Should I (2015) ?
#477
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12736 Post(s)
Liked 7,645 Times
36er only if it fits 33+, too.
#480
Quoted: 399 Post(s)
Liked 273 Times
My bar is 24mm OD at the ends...
I had found several reverse Tri/TT levers that fit on the outside of 22.4mm barends but was having trouble finding something to fit mine until I just ran across this...
https://="https://www.3tcycling.com/r...ke-levers-pro"
Looks like I would have to drill a hole in my bar for the cable to use these - which I prefer not to do, but unless anyone has any better suggestions soon...I may well give them a try.
Wish me luck...
Wish me luck...
Am back from a pretty long, generally successful test-ride and will be riding it like this for a bit, finally wearing some gloves I spent too much money on, while I waffle on what new bartape to get...
#482
Quoted: 399 Post(s)
Liked 273 Times
Good eye.
Edit...on 2nd thought I prolly should have posted this in the "Quick Question" thread where I originally asked for the advice but since a couple members told me there that barend levers couldn't work on a RB-002 I thought (perhaps incorrectly) this thread was more appropriate for the follow-up
Has anybody here successfully used bar-end/reverse/TT brake levers on a Nitto RB-002 handlebar?
Yes, I know that they specifically state that this bar is not suitable for a bar-end lever. But it is what I already own, and from riding hooded roadie levers so much lately, I got used to being on the "horns" & since i put my Nitto on, in a couple incidents even the slight delay/awkwardness in moving my hand to the cross-top lever has been...errr...disturbing.
I foolishly tried Tektro 4.1, which as to be expected did not work, so now am hunting some other solution. Any ideas here?
Thanx...
Thanx...
#484
Hey all. Havent been around these parts in a while and I just wanted to ask for some advice. Im currently looking at this bike. It fits me well and is pretty much exactly what I'm looking for. Im just curious if the $1600 CAD the seller is asking for is fair? I almost want to ask if he'll do $1300 since it seems pretty well ridden.
Thoughts?
Thanks!
Thoughts?
Thanks!
#485
Quoted: 1332 Post(s)
Liked 398 Times
Seems like you're mostly paying for the frame. Not something I would buy, but maybe a decent deal if you're into bespoke steel.
#486
1600 CAD is about 1200 USD. Doesn't seem like too much to pay for a one-of-a-kind frame built by hand in Columbus, Ohio out of Columbus steel with a 105 group set.
Just my 2 cents. Might be a better question for the road bike forum though.
#487
Quoted: 79 Post(s)
I don't think you are getting hosed at 1600 CAD - bike looks pretty good, though it's not quite my thing - but go ahead and offer 1300. What's the worst that can happen? He'll either say no or come back with a counteroffer.
#492
Bikes: Newish steel.
Quoted: 117 Post(s)
I have a ~1550 gram wheelset with BikeHubStore.com SuperLight hubs > 24/28 CX-Rays > H Plus Son Archetypes. It is currently on my Space Horse. I have a new MX Leader frame, and I am trying to decide what wheels to use for that build. Should I:
A. Move the existing wheelset to the MXL and buy a cheaper and more robust wheelset for the Space Horse
-or-
B. Keep the existing wheelset on the Space Horse and buy a new wheelset for the MXL.
Thinking A, but the new Campagnolo Zondas look awesome, and a new wheelset with nicer hubs (though the BHS hubs are solid) could be only a little more expensive than most options out there for a replacement Space Horse wheelset.
That said, a Shimano hub > Velocity A23 set is only $200 from Velomine.
-or-
#493
Quoted: 79 Post(s)
-or-
Thinking A, but the new Campagnolo Zondas look awesome, and a new wheelset with nicer hubs (though the BHS hubs are solid) is only a little more expensive than most options out there for a replacement Space Horse wheelset.
-or-
#494
Should I buy my friends 2013 caad8 105 +upgraded wheels https://cycling-passion.com/wp-conten...aad8-5-105.jpg for around $400-500 or save up and buy a much nicer steel frame that I really like? This is going to be my first geared bike by the way.
Another question, should I pay $100 for a new Thomson seatpost when I can get one for as low as $60(barely used) online? I ask because I'm going to the mash store soon to get some stuff and I figure I might as well get it there, but it looks like I'm going to spend close to $300 on a seatpost, rack, and cog.
#495
Liked 398 Times
Should I buy a Thomson Elite cut to 270mm for $34.99? Based on my saddle height, it would put the bottom of the post ~9cm below seatpost clamp, ~5cm below center of top-tube. Not sure if that would be flirting too much with minimum insertion.
#496
Calamari Marionette Ph.D
How much will be below the bottom of the top tube? And where do the seat stays join the seat tube?
#497
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
https://www.bikethomson.com/wp-conte...0/PostInst.pdf
Personally, I wouldn't use a Thomson seatpost, or any other seatpost for that matter, which had been cut by anyone outside of a machine shop who knows what he is doing.
#498
I cut all my posts off since they aren't expensive or collectable. I even cut my quill stems for the same reason. What could go wrong? As long as they are inserted far enough to not damage the frame or the fork, why have the excess?
