Hardest workout before easiest in a microcycle?
just another gosling
Quoted: 3889 Post(s)
Liked 1,938 Times
CTS has an interesting article by their top ultrarunning coach. Seems equally applicable to bike training. I haven't tried his system, but I'm guessing from my experience that he's right and all those canned training plans are wrong.
Which Comes First: Hardest or Easiest Workouts?
Results matter
Results matter
Quoted: 232 Post(s)
Hmmm... I wonder if this would naturally happen correctly for both novice and trained athletes alike when using MSI because if...
The common way beginner training plans work is to start with short or easier training sessions, then add more time or intensity in subsequent workouts. The notion is that if you can run one mile this week, then your body will adapt and be able to run two miles next week, then three the following, etc. This also gets applied to interval workouts. This week you can do six hill repeats, so next week you can do seven, and the week after you can do eight. The term for this is ‘progressive overload. In the beginning, progressive overload works...
...then RPE for new athletes would decrease without progression while RPE would skyrocket with progression. And since MSI is based on RPE, then novices would naturally increase load via MSI while trained athletes would naturally decrease load via MSI
Liked 1,938 Times
After reading the article, I'll try changing that. Next week's an easier week, so then . . .
Results matter
Results matter
Quoted: 2952 Post(s)
Liked 3,106 Times
Interesting. That's generally been my approach so this bears it out. I'd do anaerobic capacity or VO2max work early in the week. I need a certain amount of freshness or I won't be able to complete them.
Quoted: 232 Post(s)
I'm not sure of that. I can get myself to do most anything. The question is: in retrospect, was that a good idea? How do we make progress? Is the straight line in the graph that way to go or should it be an upward curve? One has to have the ATL and CTL data and plot it. Or use TP where it's done for me automatically. Looking at my past data, sometimes I do it frontloaded, sometimes backloaded. My guess is that it depended on how I felt or the weather or other life factors, not a direct result of planning.
Quoted: 232 Post(s)
Liked 3,106 Times
I read it to apply to both.
Liked 1,938 Times
Huh. I think you're right. Never occurred to me because all training plans have the other way 'round. So I went to TP and switched my Tuesday and Thursday workouts, and sure enough it evened out the ATL graph, plus I should be more rested for the Sunday sufferfest.
Results matter
Results matter
Quoted: 232 Post(s)
Version 7.0
Bikes: Too Many
Quoted: 1340 Post(s)
Liked 2,482 Times
IMO, this article is for ultra marathoners who have a high degree of fitness and the focus is week to week.
As an ultramarathon athlete, you are better off completing your hardest workouts (like the 8 hill repeat workout mentioned above) when you are most rested, and then backing off the volume of workload (like the 6 hill repeat workout mentioned above) as you accumulate fatigue over time.
This concept may or may not apply to road cyclists but may have some implication for long distance cyclists.
Liked 1,938 Times
I've seen programs where there't not the variation in ATL shown in the article. Some folks do different things during a week but all having about the same TSS. I'm in the one killer ride a week camp because I train specifically for that thing. I can definitely see the point of not having huge weekly peaks in the ATL if one didn't need them. As you point out, I'm in the camp with the ultrarunners because we need that one big workout.
I'm not sufficiently familiar with the training science of overload to opine which is actually better for ultimate fitness . . . anyone? I suppose the real question is "fitness for what."
Results matter
Results matter
Gravel Rocks
Liked 1,938 Times
I'm a CTS coached ultra distance cyclist and this is not the way my training plans are designed. My longer intervals are at the end of the week and the end of the microcycle, and intervals are always the same power zone within a cycle. I very rarely do anything above steady state though, a couple times a year V02max.
Results matter
Results matter
