Shorter cranks.
Bikes: Had an old Columbia in the 80's, here a used Schwinn hybrid, now a Cannondale Quick 3 and a Topstone 105..
Quoted: 249 Post(s)
Liked 306 Times
Shorter cranks.
Have any of you had a knee issue and ended up changing your cranks to a shorter length? I am considering doing this as the 175's that came on my bike are, according to all of the articles and graphs and tables I have read, are much too long for my short legs. It is proposed that it is a considerable contributing factor to some of my knee issues. I have a second bike with 172.5's and I have much less of an issue with my knees with this bike so it seems to have some validity. It is a relatively costly swap so I was hoping to get some real-time feedback before I order the parts and attempt the change. I am looking to change from the 175's to 170's or the165's that the tables say are correct for my leg length. I am concerned that I will be making the hills a more difficult issue as I have a lot of them where I live. Thanks in advance.
Frank.
Frank.
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times
How could anyone advise you when you haven't provided the frame size you are riding, your height, or your inseam?
Quoted: 427 Post(s)
Liked 699 Times
After reading your post, I was wondering the same thing. Found an article that seems to imply that it wouldn't affect climbing (we have gears for that, so it makes sense). Here's the article, hope you find it helpful: The Benefits of Reducing Your Crank Length | TrainingPeaks
Likes For freeranger:
Quoted: 6193 Post(s)
Liked 4,808 Times
I've ridden with short cranks all my life in the 160 mm to 165 mm. When I built up my Paramount from a frame in 2017, I put 170 mm cranks on it because at the time the shorter were out of stock and/or not in the silver color I wanted then. I'm 5'-11" with 34.5" inseam.
Soon after I began riding it, I noticed a slight annoyance behind my knees, mostly my right knee. Never enough to keep me from riding as hard or as long as I wanted. And it usually bothered me more after I was off the bike and relaxed during the evening watching TV or reading.
I put up with it thinking I'd get used to it for four months. Then a short crank in silver came available, I ordered it, put it on and that feeling behind my knees was gone. It was only 5 mm difference, but I even noticed that I was more comfortable with my legs not pushing up into my gut as far when I was in the drops and very aero.
If you do decide to try shorter cranks, make certain that you don't already depend on that lowest gear on your bike. If you do, then you might also need to change your gearing too.
Likes For Iride01:
Quoted: 249 Post(s)
Liked 306 Times
Thank s again, Frank.
Liked 4,808 Times
My brother-in-law just had a knee replacement. He had issues for 20 years with his knee. He now wonders why he waited so long. However he doesn't ride bikes. But he is otherwise very active and using his legs all the time.
EDIT:
I said "just had" but thinking about it, it's been over a year. He's out cutting down damaged trees and cleaning up from the ice storm several weeks ago on the acreage he has. He's a fair bit older than me and just don't know when to slow down.
EDIT:
Likes For Iride01:
just another gosling
Quoted: 3886 Post(s)
Liked 1,938 Times
Thank you for this. I do use the lowest gear but only to try to keep as much strain off my knee as I can. I am thinking 165mm from the 175 as my inseam is 29". I also realize that at my age, 72, the obvious knee issues are not going to be solved with just a crank change. At some point, I might have to face replacement but for now, I believe a shorter crank arm will help. And who knows, it might be enough to fend off the surgery.
Results matter
Results matter
Quoted: 4806 Post(s)
Liked 3,928 Times
The ancient advice, shorter cranks - slightly smaller gears. Say 172.5 to 165. Say starting with 50-36 x 11-32.
an equivalent would be 165/172.5 X 50 = 47, X 36 = 34 so a crankset of 47-34 or:
172.5,165 X 12 = 12.6 (13), X 32 = 33.4 (34).
I'd probably go with a 48-34 crankset or 13-24 cassette. More important - get the cranks your body likes! Life's too short to ride the wrong ones. I'm a long skinny guy. My knees to not like crank length changes. 175s work for me really well. I use them for all my bikes, including my three fix gears. I'm not saying at all you should go bigger - just go "right for your". That your knees like 172.5s more than 175s says a lot. Explore smaller and watch how your knees (and the rest of you) respond.)
Likes For 79pmooney:
Quoted: 249 Post(s)
Liked 306 Times
Frank.
Likes For Helderberg:
Liked 1,938 Times
So 162.5 would be even better if you can find them. One understands that shorter cranks mean slightly lower gearing and spinning faster to put out the same power/maintain the same speed - it's a torque issue. You'll want gear inches then of .92 * what you use now, like maybe 1 cog tooth lower, no big deal.
Results matter
Results matter
Likes For Carbonfiberboy:
Quoted: 249 Post(s)
Liked 306 Times
Thanks again for your help, Frank.
Liked 1,938 Times
Thank you for this. I have ordered 165 as I am matching a 9 speed rear cog set so Sora 165mm. I had already had the rear cogs bumped to 11-36 so this should be a good compromise. I was looking into possibly an 11-40 for the rear cogs but tough to find in 9 speed. I think the benefit of not pinching my knees at the top of the stroke is in itself going to be an improvement. What I found I was doing was splaying my knees out at the top of the stroke and not correcting on the down push. If I could concentrate on keeping my knees in at the top I would not feel any pain in my knee. When fatigued it would be harder for me to keep up with it. I don't think this will be a bad move regardless so I have ordered the Sora crankset, Ultraga BB, and the tools to do the job. Glad I have two bikes as this will be a definite teaching moment for me.
The knees are a perpetual geezer issue, though some folks hit geezer at 40. Oddly enough, the cure is to do unweighted full depth squats, hams on calves, first slowly working up to going down that far, perhaps over a period of many months, doing a few squats say every other day. Always stop at the point where discomfort begins, never pushing into pain. Then after one can get all the way down, doing like 3 sets a couple times a week. If you've ever visited the Middle to Far East, you'd see people resting in that full squat position on street corners. It's very comfortable and human knee joints are built particularly to be able to do that resting position.
That said, you really are better off with the shorter cranks, regardless of knee issues because your legs will spend more time with less knee bend, which is the stronger range of motion.
Results matter
Results matter
Quoted: 249 Post(s)
Liked 306 Times
I found an 11-40 9-speed cassette on Amazon for our tandem. Works fine, but one needs to add a Wolf Tooth Roadlink to move the RD down.
Be safe.
P/s: What was the brand 11-40 cassette you found? Might be something I will need in the future.
Liked 1,938 Times
I was stationed in South East Asia during the war and I do remember the seated position you are describing. Just thinking about that makes my knees hurt. When I got out of the service I went to work with my father as an apprentice plumber. The older guys that worked for my father would tell me not to kneel on the concrete. At least use a piece of corrugated cardboard they would say, but I was 24 years old and I knew everything. I should have listened but as my uncle used to say, "Smart too late". Thanks again for your help and I will give the exercises you described a try, carefully.
Be safe.
Be safe.
https://www.amazon.com/Race-CSM980-9...dp/B01N4KXIQF/
https://www.amazon.com/Cassette-11-4...dp/B078XGXJZ7/
I knelt for 40 years, but used knee pads after the first 5. My knees used to hurt, too. I think they got better when I stopped using ibutprofen when they hurt, started lifting at the gym, and did more hiking in the mountains, years of it. I've also taken glucosamine sulfate and MSM for 30 years, but I don't think that had anything to do with my knee issue, though it might be part of the reason that my knee cartilage is still perfect.
Results matter
Results matter
Quoted: 249 Post(s)
Liked 306 Times
Amazon doesn't have the one I bought any more, but here are two more:
Be safe, Frank.
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
My wife has hip and knee issues and rode 165mm arms for years. When I converted her bike to 650B wheels, I also changed the arms to 155mm, mostly to keep ground clearance. It hasn't been a problem.
Likes For JohnDThompson:
Quoted: 1074 Post(s)
Liked 295 Times
I’ve had knee issues since an overexertion event in my teens. Shorter cranks makes it easier to keep the cadence up, which the knees appreciate.
There’s nothing I could ride with the longer cranks that I can’t ride with the shorter cranks.
Although I’m still slightly faster on the longer cranks - at least day one.
These days I tend to value being able to sleep w/o painkillers more than being as fast as possible.
Likes For dabac:
Quoted: 35 Post(s)
Liked 11 Times
get ready though, now you are going to have to change all your bikes, it was expensive for me to do.
Likes For Tom L:
Quoted: 249 Post(s)
Liked 306 Times
Frank.
Super Modest
Quoted: 10963 Post(s)
Liked 4,620 Times
I'm 5'7" with a cycling inseam of 31" and change. I've ridden 165s since 1984 when I rode my first track bike and converted every road bike since to 165s.
Caveat: I'm a natural spinner.
Keep the chain tight!
Likes For Trsnrtr:
Pennylane Splitter
Bikes: Yes
Quoted: 1797 Post(s)
Liked 1,439 Times
I changed from 175 cranks to 170s. I went for a short ride on a friend's new SS that had 170s and it was astounding how much more comfortable the pedaling was. I used to get some knee pain after long or tough rides and that's no longer the case. No scientific or medical proof of anything, but its been working for me for a few years now.
Likes For skidder:
Bikes: 2011 ICE Sprint Special Edition
Quoted: 35 Post(s)
Liked 101 Times
My wife, JoLynn has very short legs and we changed out her Crank arms to "152 mm" triple crankset and she says it's a LOT easier on her knees and let's her "SPIN" much more than before. I'm thinking of switching to 160 mm crankarms myself!!
Take Care, Ride Safe, have FUN! :)
Jo: 2009 ICE Trice T
BJ: 2011 ICE Sprint Special Edition
Likes For bjjoondo:
Quoted: 249 Post(s)
Liked 306 Times
I have been informed that my order, 165mm Sora Crankset, bottom bracket, and necessary tools are on the way. Should have everything by the end of the week or so and will try to get the change made soon thereafter. Will definitely keep you all in the loop as to my experience. I have also already looked up the parts for my other bike but am waiting on this change first.
Thanks again to all of you that have tried to help this old guy stay on a bike a little longer.
Frank.
Frank.
Interesting read here. I am 6'3" with a 35 inch pant inseam. I rode 170 for years and then had a bike fit which said 175. I made the switch and actually prefer it -- fewer knee issues. To each their own.
Likes For dmanders:
Quoted: 249 Post(s)
Liked 306 Times
Frank.
