Best chain lubricant
Senior member
Quoted: 943 Post(s)
Liked 658 Times
Rust Check Coat & Protect: Premium Vehicle Undercarriage Protectant. https://www.rustcheck.com/index.php?...128&Itemid=135
You gotta be kidding!
Quoted: 5787 Post(s)
Liked 2,580 Times
What is on the new chains is "Gleitmo". SRAM identifies it here: https://www.sram.com/sram/mountain/p...s/pc-890-chain
What they don't say is *which* variant of Gleitmo. There are a number of variations.
It is made by: Solid Film Lubricants - FUCHS LUBRITECH GmbH
I have no idea how similar the chemistry might be to cosmoline.
Meanwhile, nobody uses Cosmoline any more. That was the packing "oil" of choice when chains were packed in wooden crates and shipped as loose cargo. The advent of container freight about half a century ago, eliminated the worry about rust from seawater getting all over the cargo, and therefore the need for cosmoline.
What sets modern factory lubes apart from after market products is how they're applied. Sram applies a thinned Gleitmo product to the parts at the point of assembly, and it then sets up as the solvent evaporates. Other companies run finished chains into a hot oil bath allowing excess to drip back into the bath.
FB
Chain-L site
FB
Chain-L site
Bikes: Dawes Lightning DLX, 1988 Klein Performance, 1991 Peugeot Safari, 1985 Raleigh Alyeska, Carrera Phantom, 1973 Raleigh Record
Quoted: 282 Post(s)
Liked 129 Times
I've been thinking about buying a quart of Cosmoline, heating it up and soaking the chain in it. It's what comes on the chains from the factory in the first place.
Everyone seems to think that the stuff that comes on new chains is made from unicorn blood or that it has magical properties. I might give it a try.
Liked 2,580 Times
This is a 50 year old myth dating back to when rust in sea transit was the main concern. Those days are long gone, and all the major makers lubricate their chains with what they believe will perform well in use. Keep in mind that well over 90% of their production is original equipment on bikes, and their customers don't want a protective product that someone would have to remove later.
FB
Chain-L site
FB
Chain-L site
Bikes: 2008 Dawes Haymaker 20XX Leader LD515 TotoCycling Road Bike
Quoted: 27 Post(s)
Liked 32 Times
I have been using Tri-Flow for the past 10 years. There are probably better lubricants out there, but I have been so satisfied with it I didn't bother with anything else.
Quoted: 282 Post(s)
Liked 129 Times
Whatever they pack the chains in, they choose it for it's ability to get the chains to the customer in the best condition. That may mean that they expect bike shops to use a different lube when they assemble the bikes.
Maybe the stuff that comes on the chains is a great lube in operation; I'm just not willing to assume that.
Quoted: 282 Post(s)
Liked 129 Times
We used a lot of Tri-Flow at the bike shop I worked at for one summer in the early 90s. I wouldn't call that an endorsement, but it did seem to be good stuff. I think we used some Pedro's lube, too, but it was mostly Tri-Flow.
Liked 2,580 Times
FB
Chain-L site
FB
Chain-L site
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
There may be such a myth, but it's got nothing to do with my skepticism. I said that based on my experience working in manufacturing, as a machinist in a tool and gage shop, a material handler and shipper in a cable manufacturing company, a documentation control specialist in a semiconductor test handler manufacturer, and a drafter/designer in fiber optic telecommunications and medical device companies.
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Then why don't Titanium Nitride and Nickel plated chains come with anything on them? Or do they?
I recently purchased a Nickel plated track chain and it was bare. KMC can't believe that no lube at all is what will perform best.
Lack of "Lube" on Ti Ni and Nickel plated chains is what leads me to believe that the stuff is mainly to prevent rust. I think rust in sea transit is still a concern.
Not trying to challenge, just asking.
-Tim-
Liked 2,580 Times
-Tim-
-Tim-
As Rich pointed out earlier, chain makers are also concerned how their products are presented on the dealer's shelves, so their choice of lubricants will represent a balance of various concerns, though rust in ocean transit is far less of one than it used to be, and just about any kind of oil will more than suffice in that dept.
As an example of how marketing can trump performance, Shimano a while back changed their factory to a much lighter lube in response to a market perception that what they were using needed to be washed off. They stayed with this product for a while until their Skunk Works crew started complaining that Dura Ace chains weren't holding up as well as hey used to, then they switched back to something that looked worse and lubed better.
FB
Chain-L site
FB
Chain-L site
Quoted: 2604 Post(s)
Liked 1,933 Times
I'm not happy with what Shimano puts on their chains. I've used SRAM for years, and the lube SRAM chains come with is good enough to ride until it starts squeaking. Got a "bargain" on some Shimano chains, so I put some on last month. After a week out of town, the Shimano chain with factory lube and less than 100 miles, had started rusting and was jumping badly.
Infamous Member
Bikes: Surly Big Dummy, Fuji World, 80ish Bianchi
"Let us hope our weapons are never needed --but do not forget what the common people knew when they demanded the Bill of Rights: An armed citizenry is the first defense, the best defense, and the final defense against tyranny. If guns are outlawed, only the government will have guns. Only the police, the secret police, the military, the hired servants of our rulers. Only the government -- and a few outlaws. I intend to be among the outlaws" - Edward Abbey
- Soli Deo Gloria -
Liked 736 Times
It's a good question. It might be that without OEM business, and when marketing "bright and shiny" their priorities shift from delivering a lubed chain. Or it might be oiled, but with the outside washed or wiped dry.
I remain unconvinced and am considering buying a quart of Cosmoline 342 to try.
Prerequisite is that I have to care enough about the subject to spend $39 and I haven't reached that level yet. In my mind however, I know that I'm right and that's all that really matters.
Quoted: 38 Post(s)
Liked 11 Times
I shave all the stray cats around and boil the fur down.....What's left over after the painful 72 hour top secret process,mixed in the Booger Labs,with finely ground pygmy butt hair,is by far the best chain lube ever.
Or when I'm tired,Mobil 1 works.
Liked 2,580 Times
If I were going to try to convince people of anything, I'd be clearer about pitching a specific product. My rule on stuff like this is very simple; it's your bike, and your money, so it's your choice, right wrong or otherwise.
However, as to Cosmoline, the bulk of their business and product focus is rust prevention, not lubrication. They do make lubricants, but those are different products from their most common product.
FB
Chain-L site
FB
Chain-L site
Liked 2,568 Times
It's something that I filed away long ago, but haven't acted on since this Chain-L kick has been treating me well.
