Can you run a USB rechargeable headlight off a backup battery?
Bikes: Surly Disc Trucker, 1977 Motobecane Super Mirage
Quoted: 34 Post(s)
I'm in the market for a new light, and it seems like most of the nice ones these days are USB rechargeable. My current light takes AAs. I like the fact that I can keep some spare batteries in the seat bag or stop at a convenience store and pick some up when I'm out and about at night and it dies. I will definitely be in that situation again at some point. I have a small USB backup battery for charging cell phones, so I thought maybe I could use it to run a USB light off of until I got home to give it a proper charge? Has anyone tried this?
Zoom zoom zoom zoom bonk
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35, Kona Rove, Trek Verve+2
Quoted: 551 Post(s)
Liked 722 Times
Some lights will run while they charge, some won't.
Quoted: 34 Post(s)
I have a NiteRider Mako 200 lumen light right now that is mostly enough, although sometimes not quite strong enough for riding on really dark unlit trails / streets. Those Cygolites look interesting. I wonder if it's possible to rig up some kind of external battery charger so I could charge the cartridges by themselves and swap them out every once in a while. I also wonder how long the cartridges hold a charge, because I know rechargeable AA batteries will not stay charged for very long at all if they are left sitting. Or maybe that's just a NIMH thing? I just checked Amazon and apparently they now make lithium ion rechargeable AA batteries with a built in USB head (!!!) Maybe I'll have to try those. I'm all about reducing battery waste, but I haven't been able to because the rechargeables I kept in my seat bag just died while they sat in there.
I checked and all the generic 18650 battery lights on Amazon look kinda sketchy quality to me...
Quoted: 34 Post(s)
& a dynamo hub is an interesting idea, although I guess I'd have to have a wheel built for that. Considering the Surly is my pampered baby and my main ride, it's not out of the question for me to get a wheel built. It certainly would come in handy for touring.
Quoted: 3462 Post(s)
Liked 1,468 Times
The last batch of Ladda batteries I got are fantastic. I am charging up a pair of Ladda batteries for my GPS in the photo while on a kayak trip.
LET'S ROLL
You'll have to decide if the convenience of a dyno is more important than total brightness:
don't have personal experience with any. Just using it as an example:
https://www.amazon.com/OVERMAL-6000L...bicycle+lights
One day: www.youtube.com/watch?v=20X43026ukY&list=UUHyRS8bRu6zPoymgKaIoDLA&index=1
Quoted: 7351 Post(s)
Liked 2,478 Times
Most people who try dynamo lights kick themselves for not getting them sooner. I'm one of them. I love not thinking about charging. I don't even switch the headlight off. I just ride. B&M headlights have shaped beams which ensure you're not blinding anyone, and they make good efficient use of the light.
Master Sarcaster
Bikes: 2018 Allez Sprint, 2016 Trek Crockett Canti
Quoted: 190 Post(s)
Charging while running is going to depend on the light... some will, some won't. My current Garmin UT800 will not.
As for the generic 18650 lights... I personally would avoid any of the ones with the spherical lens, or any of the really cheap ones.
That being said, I did use a NiteCore SRT7 for about a year and a half and found it to be a great light (used an SRT5 with a 14500 battery before that, but it was a little weak). It's not cheap, and it's a pretty tightly focused beam, so it works well on road at speed. One thing I specifically liked about the SRT series was that the output is infinitely adjustable between nearly nothing and full power. The downside is it's fairly heavy, so finding a good mount took a lot of trial and error. I finally settled on a mount off of ebay that allowed me to put it on a K-Edge style GoPro mount. The only reason I'm not still using it is because I wanted something smaller, lighter, rechargeable without removing the batteries, and had ANT+ connectivity to my Garmin.
Guy I mountain biked with did that with one of his lights were the built in battery had completely died, no longer charged. It "worked" but only on the low setting. The external battery couldn't pump out enough amperage to run the light at the higher settings by itself. I just use the sketchy Chinese lights and external batteries.
Liked 1,468 Times
PS, there are also lights that are made to run off a power pack. I'm not recommending this light,
But to run it off a powerbank, it would have worked great. It also would have worked great on a dynohub with a pass through cache battery to keep the power up while you slow down for hills or stop for stoplights.
I might bring it on a bike tour because on bike tours I almost never ride in the dark but occasionally need a light for tunnels, etc. And then I would only use it on a power bank for short periods of time. On bike tours I am almost always charging batteries off of my dynohub.
It is a symmetrical beam similar to a flashlight, not a low and wide beam like the better bike lights. But for $5 USD, you can't be too picky.
The one I got was like this one:
https://www.ebay.com/itm/New-Waterpr...t/192394993651
B&M Ixon Core can be charged while powered on.
bumm.de/en/products/akku-scheinwerfer/parent/180/produkt/180l.html?
Why not have both? A rechargeable USB light and the convenience of swappable batteries?
https://www.cateye.com/intl/products...ts/HL-EL471RC/
How do you know it can be powered on while charging? Cateye don't write anything about it, so i bet it isn't possible.
Quoted: 4560 Post(s)
Liked 2,802 Times
My 2016 version of the Light & Motion Urban 500 cannot be charged and run simultaneously from an external USB battery. No idea about the other L&M lights but it's likely all of the Urban series are the same, at least up to the 2016 models. You could email L&M to ask about this. Great lights otherwise.
My various to-be-seen lights can be charged and run simultaneously from external USB batteries:
Vivo Bike Illuminati (now available on Amazon under various other names)
Blackburn 2'Fer
Cygolite Hotshot 50
In fact, all of my other USB rechargeable devices can charge and run simultaneously, including my video camera, cell phones, etc. The L&M Urban 500 is the one exception.
I usually carry a Serfas SL-255 headlight as a backup. It runs on AA batteries, including NiMH or other rechargeables.
Relying on external USB batteries as a backup has limitations, primarily lack of weather resistance. On all my devices it requires opening or removing a weather seal to access the USB port. The batteries themselves aren't usually rated for wet weather. And the cords and plugs can be fiddly, snagging or eventually loosening and losing connection.
Since I ride at night more often than I'd expected after resuming cycling a few years ago I'm considering a dynamo setup for my hybrid used for casual rides and errands.
Blackburn 2'Fer
Cygolite Hotshot 50
Liked 2,478 Times
Powerbanks can be stored in frame bags, so that the only exposed part would be the connection on the light. Cables can be fixed to the frame or replaced with coiled cables.
Delock Produkte 83162 Delock Kabel USB 2.0-A Stecker > USB micro-B Stecker Spiralkabel
Delock Produkte 83249 Delock Kabel USB micro-B Verlängerung Stecker / Buchse Spiralkabel
Just tried and you can't (on mine at least). Point is, instead of carrying a USB backup battery to recharge your light as it runs, get a spare battery and when the first one drains, swap it for the fresh one.
Quoted: 539 Post(s)
Liked 44 Times
As people have said it varies, some let you charge while riding, some do not.
When I go mountain biking near dusk I need to have enough light to get out of the woods. So to cover all backup scenarios (including my main light getting broken) I bring a backup light. A Fenix BC21R is the smallest (including mount) light I was able to find at the time for $75:
https://www.amazon.com/EdisonBright-...dp/B01ACHGGQW/
In a german Forum a mamber did find out that the B&M Ixon Space can be charged while powered on too (like the Ixon Core).
https://www.bikeforums.net/commuting...ot-lumens.html
Bikes: 2003 Litespeed Vortex, 2017 All-City Mr. Pink, ~1997 Trek Multitrack 700
Quoted: 139 Post(s)
Liked 94 Times
The new Light & Motion Rando can be charged while using it. I've ridden in the dark several times with it and really like the light pattern.
https://www.lightandmotion.com/rando-500
The only thing you need to remember is if you want to charge it when you aren't planning to use it, you must use the orange ended USB cable that comes with it! Otherwise the light stays on. A little annoying when you are in a hotel room...
CliffordK
41
05-14-18 01:20 PM
thedonald
4
07-28-10 12:09 PM
