Your Catch of the Day / Saved from the Dump!
#2726
Lost
Bikes: old columbia 27" road bike
Oldroads.com has a serial number database too, if you want to be exact. Left rear dropout I believe?,,,,BD
So many bikes, so little dime.
#2728
This is not meant in anyway as a put-down, as anything can be brought back to life with enought effort
(and cash, too often), but I was wondering how this bike got so badly corroded: did it live anywhere
near the ocean (NJ)? or was it simply 'stored' outside somewhere.
Interested in what effect salt content in water vapor will do to steel/aluminum over time.
The bike is not that ancient that you'd expect that much corrosion.
#2729
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
Well, it was mountain bike day at the garage sale today. Bought all four bikes at one sale. Pretty nice Gary Fisher and a couple of nice Treks (the 7000 might be my size, oops), and a nice Women's Specialized. Just sold my last women's bike yesterday, so I kind of needed a recharge. I wish the Gary Fisher was a little bigger, it looks to be a nice bike. FWIW: I bought a bike from this guy at his last garage sale (last year).
All four bikes were made in the USA. Can't remember the last time that happened.
On the various flip threads, I have stated that you should never buy a mtb. I need to amend that comment. At the right price, you can flip mtbs. You just have to be very careful about parts spending and pick them up pretty cheap. These bikes all need very little or nothing, just a good clean up and some adjustments. I already have the Specialized ready to go.
#2730
Quoted: 7348 Post(s)
Liked 2,470 Times
Excellent! What did you pay for them?
Without even thinking about it, I notice I'm buying road bikes, not mountain bikes. Maybe it's my intuition. Why should we not be flipping mountain bikes? Are the resale values lower? Do you have a chart of values for mountain bikes? We recently discussed this with road bikes, i.e. with steel rims, $150, alloy rims, $200, chromoly frame, $300, etc.
#2731
N+1
Bikes: A few
Liked 5 Times
Mountain bikes have always been harder to sell, and they sell for much less. I often have trouble selling decent bike shop big name (early Schwinn, Trek, GF, Jamis, Cannondale, etc.) for $100-150 where as most road bikes in the range fly out the door. MTBs tend to be used and abused more than road bikes so often they need much more work and/or parts than a road bike does. The older 7 speed trigger shifters most of these MTBs came with are notorious for getting gummed up and stop working. They are often easy to fix, but not everyone knows how to fix them. I have used that to my advantage at a garage sale saying the shifters don't work so would you take less.
#2732
Liked 2,470 Times
I totally believe you on the harder-to-sell and worth-less-than-road-bikes points. I'll take your word for it.
I'm pretty much just getting started in this endeavor and can use all the help I can get.
You're saying 7 speed triggers can be fixed? No way! My LBS said they're too complicated, so I took their word for it and replaced a pair. I also bought an extra pair, with integrated brake levers, and I keep them around, new, in the box, for an anticipated need. Maybe I wasted my money, but what the heck. So what should I know about fixing them?!
#2734
Bicycle Repair Man !!!
Upgraded the drive to a 14 speed with a new 7 speed block (14-28) to give it a better / wider gear range and as always, the 6 speed Shimano indexed shifters work fine running 7 speeds... added a 1 mm spacer on each side as this was all the extra it needed for the 7 speed and in this way no re-dish is required.
Those red label Arayas are the nicest wheels... one could tour on them.
I love these old sport class bikes as they are racy enough for play but are also really versatile enough to serve a number of roles... I'd love to see it with fenders and a rack which would make it the nicest little commutourer.
#2735
Bikes: I hate bikes!
Quoted: 431 Post(s)
Liked 710 Times
Picked up this Raleigh International today off of Philly CL for $75.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
#2736
N+1
Bikes: A few
Liked 5 Times
The pawl inside the shifter gets gummed up after years of use (and neglect) and will generally stop moving. That is what happens when you push the shift level and it doesn't catch. The fix is usually two fold. First is spray the crap out of it with a thin cleaner/lube (WD40, Finish Line 1 step, triflow, etc.) and repeatedly try and up and down shift while pedaling. Often that will get the pawl moving again. The usual sure fire cure is to take off the access cover to the shifter and find the pawl. Poke it with a pointy thin object to move it back and forth and get it freed up again. I use a sharpened old spoke, aka. Spokie Pokie. Then hit the pawl with a little bit of lube. Try shifting it up and down repeated while pedaling the bike. You will generally have the pawl start to engage in a few gears, then a few more, until it is completely working again. The other is if you own one remove the shifters and run them through an ultrasonic cleaner. I would say probably 95% of the trigger shifters can be fixed with this method. The other 5% are actually broken and need replacing.
#2737
At the last minute today, I learned of the most enormous rummage sale I've ever seen. There were dozens of bikes. I hope to shoot pictures tomorrow. I also got a trailer. That was $62, but I don't think I could do much better than that.
I got:
- a circa 1975 Gitane 10 speed
- an 1990's Trek Antelope 830
- a circa 1984 Fuji Cambridge VI (city bike)
- a pretty Univega mixte, circa 1982
I got:
#2738
Thrifty Bill
Liked 964 Times
+1 Super find on the International.
On MTBs, there just is not much interest in the older ones. Its a lot different market than road bikes. But as a buyer, they can represent tremendous value (until you want to sell).
#2741
It strikes even on vacation. I was spending the week in a small town last week, and had a few minutes to kill, so I hit a few thrift stores. Two had nothing, when I pulled up to the third I could see bikes piled up along the fence in the back. I figured there were probably 50 or so. Can't all be Roadmasters huh ? I was traveling with the family, so I was with minivan and the rack was full already with the family bikes. My Dad was with us and he had his truck, but it was pretty full already too. The point is, I had to leave some stuff I never would have walked away from otherwise.
Left behind were a Raleigh sports missing wheels, a tall Raleigh frame that I could not make a model out on, a Nishiki rivera, and an un identified mixte.
What I grabbed was a Gary Fisher Hoo Koo E Koo. I was asking the guy prices as I dug through, the highest price I encountered was 15.00 on the Fisher. I told him I would take it, and he took it up front. Problem, they don't take debit or credit. I say " all I have is 12 bucks", they say "we'll take it".
I didn't have time to sift through the massive pile of wheels they had either. I have been trying to think of a way to get back there solo, but I really don't see that happening. Oh well, we do this vacation every year. Next year I will have more space/cash.
#2742
Lost
From old roads. Their site always has been a a little hard to navigate, and since it was updated, even harder.,,,,BD
1971 W-242733 through W-752146
#2744
Bikes: 90's Trek 850, 05 Giant Yukon, and many others that pass through my hands between the junk yard and a new owner
Thrift shops or junkyard?
Bornhere,
My local thrift shops don't seem to be stocking bikes anymore. Used to be that when I stopped at the Salvation Army, they had two racks full of bikes to chose from, and there were always a handful at Goodwill and St. Vincent's. Now none!
I loved your description of the pile o' bikes and the full van on vacation. Years back we were on vacation when we happened upon a rummage sale run by a flea-marketer who was going out of the business. No bikes, but the prices were too good to pass up. My children have fond(?) memories of riding home in the car perched on top of boxes of old dishes, between some old chairs.
In our town that pile o' bikes shows up at the local junkyard, especially in the spring when people are moving or cleaning their garage. On another post I have a photo of the pile on the weekend after Memorial Day. That's been my go-to source this summer. Picked up an American Arrow 10-speed (well-made, but in Belgium), a Bottechia mixte, both from the 70's, and a 60's or earlier BSA 3-speed. Then in July I found a Panasonic DX-5000, like new, in the same junkyard. What people will throw away! The junkyard owner has become a friend, so we have this arrangement where he tells me to just take the bike, and then I give him $10 or $20, which is a lot more than he can get for the scrap.
I love the adventure and love everyone's posts about their latest finds.
#2746
Bikes: Focus trash find commuter, Eddy Merckx Corsa, BP Stealth TT bike, Leader 720 TT bike, Boardman Comp Hybrid drop bar conversion, Quantec CX budget cyclocross build, SerottaNOS frameset ready to build up!
Quoted: 128 Post(s)
Liked 104 Times
Chibi, that Mixte looks a lovely find. Almost as if they cleaned the frame and crank before throwing it out! Bloody well done!
#2747
Bikes: 1989 Dahon Stainless Classic III Folder - 1990 Dahon Mariner Classic III Folder - 2005 Dahon Jetstream P8 Full Suspension Folder
Picked up three bikes yesterday.
An almost new Schwinn Jaquar 7-speed cruiser.
A Raleigh Sprite 10 speed with wicker basket.
A Raleigh Super Deluxe 3 speed
#2748
Bikes: Many. Ralieigh sports`s, Raleigh Superbe, sears Spaceliner, Firestone supercruisers, many vintage mountain bikes, random cruisers, and other unique bikes.
I found something strange today. I've actualy never seen this kind of bike before. A kid's 3 speed mountain bike. it's also in pretty good condition.
