries.
I use backpacking bags although recently bought a Tailfin setup
I use two rear blinkies.
I carry two front battery powered lights (one backup).
But gravel for me is more incidental rather than a destination. Some of my routes have gravel, most don't. 25mm isn't fun. 32mm is fine. for me. YMMV
Liked 1,934 Times
Quoted: 1084 Post(s)
Liked 687 Times
I take your point about the lines blurring. You did mention above that for really rough stuff you'd take your mountain bike; does that imply that you see MTB as the fatter tire/rougher trail end of the continuum? Presumably when you get down into the 20s tire width you're now on the "road" end.
I put drop bars and Continental Top Contacts on my 1989 Trek 970 (rigid mountain bike) and called it a gravel bike. We ride mostly hardpack dirt roads that get graded fairly regularly, but there's often sections that get pretty rough. The Top Contacts handle it very well but are also just fine for the paved roads we also ride. When there's a lot of really loose gravel or deep sand, not so much. I'm fine with getting off my bike for short stretches and just walking. That covers 90% of our riding, and for rougher courses I just use a bike with big fat MTB tires. That's why we need multiple bikes - there really isn't one bike to do it all, or at least do it all well.
In your example, if that short stretch up the driveway to the campground is the only section of the ride they had trouble with, maybe they didn't bring the wrong horse for the course. The Blue Ridge Parkway is paved, right?
Liked 3,448 Times
Huh. I was thinking a bit fatter tires, since I've got a touring bike that'll handle 35 (and maybe skinny 38) tires. Maybe I don't need another bike?
Liked 1,934 Times
If I may prod a bit, what's keeping the Saga from being your personal gravel grail? (Oops, did I just invent a new marketing meme?)
Liked 3,448 Times
It is kind of a wee bit sluggish to ride unloaded, both on and off road, compared to my custom steel "all road" bike. Like I said, it is entirely subjective, and perhaps quite unfair. In addition to having disc brakes and allowing huge tires, it has (slightly) flared bars, and Redshift Stopshock seatpost and stem, so in many ways it should be ideal. I have bar end shifters for 11 speed mtn gearing, and a 46/30T White Industry's crankset, and good hand-made wheels (WI hubs and HED Belgium+ rims), so it is really well-equipped. If I didn't own the custom bike which has spoiled me, I would probably appreciate it much more.
Likes For prj71:
I like bike
Quoted: 267 Post(s)
Liked 283 Times
Trying to look at this from a more generic viewpoint. Would it be fair to say your "gravel bike" would be one that had the capability to handle wider tires (whatever that's defined as), and you'd prefer to have two wheelsets, one for narrower tires and one for wider? Would I be correct to guess you'd want disc brakes to make the changeover easier?
For loads I use Tailfin panniers, they put all the load at the rear but are off-on in a matter of seconds (both bags and racks) so I don't have a bunch of junk attached to my bike on road rides. If I did longer trips I would at least get a handlebar bag and maybe a frame bag.
Liked 415 Times
I spend decades on a mountain bike, because road bikes are totally inappropriate to the roads around here (crappy broken up cement, asphalt and chip seal). At the beginning of this century, they were trying to tell us road bikes had to be ultra stiff, small tired, tight clearance Tour-de-France machines. Those bikes were crap on real roads, and I never bought one. an '90's mountain bike was faster.
finally, gravel bikes were re-invented (just like we had in the '70's) I can now ride them on my local roads, commute on them, and out sprint road bikes on our local club rides (on crap asphalt).
Currently running a CX bike on 37-38mm Conti GP5000 and Schwalbe Pro-one tires. ~10 watts rolling resistance - its as fast as my track bike, but usable on the broken asphalt we have around here. About 10% faster than the roadies on 25mm tires at 120psi. Its kind of a cheater tire on asphalt, but quite fun on class 1-2 gravel. Its giggles and laughs sprinting past road bikes on rough asphalt because they are being pummeled to death on our roads.
for rougher gravel I bump up to 40-50mm tires that can handle 2" thick gravel they lay down around here when re-grading a road.
What are people around you doing?
Liked 1,934 Times
That is me.
That was back in the last millenium.
Since then, a succession of mayors have diverted money to various pet projects, which don't include the streets (except for big interchanges on the edge of town). Now our streets average halfway between cracking pavement and what I call "allegedly paved." I've taken to re-routing whenever a road near my route has been paved in the last 5 years.
Liked 1,934 Times
That's because people are all over the place. Gravel bike use cases are very heavily regional, depending on the geology, geography, and types of right-of-ways. I wouldn't choose a gravel bike based on a global median use case, because such a bike may or may not have anything to do with my surroundings.
Liked 3,448 Times
Good points, and a good question. My feeling is that most gravel bikes bought locally are carted off on multi-hour drives or flights to get to gravel. TBH, that's half my proposed use case. The other half is back roads in gravel in a few locations near town, one of which claims to be a mountain. The third half (thanks, Click and Clack!) is the allegedly paved roads mentioned in my previous post. These streets feature pavement, most of which surrounds potholes or is broken up into 2" pieces for hundreds of yards. So most of the curiosity deals with the first half, what can I tackle when I hit the road and go to "gravel?"
Part of my commute is off-road as well, so I use it for that. The bike was in fact designed with that in mind, in 2013, before the label "gravel" was common. (I wish it could take a wider tire in the rear, but 42mm 650b is fine. If I use 700c, 38mm is the widest I can go in the rear.)
Having 38mm slicks on road here is more of asset than a penalty. The paved road conditions are quite poor.
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
“Gravel Bike” is a broad term that can cover everything from an “All Road” bike (basically an endurance road bike that takes big tires… like 38s), to bikes bordering on drop bar MTBs.
Sort of like the term “Mountain Bike”. It covers a wide range of bike types.
What you should get depends on what kind of unpaved surfaces you are dealing with, how much time you spend on/off pavement, what that pavement is like and how much you care about performance on pavement vs off-pavement.
