Your Dream Rando Rig
Quoted: 3459 Post(s)
Liked 1,465 Times
You missed the point, it isn't about frequency or reliability. It's about what you can do if it fails. In my example above, several experienced people at the controle couldn't figure it out. A friend of mine recently had connection issues, messed around with the thing and eventually took the bike to the shop to get it rectified. I don't need this kind of stress during an ultra endurance ride. With a mechanical derailleur, all I need are spare cables (you bring them on 1000k and above, don't you?) and tools and I can fix 99% of any issue that comes up.
Good thing it was a conventional cable operated system.
Quoted: 6963 Post(s)
Liked 10,963 Times
Likewise with tubeless. Sure they generally work. But on the rare occasion that they don't seal, I don't want to deal with putting a tube into a messy gunk-filled tire in the middle of an event, and also deal with mounting and unmounting tighter-than-usual tires in the process. And yes, a couple of people I have ridden with had exactly this problem - punctures that aren't sealing.
I also suspect that, as electronic drivetrains become more common, then more people will be knowledgeable enough to handle the occasional problem. But perhaps we're not there yet.
Randomhead
Liked 3,696 Times
The thing about Di2 is that if you crash or otherwise damage one of the cables, it can be a fairly elaborate and expensive repair. I helped my lbs troubleshoot the aftermath of a crash on a Di2 system. I recall it was going to take $400 in cables to fix it, and the diagnostic software didn't pinpoint the issue very quickly. OTOH, I have seen any number of cable driven bikes that were modified into single speeds so the rider could complete their ride. Di2 failures among randonneurs that ride a lot seems to involve not charging the battery in time. Oftentimes the battery is hidden and you can't just swap another one in. It seems like etap wouldn't have this problem as much because you are constantly swapping out batteries. I wanted an etap system for my travel bike, but now they went to 12 speed and I see no reason for that. Maybe shimano will come out with wireless
I think if my dream rando rig had di2 i’d get it setup to charge the battery for the dyno. My 6700 mechanical shifters have over 25000km on them and are still going strong. Electronic does appeal to me since I found my hands were cramping up on PBP from all the shifting, but I hear the 11 speed stuff needs a lighter touch. I haven’t looked closely at a di2 derailleur but it can likely be rigged up to stay near the middle of the cassette.
Liked 10,963 Times
You could ride a 1200k brevet on a single charge of a Di2 battery and have plenty of juice left over. So, running out of battery power would require epic stupidity.
Bikes: 2004 Trek 520, resto-modded 1987 Cannondale SR400, rando-modded 1976 AD Vent Noir; 2019 Wabi Classic; 1989? Burley Duet
Quoted: 213 Post(s)
Liked 93 Times
Count me as an electronic shifting skeptic.
Upside: shifts a little quicker. Downside: if something goes wrong, your ride is probably over. And things often go wrong on brevets.
It’s cool on racing bikes, but what’s the point of it on a randonneuse?
Bikes: Trek Emonda SL6 .... Miyata One Thousand
Quoted: 63 Post(s)
Liked 29 Times
It took me over 4 years of searching to find a 1980's Miyata 1000 in my size
I found one in May from a seller in Germany .... took several emails to convince him to ship it to the UK
Bike is in mint condition and was his late father's who bought it brand new, was very nervous of riding with drop bars, so stored it indoors for 44 years
I'm still changing things and so far I've done the following:
HED Belgium Plus rims (tubeless rims), SON 28 Dynamo hub, Royce rear hub and am currently using Continental GP 5000 TL (tubeless tyres in 32mm wide)
Honjo hammered fenders which will allow me to use tyres up to 38mm wide
Brooks Cambium C17 Carved saddle
3 Nitto stainless steel bottle cages
MTB clipless pedals
Japanese Crane Suzu brass bell
Supernova front and rear dynamo lights (I need to change the front Supernova E3 triple light to the Supernova E3 Pro light as the triple is way too bright for oncoming cars (it has a symetrical light beam)
I've bought the Tubus Cosmo stainless steel back rack
Still to buy the Tubus stainless front rack
Still to buy 4 Ortlieb bags (I have the full set of Miss Grape bikepacking bags for when I want to travel lighter without the pannier bags)
still to buy the Sinewave Revolution powerbank charger
still to buy a secondary front USB light such as a Lupine ... I have a Cygolite Hotshot pro 200 as a rear backup
then I think I'm done .... my first tour will be in May/June 2020 along a part of the Wild Atlantic way in Ireland (fishing/camping where possible plus some B&B inbetween) .... I'm using this bike as my daily commuter and will also use it for some Audax rides
I still have all the original parts (including the original Miyata Radial tyres), original Miyata pedals, mirror etc should I wish to enter L'Eroica events
here's a pic from a while back with the original miyata rack (It came with the original Miyata front and rear racks but they are not as strong as Tubus)
If I were to buy a newer bike, I'd be looking very closely at something like a Mason Bokeh with disc brakes
MTB clipless pedals
Likes For dim:
Quoted: 896 Post(s)
Liked 2,063 Times
OP here, back for more; call it a mini-zombie thread.
Still recovering from the injury, with added insult of some kind of bug for the last several days. My hard neck brace is off, I've been cleared to ride paved trails but no traffic, and post-crash miles to date are around 70.
I had a chat with a local builder, and he could put me in a full custom bike for rando from $4k on up depending. He can do pretty much everything I want, though he does only work in steel and has gone 100% thru-axle.
An alternative that's growing on me lately is the All City Space Horse disc https://allcitycycles.com/bikes/space_horse
Room for 700x42 with fenders! That's what I'm talking about.
Frameset at $650 or their SRAM Apex build at $1500 ($1200 for the Cream color if I'm reading it correctly). If I start with the frame, the things on my list it lacks are:
Horizontal top tube. Purely aesthetic to me; it's nearly there so I'll give it a pass.
Three bottle mounts. Can be worked around.
Chain Hanger on the seat stay. Again mainly aesthetic.
I've been comparing it to the offerings from Surly and Salsa, and it looks better to my eyes. Heck I might see if Joe Bike in Portland has my size in stock. I may be too sick to work, but not too sick to throw a leg over a bike .
Bikes: 2003 Litespeed Vortex, 2017 All-City Mr. Pink, ~1997 Trek Multitrack 700
Quoted: 139 Post(s)
Liked 94 Times
I have an All City Mr. Pink (that is what is shown in my avatar) and it has worked out very well for randonneuring!
Quoted: 7348 Post(s)
Liked 2,467 Times
That Space Horse looks great. Does anyone here have one?
Liked 1,465 Times
Compact double with an 11/32 cassette. I like a wider range myself, I have a road triple (52/42/30) with an 11/32 cassette on my rando bike. But the compact double is close to what I have, so probably not worth modifying later.
I do not think I have ever seen a replaceable derailleur hanger on a steel frame. Is that as rare as I think it is? Is that something that you need to get a spare in case of damage?
Cream color bike has a five arm crank, others are four arm. I did not look close at other components, they might also differ.
Sounds like you are getting a new bike, then you will have to decide later how important things like a dynohub are. Or couplings.
I like having a rear disc on a chain stay like that instead of on the seatstay, that makes it less likely that fitting a rack becomes problematic.
Liked 1,465 Times
Oops, double posted.
I’m surprised they are still making bikes with quick release disc brakes. My mtb has them and they are finicky to get the discs lined up after removing the wheel. My LBS has one of the new all-city bike shop and he paint looks amazing, the rest of the parts seem like good stuff. I’d buy a replacement hanger and toss it in the saddlebag. I suppose one of those emergency hangers would work with the quick release wheels but I’ve never had a hanger issue on the road.
i am thinking about getting a Fuji Jari as a second rando rig, has room 700x43 or 650x50 or something like that. I was eyeing up the carbon version but they did have a steel one at some point but it had entry level parts on it, dunno if they still make it or even if they’re available widely.
Randomhead
Liked 3,696 Times
QR dropouts on a disc fork is definitely an anachronism nowadays. I suggest getting TA hubs and using a QR adapter. OTOH, if you use 40mm tires with sealant, no reason to take your wheels off.
I have an all city. It's a bit quirky and heavy, but I have definitely gotten my money's worth out of it. I wish it had mid fork braze ons like the Space Horse. I made another fork for it, but I haven't gotten it coated yet so it isn't installed.
Liked 2,467 Times
unterhausen how much does it weigh?
Liked 1,465 Times
I have never had any problem seating my quick release rear disc wheel into the frame, the disc and brake unit always line up just right. But I only have one bike with a disc wheel, so my "survey" has a very small population. Perhaps some frames have dropouts with larger manufacturing tolerances?
Randomhead
Liked 3,696 Times
My LBS has some of the Cosmic Stallions. That looks like a nice bike. Outfitted with GRX.
Likes For unterhausen:
Quoted: 896 Post(s)
Liked 2,063 Times
I had a short test ride of the Space Horse, before things shut down. I liked the ride - smooth and comfortable for the 20 minute test ride. I didn't get a chance to ride the Fuji Jari. That line looks promising.
It's not the time for me to spend money on a new bike, since income is not assured. OTOH supporting the local economy... we'll see. Nonetheless, that doesn't stop the ongoing analysis though .
Currently looking at:
Soma Fog Cutter build (currently my #1 )
Space Horse (lacks 3rd bottle mount, mech disc)
Fuji Jari 2.3 (mech disc)
Surly Straggler (2, mech disc, 1x)
Interestingly, Soma calls the Fog Cutter "road bike geometry, with clearance for wide tires", white Fuji says the Jari is designed for gravel, "not just a road bike with wide tires".
Likes For downtube42:
Quoted: 896 Post(s)
Liked 2,063 Times
OP with an update.
Yesterday I came home with a Soma Fog Cutter frame. (in a box, carried by me on a bike for 10 miles from Universal, but that's another story). It's gorgeous.
Parts acquired thus far are a Selle Anatomica saddle, currently on my vintage Windsor, and a set of 105 11x3 integrated shifters, bars. Measuring up the Fog Cutter (which is gorgeous, did I mention) against my last list:
- Room for 38s plus fenders. 40 even. More even. Check.
- Speaking of fenders, full coverage with mud flaps. Still the plan
- While we're at it, eyelets for fenders and racks. Check.
- Fork mounts for a front rando rack I haven't purchased the fork yet. Probably going with the Steel Fog Cutter, which has mounts
- Three water bottle mounts No, just two.
- 700c wheels. I'm tall and there's plenty tire selection at 700c. Check.
- Generator hub lighting front and rear. Probably, though I'll keep looking at battery lights.
- Headlamp on the front rack Second guessing the front rack.
- Rechargeable 2nd headlight on the bars for high beam. Still the plan
- Generator tail light mounted on the rear fender. Still the plan
- Second battery powered tail-light on the seatpost Still the plan
- Gearing will be low low low. Did I mention low? I want to spin at 5 mph. Still the plan
- Coupled for travel Decided not.
- Cable shifters Yes
- Disc brakes Yes
- Shallow flared drop bars So-so on the bars I picked up.
- Tubeless ready, shallow v, alloy, black, no sticker rims Depends on how the budget sorts out.
- Wahoo Element GPS Not in the budget.
- Handlebar bag Still the plan
- Under-seat bag Still the plan
- Chain hanger on the seatstay. Because I like them. Nope
- Pump peg and frame pump, if such things still exist. Nope
- Externally routed cables with cable stops and maximum exposed inner wire Check
- Hydraulic or mechanical discs. Depends on coupler technology. Cable actuated hydro is the plan
- Paint matching custom metal fenders or replacable off-the-shelf fenders Soma has matching fenders. Like black though. TBD
- Frame pump mounting location. Hmmm
- Frame and fork material. Tending toward steel/carbon. Steel is real
Go Ride
Custom Alex Meade
I’ve my dream rando bike already, a stainless steel custom Alex Meade frameset with campy components.
Alex Meade Stainless Steel Randonnuer
Likes For tacreamer:
Quoted: 896 Post(s)
Liked 2,063 Times
Note that the front steel fork doesn't have mounting points so you'll need clamps. For brakes, I am using Juin Tech R1 Cable / Hydro and really like them.
Edit: To clarify, the steel fork doesn't have mid fork mounts.
Liked 1,465 Times
I really like those square taper Campy triples too, have them on several of my bikes. I did not even notice the S&S couplers until I looked at the blown up photo, they are almost camouflaged on the stainless frame. The upper rack mounts on the seat stays are not just welded on, they are a work of art too. I like a third bottle cage under the downtube too, I think that should be included on more bikes.
Marvelous. Thanks for posting.
Likes For Tourist in MSN:
Liked 2,467 Times
My goodness, @tacreamer. You are done buying bikes.
