GT triple triangle frame thread
Quoted: 8 Post(s)
Stop reading my posts!
Quoted: 1422 Post(s)
Liked 1,038 Times
I have a similar Talera and my frame came with a thinner-than cable housing piece of hollow stainless tube that has a shallow "S" curve and fits in that brazed-on guide on the seat tube, it's only about 3" long. The housing terminates on the forward end of the FORWARD guide in the bottomside of the top tube and the cable is in a plastic "inner liner" from that guide into REARWARD guide and then raw cable from there into this "S-tube"...You might also try stripping the plastic off a conventional housing and just use the bare metal coil, or maybe source a piece from a V-brake cable "noodle". Maybe I can snap a pic....later...it's a strange set-up but I don't recall it being any more friction-prone than normal when set up this way I describe.
Quoted: 4719 Post(s)
Liked 3,034 Times
The problem is probably the sharp bend of the cable exiting from the seat tube tunnel though it may be compounded by burring on the ends of the cut cable housing. This is very easy to do, especially with standard pliers and can greatly increase cable drag.
As mentioned by Unworthy1 (we really have to get him to give up the misnomer) a piece of cable housing stripped of the plastic casing may fit or a V-brake noodle. Alternately, you could cut a slit in the tunnel and pry it open slightly, so that it will accept cable housing. Another option would be to find an old GT crossover cable guide, though you may have to remove the tunnel to optimize the cable alignment between the brakes and the tunnel on the underside of the top tube.
Likes For T-Mar:
Quoted: 7287 Post(s)
Liked 2,365 Times
I like the way these frames look but I can't ride them. My thighs rub against the seat stays. Either I ride with my legs unusually close together or they're unusually thick. I had a Shogun briefly, which I flipped.
Liked 1,038 Times
you can almost make out the small "S" shaped piece in the pic above but it's blurry on my monitor^ this one is dark-colored. You can clearly tell the cable is bare in the run from the TT underside guide to that "S"-piece.
glorified 5954
glorified 5954
The weather this weekend was just beautiful. Yesterday I took the Tempest out for the first time in a while. What a great bike to play around on! It is so much fun, and such a gorgeous thing. After a little high of a jump, I found out first hand what a "burp" is in regards to tubeless tires. After pumping back up to the minimum stated 2.0 bar, it burped again. Maybe I have put on too much weight in my off-season!
However, I had so much fun yesterday that today the tempest got some metal polish, another ride and then a few pics.
Quoted: 620 Post(s)
Liked 1,205 Times
Just got this one in a trade last night, lots of changes planned. I believe it's an '89.
glorified 5954
I am always on the look out for a good deal on a steel GT. I have dreams of copper plating one and letting it oxidize.
Heck on Wheels
Bikes: In Signature
Quoted: 206 Post(s)
"I had a great ride this morning, except for that part about winding up at work."
Bikes so far: 2011 Felt Z85, 80's Raleigh Sovereign (USA), 91 Bianchi Peregrine, 91 Austro-Daimler Pathfinder, 90's Trek 730 Multitrack, STOLEN: 80 Schwinn Voyageur (Japan)
Quoted: 620 Post(s)
Liked 1,205 Times
glorified 5954
That's a great looking Timberline. The road conversion looks great to me. I think that will be my goal. A 26" steel frame with copper plating and road conversion.
WV is not flat..
I have a 1990 20" Karakoram elite frames I so want to do the 700 conversion on. Have the wheels and everything, but it's fun to ride it 26" wheeled right now.
My Tequesta, dump rescue.
The dropouts are just horizontal enough to allow chain tensioning.
Fixed cog is drilled to bolt on the disc side of the hub.
Mini starfish crank
At this time it had Avocet 2" slicks
Black with gold overspray
Rusty steel bars, later I wrapped the grip area with black leather. Seat is a factory embroidered Giant
Mini starfish crank
Likes For 2cam16:
Bikes: 84 Pinarello Trevisio, 86 Guerciotti SLX, 96 Specialized Stumpjumper, 2010 Surly Cross Check, 88 Centurion Prestige, 73 Raleigh Sports, GT Force, Bridgestone MB4
Quoted: 278 Post(s)
Liked 71 Times
My GT roadie, lovely bike, not as twitchy as my Centurion Prestige, much stiffer but actually a pleasant ride:
aka: Dr. Cannondale
Quoted: 2151 Post(s)
Liked 3,380 Times
Likes For rccardr:
Quoted: 1115 Post(s)
Liked 2,230 Times
