Another Vintage Campagnolo Question from the Masi Noob
Hi All,
My 1982 Masi Gran Corsa project goes well, the replacement 6-speed 13-28 freewheel rides well, and bike is now in good riding condition. Hoping to ride in the California Eroica if that event takes place this year.
However, I have found the front 39 chainring has a bit of wear and will want to replace soon/eventually. The Campagnolo 53 and 39 135 BCD, 5-bolt arm chainrings currently on the bike (which I been told are 6 speed Chorus, yet to confirm) are stamped AS, and been unable to locate a replacement AS 39 chainring. However, there are several Campagnolo Record 39 chainrings NOS on eBay that are for 8/9/10 speed Record groupsets, pic attached. One seller stated that this Campagnolo Record 8/9/10 speed chainring has the correct 135 BCD and will work fine with with my 53 AS chainring 6-speed setup. My concern is that the 8/9/10 speed chainring will be thinner to accommodate the narrower 8/9/10 speed chains, and may not work correctly with my wider 6 speed chain.
Hopefully one of the Campy vintage experts here might be able to confirm if this chainring will work properly as a replacement for my current 39 AS chainring.
Hard to see in the pic, but next to stamped 39 is a stamped E in a diamond shaped outline.
Thanks in advance
Thanks in advance
Quoted: 3464 Post(s)
Liked 2,828 Times
The 39 should be no problem.
the Big rig can be an issue as the Record crank has one chainring bolt that fastens from the back.
so, a different hole configuration there.
the subordinate groups have all exposed fasteners and assemble in the expected way.
Bikes: Peugeot, Legnano, Fuji, Zunow, De Rosa, Miyata, Bianchi, Pinarello, Specialized, Bridgestone, Cinelli, Merckx
Quoted: 429 Post(s)
Liked 475 Times
Very useful information to understand the compatibility you're facing: https://branfordbike.com/chainrings
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,923 Times
Your Masi is equipped with the original Chorus group from 1988 until it upgraded to 8spd Ergo in ‘92ish
I mix match 135 rings all the time on my Chorus cranks with no problems
Sugar "Kane" Kowalczyk
Hi
THANK YOU all very much for the info, most appreciated. Here is the pic of Masi. Beautiful warm day here in California's Silicon Valley, so I'm going to take the Masi out for ride along the bay..
Likes For City Guy:
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,295 Times
The perhaps-thinner teeth will work fine with 7-8s chain.
Campagnolo chainring spacing determination is "opposite" from Shimano's, in that Campagnolo's big ring is the determinant of chainring spacing differences.
That Masi looks great!
Likes For dddd:
Quoted: 1856 Post(s)
Liked 664 Times
For your chainring wearing out, I would not worry about it too much. Campy chainrings have always been very long-lasting, in my experience!
Quoted: 1079 Post(s)
Liked 1,898 Times
Any 135BCD will fit (C) Record cranks, but the pin that stops the chain dropping between the crank arm and chainring may be in the wrong place unless it’s a Record chainring. Ideally it would also have the knurled nut that the hidden bolt screws in to, but you can secure it with a track nut and Loctite.
Liked 2,828 Times
Kinda, sorta, not really.
