Bringin' home the groceries
Quoted: 11 Post(s)
I'd like to start making grocery runs larger than what I can fit in my backpack. Not sure where to begin. I'm figuring on a pretty standard rear rack, or do I need more of a heavy-duty touring rack?
After that, though, what to use as carriers? I see grocery panniers, collapsible baskets, some other solutions. I worry a little about having bags stolen while I'm in the grocery store. Do you take them inside? Looking for some ideas.
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 15 Times
It will boil down to what works for you. I have one bike with baskets on it that I can just plop my grocery bags in. Another has a large set of panniers that stay fastened to the bike, they are strapped on and have small stainless steel cables looped around to help stop them from walking off. You can use a stock rack, but I would take the weight of what you plan to haul into consideration. Things like canned goods and bottled liquids can add weight quickly.
Aaron
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
Likes For wahoonc:
I use the Ortlieb back roller Panniers for my shopping trips. I pop them off , bring them in, empty,
put them on the check out belt first, and the checker puts the stuff in them ,
then they go back in the trolley and I roll the trolley back outside where the bike is locked up.
Quoted: 11 Post(s)
Nice, but $180 full-blown touring panniers seem like a bit much unless I'm also doing some touring when I'm not getting groceries. It also seems to me that touring panniers give up some capacity over baskets and similar fixtures built to haul goods around.
the part that I find makes them most useful is the way they attach to the rack is both secure locking on,
to not pop off while you ride,
and quickly removable by simply lifting the strap connecting the 2 hooks . stuff stays dry inside both ways ..
& I use no disposable into the waste stream shop's bags.. [used to get 5c credit for each bag I didn't use]
if you can find a cheap bag which combines all those features go fo it.
what is your years auto insurance costing you + costs to run it? then a pannier that will last for decades will seem cheap.
For a rack, a regular 30-lb capacity rear rack will be fine - a gallon of milk (or beer) weighs a little over 8 lbs - your standard Blackburn rack will thus carry nearly four gallons of milk (or beer), or one gallon of milk and 22 boxes of cereal. Personally I have a 55 lb capacity Axiom rack, but it's not really necessary to have that much capacity.
For shopping panniers, I generally use cheap grocery bag panniers from Nashbar. (Other folks make them too.) Paper or reusable grocery bags fit right into them, or you can use the panniers themselves, "unlined". They do get a little flexy, which is where the extra side rails of my Axiom rack come in handy. I just as frequently use standard touring panniers.
I have also tried collapsible baskets by Wald, but I ride unloaded so often that the rattling got annoying, so I took them off in favor of easily removable panniers.
Whatever panniers you use, the method described by fietsbob is the way to go - carry them into the store and put them on the checkout first so the bagger can bag right into them. Ortliebs work for him, but any panniers with a wide top opening will do.
Quoted: 659 Post(s)
Liked 7 Times
No need for $180 ones for either touring or grocery shopping. I got Nashbar's Waterproof rear panniers when they were on sale for $30/pr. The initial use was for touring but they've been my standard way of hauling groceries home as well. Also got some generic rear rack for less than $10 around the same time. It holds my weight without any problem, so 60 or 70 lbs. of groceries are not an issue at all (my usual load is less, but it gets that high when buying lots of liquids and other high-density items). The rack and panniers have been in regular use for over 5 years now and still seem as good as new.
Quoted: 70 Post(s)
Liked 15 Times
I like the features of the Ortlieb panniers, the more you use them the cheaper they are!
Aaron
Bikes: Takara Deluxe Touring 12 speed, Trek Tracklight 730
Quoted: 42 Post(s)
I use a Burley D'lite 2 seat trailer (FREE at the local drop-off/pick through for the poor) towed behind a 21 speed hybrid. I usually have my 4 year old, and there's plenty of room for groceries etc.
Quoted: 11 Post(s)
Funded by the sale of my truck (along with a bunch of ther biking goodies), that trailer has changed my life. Easily one of the best peieces of kit I've bought to date.
aka Phil Jungels
Grocery panniers, from Performance, bought for 28 bucks on sale for the pair. Reusable grocery bags fit perfect! A normal cheap rear rack has survived for 7 years, so far!
I use the Arkel Shopper bag - it's pricey but very spacious. It can fit a shopping basket full of groceries, and if you "pop the top" an overflowing basket. I have a pair, but 95% of the time only use one for shopping. Capacity is four six packs of bottled beer per pannier, more if you buy canned.
The one major drawback is a that they are very deep and don't have heel clearance so if you don't have long chainstays, small feet, or a rack that extends back more than normal you likely will have heel strike. While you may knock half of the pannier off, I've never once dropped one. I have, on a couple occasions, ridden with only one of the Arkel cam hooks hooked and the bag hanging half off for several miles wondering why my bike seemed to be swaying...
Bikes: 1984 Takara 490 Challenge
For years, I used a set of 1984 Cannondale Frannies and Overlands with a Blackburn rack. After adding a Winchester trailer, I weighed one trip and found that I was bringing home 85 pounds on the bike and hit the trailer's 100 pound limit. Another factor to consider is do you shop in bulk? Sometimes, you can save money buy buying bulk. Then, the weight can add up.
Getting ready for a party, or maybe there is a sale....
I may have six stripper clips of beer and soda, plus the rest of the groceries. With the Big Dummy, I don't need a trailer. Two stripper clips port and starboard, two on the upper deck. Groceries pad this out front and back. Oh, the Touring bikes rear Overlands become the Big Dummy's front Overlands. (funny how that works)
Quoted: 70 Post(s)
Liked 15 Times
You probably won't like my solution then; I bought a Burley Travoy and the upper & lower market bags.
Aaron
Bikes: GT Traffic 2.0 w/ Blackburn Rack
I use my Blackburn EX-1 disc rack ($49.99 installed), and two Blackburn EX-Delux Pannier bags ($24.99 each on clearance). They aren't the right size for grocery store bags, but the price was right and they fit what I buy. I subside mostly on fruits, vegetables, dried beans, and dried rice. Nothing I currently purchase from the store comes as a liquid. I take the bags in the store with me. They snap on and off in about 5 seconds per bag. I haven't needed the additional capacity, but I could always add a trunk bag to my setup if I wanted.
Bikes: 2017 Giant Escape 2, 2013 Giant Escape 2, 1986 Bianchi Nuovo Alloro
Quoted: 8 Post(s)
Liked 5 Times
I use the Topeak trunk bag, the DXP which is the largest one they make. It has fold out panniers. I use that and my Chrome Bravo backpack, which goes from 20L to 40L. Between that and the trunk bag all my groceries are a done deal. And yes, the trunk bag has a removable shoulder strap so you can take it with in the store. You need Topeak rack to use the bag. It slides in and out on the rack using a rail and locks and unlocks the bag. Check it out on Amazon.
https://www.amazon.com/Topeak-Trunk-B...peak+trunk+bag
The Topeak rack,
https://www.amazon.com/Topeak-6310703...opeak+mtx+rack
The Topeak rack,
Likes For ikaika777:
Likes For martin_at_gbc:
Quoted: 18376 Post(s)
Liked 4,511 Times
I do some errands, thrift store runs, whatnot. Perhaps up to $100 - $200 worth of stuff in my bags, trailer, etc. So far nobody has touched the bike, trailer, lights, speedo, miscellaneous cargo, etc. I always take the phone and wallet with me and lock the bike (but I don't lock the trailer).
I suppose I figure it would be a pain if someone stole $100 worth of stuff, but hopefully they need it more than me.
It is just not worth stressing over the little things that are beyond my control. And, it is not worth always stripping everything off the bike then remounting it. (the bike is secure at night).
Quoted: 11 Post(s)
Thanks for all the great ideas. I just can't see myself ever hauling a trailer. I have a car for when it's necessary and I'm not on any kind of crusade.
Quoted: 32 Post(s)
Quoted: 32 Post(s)
Calculate how many hours a month do you have to work, Carson, Just to pay the cost of owning the car , and insuring it ,
even leaving out the fuel cost to drive that ton of stuff just to get a few bags of Groceries ..
Work More , Cancel your Holidays .
Bikes: Treks and a Moulton
Quoted: 64 Post(s)
These REI Novara panniers will haul 3 bags worth of groceries. Use one or both, they clip to a standard rack and can be installed/removed literally in two seconds per side.
Novara Nucleus Commuter Pannier - Pair - REI.com
