What, if anything, can be learnt about this spoke breakage?
Quoted: 463 Post(s)
Liked 567 Times
What, if anything, can be learnt about the cause of this spoke breakage from the image?
broken spoke on non-drive side
Really Old Senior Member
Bad luck.
Likes For Bill Kapaun:
Nothing unusual. Spoke threads are rolled and not cut, so not as bad as cut, but thread minor diameter is still less than spoke body, so constitutes a stress concentration. Spoke also has the most bending stress right above the nipple (for rims that are not "aimed and drilled"). So pretty normal.
Quoted: 2490 Post(s)
Liked 2,961 Times
I broke several spokes, front and rear, in the wheels of a Specialized Langster that I'd bought new. I was surprised and annoyed that it began breaking spokes after only about six months of riding. (I bought that bike the first year of production. It had several other problems that Specialized corrected in later years.)
It, too, had black spokes. Some broke at the nipple, most at the elbow. I eventually rebuilt both wheels with new spokes.
My guess is that the black finish was meant to conceal the dull finish of low-grade steel.
Mother Nature's Son
Quoted: 854 Post(s)
Liked 1,439 Times
I learnt they need to be replaced.
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,308 Times
I don't know if it is my eyes playing tricks, but it looks like there is an angle where the spoke exit the nipples on the adjacent spokes.
Quoted: 2604 Post(s)
Liked 1,934 Times
On both sides, so it's probably not an optical illusion. I'd guess detensioning the wheel and putting a drop of oil on each nipple head might allow the nipple to rotate in the wheel when you re-tension. The wheel might be under-tensioned, but again that's an "internet expert" guess.
Quoted: 5793 Post(s)
Liked 2,595 Times
Some rims are drilled too close to the nipple diameter forcing it to align with the hole rather than the spoke.
If not properly stress relieved, the angle creates a local dead load.
Added to working loads this can bring the total stress beyond the fatigue limit.
If I see this kind of bend, I make doubly sure to stress relieve and retrue the wheel. If I made spec. decisions, the rim's maker would be told to address the problem or lose my business.
When dealing with rims, the phrase "wiggle room" needs to be taken literally.
Quoted: 4806 Post(s)
Liked 3,933 Times
This may be the issue. Ideally spoke holes in rims are such that the nipple can float and properly align with the spoke.
I have broken spokes from bends there. Not a lot. I haven't focused on them when I build and it appears it shows.
Liked 2,595 Times
Since this is an OEM wheel, it's a manufacturing or spec. defect, and IMO the manufacturer's responsibility to make it right.
To be clear, it's the OEM's job to make sure hub, rim, spokes, and number of crosses all are compatible. As I said earlier, I would not have accepted these rims, but it would probably have been OK if the finished wheel were properly stress relieved.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Quoted: 970 Post(s)
Liked 1,635 Times
Your Turn...
As you're riding, the section of the rim at the contact patch gets flexed upwards a little relative to the hub. This momentarily shortens the spokes that are "passing through" the contact patch, causing them to drop in tension. If their tension was low in the first place (which is often the case for rear NDS spokes), they might go slack enough to wiggle and flex, which can fatigue the spoke where it contacts either the nipple or the hub.
Immediate fix is to replace the spoke. But when that happens, the wheel should be checked for appropriate spoke tension, and adequate spoke-to-spoke tension consistency. The failure may have been a fluke, but if it wasn't, you'll want to address the problem sooner rather than later.
Likes For HTupolev:
Liked 3,933 Times
No matter what, it boils down to wiggle room.
Light to very light spokes and as many crosses as I can do because I love the ride.
So rims that aren't fussy as to spoke orientation, yeah! But I haven't broken enough spokes at the rim to raise it to awareness when buying. Thanks, FB, now I'll look harder. (And see if maybe spoke holes want to be tweaked on rims I really want for other reasons if these don't allow proper alignment. The Velocity Aeros seemed to be poorish in that respect. My two city bikes are my only clincher bikes now and I am guessing those wheels are going to go to a natural death. Not spoke shedders despite being Aero'd and on their second or so rim. Winter PNW lava grit brake wear.)
Liked 2,595 Times
Spokes rarely break at the first thread stress riser.
Spokes bent at the nipple are fairly common, and yet this isn't a common cause of breakage. In any case there's a far worse bend at the other end.
But, a bend at the stress riser, that wasn't stress relieved, possibly compounded by other factors is simply too much.
FB
Chain-L site
FB
Chain-L site
Quoted: 4212 Post(s)
Liked 3,883 Times
Do I see a tad of corrosion at the spoke's broken end? Are the nipples Al? Andy
AndrewRStewart
AndrewRStewart
Liked 2,595 Times
Hopefully the OP would have mentioned that.
OTOH based on cosmetics alone, I lean to downplaying corrosion worries.
FB
Chain-L site
FB
Chain-L site
More information about the wheel/build would be helpful.
Position of the broken spoke (DS, NDS, Disk brake side)?
# of spokes, cross pattern?
Unusual hub, flange diameter?
Butted spokes?
How deep within the nipple the first thread was (assuming that the break was there)
Bike type & use.
Butted spokes?
Bike type & use.
Quoted: 463 Post(s)
Liked 567 Times
- The wheel is not OEM, but rather hand built.
- It is 20" (ETRTO406), 24-spokes laced two-cross.
- It has broken spokes twice since 2018, this time being the second time.
- The spoke broke while riding.
Mad bike riding scientist
Quoted: 6222 Post(s)
Liked 4,222 Times
The spoke may be too short or, more properly, have insufficient threads engaged with the nipple. In some Specialized OEM wheels of a certain age this is a common failure. The spokes don’t go through the nipple to the nipple head slot by several spoke threads in almost all of the ones that fail this way. The wheel can be properly tensioned and a nipple driver will still engage the nipple slot…can’t turn it but can still be put in there.
Stuart Black
Stuart Black
Quoted: 463 Post(s)
Liked 567 Times
Fwiw
Broken spoke today at 12 o'clock. Replaced previous broken spoke, still intact today, at 6 o'clock.
Liked 2,595 Times
Doubly so if both spokes broke the same way.
BTW some of the nipples nicely align with the spokes and some don't. Is it possible that the rim is drilled forward and back (rare but not unheard of), and not laced to match? Otherwise it's hard to explain some, but not all unaligned nipples.
Side note, having nothing to do with the issue.
I note that the wheel isn't mirrored (all trailing spokes either elbow in or out). Most hand builders mirror for a number of reasons. Machine built wheels are often built unmirrored because it's faster for a production worker. So, while this wouldn't cause failure at nipples, it argues against the wheel being hand built by a skilled builder.
Quoted: 463 Post(s)
Liked 567 Times
The thick plottens...
I just noticed that the first broken spoke a couple of years back was the antipode of this second broken spoke today. That is, on this 24-spoke wheel, the first spoke broke at 12 spokes plus/minus this second broken spoke or exactly on the opposite side or 180 degrees apart, both times on the non-drive side. What does this tell us, if anything?
Liked 2,595 Times
I hate coincidences, but can't find a logical connection.
In any case, your main concern should be where to go from here.
Two spokes in two years isn't something I'd get worked up over.
Based on the long interval, I'd simply replace the spoke and true the wheel. With any luck the next break will be a year or more away.
If that next break happened sooner, I'd note the shrinking interval, and either rebuild or say last chance.
Spokes angled at nipples: Very common on smaller wheel bikes, because with hubs being the same hole ring diameter as bigger wheels, you're gonna have more leading or trailing angle at the rim (for crossed spokes), and I don't think most rim makers take this into account, they just drill the holes pure radial, and there isn't enough nipple hole clearance for the nipple to swivel enough to be in alignment with the spoke. Every spoke on my 406 2X wheels are like that. Note: They are cheap Dahon single-wall rims, so the material is thick at the nipple hole, even thicker if that is actually a thin double-wall as some have speculated, I have not yet had apart since then to look closely.
I have not stress-relieved my wheel spokes. Only saw bit decades ago about doing that with feet, didn't seem precise to me. In recent days I read how to properly do this on sheldonbrown, gripping adjacent parallel spokes.
Likes For Duragrouch:
