25 mm diameter seatpost
Old 09-11-20, 10:58 AM
Carbonated
Quoted: 55 Post(s)
Liked 4 Times in 4 Posts
I am having a difficult time finding a 25 mm diameter aluminum seat post for my Look KG281.
The Look original carbon seat post is old and starting slipping due to a poor 2 piece wedge shaped clamp.
I have tried anti slipping carbon paste but it still twists and moves vertically under force.
I am hoping an aluminum post will not be as smooth as the wedge clamps are very much so.
Thanks in advance..
Carbonated is offline
Old 09-11-20, 11:16 AM
redcon1
redcon1's Avatar
Bikes: Focus Arriba, Specialized Roubaix Expert, Bianchi Impulso Allroad
Quoted: 109 Post(s)
Liked 82 Times in 53 Posts
Campy Post
You're welcome
redcon1 is offline
Old 09-11-20, 11:45 AM
Litespud
Quoted: 645 Post(s)
Liked 797 Times in 446 Posts
Originally Posted by redcon1
Campy Post
You're welcome
three hundred for a seat post?
However, below that listing is a 25mm American Classic post for $54 - I had a couple of these BITD - reasonably light, good two-screw angle setting and robust. I ultimately replaced them with a Chorus Ti post and an otherwise-identical Daytona steel post, but that was because I was on a bling quest, not that there was anything wrong with the AC posts. My only concern is that the one listed might not be long enough for a sloping TT frame (couldn't see length listed).
But i do think that eBay is the OPs best friend here - barring obvious trauma, there's not much that can go wrong with an Al seat post.
Litespud is offline
Old 09-11-20, 01:12 PM
Germany_chris
I’m a little Surly
Germany_chris's Avatar
Quoted: 699 Post(s)
Liked 1,294 Times in 647 Posts
25's were never (drives cost) all that common (Frenchism) if you have a bike that needs one and you want to keep it I'd get a couple of them.
Germany_chris is offline
Old 09-11-20, 03:14 PM
Carbonated
Quoted: 55 Post(s)
25mm diameter seat post
Thanks in advance..
Old 09-11-20, 04:33 PM
curbtender
curbtender's Avatar
Quoted: 1612 Post(s)
Liked 2,594 Times in 1,225 Posts
Check post #3097
https://www.bikeforums.net/classic-v...t-5-a-104.html
curbtender is offline
Old 09-11-20, 04:41 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
I got Campagnolo 25.0 seat posts from the same importer I got my AlAn screwed & glued frame & fork, that used them , in the 80's
Kalloy makes low cost seatposts from 25.0 mm & larger in 0.2 mm increments in aluminum ,
their finish is not highly polished which, in this situation may be an advantage..
fietsbob is offline
Old 09-11-20, 04:44 PM
fietsbob
Bikes: 8
Moderator merge these 2 identical threads?
fietsbob is offline
Old 09-11-20, 04:50 PM
unterhausen
Randomhead
Liked 3,699 Times in 2,519 Posts
If you think a moderator should do something, there is a report button at the bottom of every post.
Merged two threads
unterhausen is offline
Old 09-11-20, 04:58 PM
fietsbob
Bikes: 8
the "Contact us " one ?
fietsbob is offline
Old 09-11-20, 06:26 PM
cyclist2000
cyclist2000's Avatar
Bikes: Masi, Giant TCR, Eisentraut (retired), Jamis Aurora Elite, Zullo, Cannondale, 84 & 93 Stumpjumpers, Waterford, Tern D8, Bianchi, Gunner Roadie, Serotta, Serotta Duette, was gifted a Diamond Back
Quoted: 305 Post(s)
Liked 2,038 Times in 604 Posts
No, at the bottom of your signature section there is a large round button with a red dot and ! in it. Hover over that and it says "report post"
cyclist2000 is offline
Old 09-11-20, 07:40 PM
Carbonated
Quoted: 55 Post(s)
Thanks everyone!
Appreciate the info...
