Long Distance Competition/Ultracycling, Randonneuring and Endurance Cycling Do you enjoy centuries, double centuries, brevets, randonnees, and 24-hour time trials? Share ride reports, and exchange training, equipment, and nutrition information specific to long distance cycling. This isn't for tours, this is for endurance events cycling
Missing link chain connector
Old 10-13-20, 01:02 PM
yannisg
Quoted: 56 Post(s)
Liked 5 Times in 5 Posts
I have been using these connectors (KMC) and generic ones for a while.
I find them practical for maintaining the chain; that is, I am more inclined to remove the chain and clean it.
I didn't have much luck with the on-the-bike chain cleaners I've used in the past.
I re-use the links when I replace the chain, but there seems to be some confusion where this is correct or not.
Do you re-use them?
yannisg is offline
Old 10-13-20, 01:25 PM
BikeLite
Quoted: 253 Post(s)
Liked 45 Times in 29 Posts
Some are resuable but may only be used 3 times. It is on KMC site and directions with each chain.
"3. Always check MissingLink. KMC suggests to replace a new MissingLink when it is worn or after locking and unlocking 3 times."
BikeLite is offline
Old 10-13-20, 01:27 PM
10 Wheels
Galveston County Texas
10 Wheels's Avatar
Bikes: 2010 Catrike Expedition, 02 GTO, 2011 Magnum
Quoted: 856 Post(s)
Liked 272 Times in 135 Posts
I have always reused them. Never had a chain problem.
Fred "The Real Fred"
10 Wheels is offline
Marylander
Quoted: 87 Post(s)
Liked 72 Times in 54 Posts
Some of them say re-usable on the packages and some don't. I have reused one of the cheapest KMC 11 speed ones and just keep a spare on the bike. Time will tell.
Marylander is online now
Old 10-13-20, 01:29 PM
jadocs
jadocs's Avatar
Quoted: 906 Post(s)
Liked 494 Times in 333 Posts
Get a Connex link and never have to worry about that again. They are designed to be removed and re-used by hand. No tools required.
jadocs is offline
Old 10-13-20, 04:49 PM
shelbyfv
shelbyfv's Avatar
Quoted: 2048 Post(s)
Liked 1,762 Times in 955 Posts
I suggest you continue doing what works for you.
shelbyfv is offline
Old 10-14-20, 04:46 AM
unterhausen
Randomhead
Liked 881 Times in 657 Posts
They are cheap, facial reconstruction surgery is not. 9 speed were reusable, 10 speed is limited re-use.
unterhausen is offline
Old 10-14-20, 05:02 AM
Prowler
Quoted: 297 Post(s)
Liked 246 Times in 145 Posts
I reuse them but keep an eye on how hard they are to open. When they get too easy then they could open by themselves if the chain slacks in use. BTDT. So I'll estimate you can reuse the KMC links 3 or 4 times then into the recycling. YMMV. I use a plier like tool to "open" them.
I agree about removing the chain. Mine get cleaned by a real good sloshing in milk bottle with a couple of inches of OMS, then dry out in the sun.
Prowler is offline
Old 10-17-20, 05:51 AM
Tourist in MSN
Quoted: 2071 Post(s)
Liked 387 Times in 326 Posts
All of my KMC quick links are the reusable ones, I reuse them and I do not keep track of how often I reused them. I have one bike with 10 speed chain, several bikes with eight speed.
KMC has two different specifications for eight speed chain width, so if you run an eight speed KMC chain make sure you get the right link for it.
Tourist in MSN is offline
Old 12-16-20, 09:15 PM
dwmckee
dwmckee's Avatar
Quoted: 248 Post(s)
Liked 133 Times in 87 Posts
I replace the link when I replace the chain. I may open it 2 - 3 times for cleaning during the chain life. I would NEVER reuse an old link on a new chain.
When a chain breaks it is often at a high stress point when you are pedaling really hard. And it goes completely all at once. It can cause a derailleur to break, and can result in a very painful fall...
dwmckee is offline
Old 12-19-20, 01:19 PM
kcjc
Quoted: 17 Post(s)
Liked 4 Times in 3 Posts
I reused the quick link that came with my SRAM 1110 & 1130 chain a few times (on same chain only) but couldn't reuse the one that came on my Red chain. I just started waxing my chains, one chain per week (4x1110 & a 1130). Three cycles so far so that al least four reuse for each chain (plus one for stripping the chain and one of quick link was reused once before). Technically it's 8 times since I reconnect the link after removing from the bike and do my rewaxing in batches with the link attached so I don't lose them. It's my indoors setup and no problems so far.
kcjc is offline
