Freezing garage. Batteries OK?
Winter is coming to Illinois soon. Some folks ride their bikes year round but not us. Our E-Bikes will sit in the garage all Winter. It’s not a heated garage so it’s been known to spend 1-2 months in sub freezing weather. Are the batteries OK or do they need to be brought in the house?
Maybe a car battery heater, or some sort of insulated bag or fire-safe with the pack wrapped in some attic insulation and add some dessicant sachets to absorb moisture, and bring the battery pack inside to warm to room temperature for at least an hour before you plug in to charge.
cyclotourist
Quoted: 443 Post(s)
Liked 205 Times
Good question. Definitely do not charge the battery when the temperature is below about 5 C. Room temperature is better. From what I have read, Lithium batteries are less affected by cold than most other battery chemistries, and they wont freeze until about -40C. So you should be okay storing the battery in the garage as long as you warm it up before you charge it or use it. I still wouldn't do it, and I bring my battery inside the house for the winter. Batteries should be stored partially charged.
Likes For skookum:
Quoted: 883 Post(s)
Liked 824 Times
Nothing I've read states that cold temperatures (below 40 - 50 F) are benign to batteries. Not a problem in socal. Insulate well or store inside.
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
I've done this with a couple of batteries (at your latitude). They lasted 2-3 years. So, ya know - if you are OK with that. This year I'm keeping them inside in the winter.
(insulating something for a couple of months below freezing isn't gonna keep it warm guys).
Quoted: 668 Post(s)
Liked 529 Times
Thought I read something about never storing in the cold, but these guys say just make sure it is a certain level of charge (and to check it once a month)
https://electricbike.com/forum/forum...li-ion-battery
https://electricbike.com/forum/forum...-ion-batteries
An insulated bag will do nothing since the batteries don't develop internal heat when sitting still. A bag does help when riding.
cyclotourist
Quoted: 443 Post(s)
Liked 205 Times
Bikes: Time Scylon, Lynskey R350, Ritchey Breakaway, Ritchey Double Switchback, Lynskey Ridgeline, ICAN Fatbike
Quoted: 465 Post(s)
Liked 547 Times
Li polymer batteries may not all use the same polymer electrolyte secret sauce, so contact the manufacturer! All batteries loose capacity when they get cold, but the point of damage depends on the chemistry of the battery.
My electric mower manufacturer is OK down to -40C. I contacted Campagnolo and was told that for my version EPS battery, storage below -20C can cause damage. That may not be the limit for other generations of EPS. Same thing for your E-Assist device. Read the manual or contact the manufacturer.
Charging some Li polymer batteries when they are below a temperature point may damage them. Same thing for prolonged storage at cold temperatures. Similarly, exposure to temperatures above some limit (often 70 to 90C so very hot) will damage them.
https://www.electronicdesign.com/pow...iion-batteries
Quoted: 2604 Post(s)
Liked 1,933 Times
Years ago when I started my own tomato plants from seed, the garden places had a plug-in cord that kept seedlings warm even facing a cold window. About 10W worth of heating, IIRC. I wonder if you could wrap your batteries with something like that and leave it plugged in over the winter.
Quoted: 668 Post(s)
Liked 529 Times
But shouldn't be hard to build some type of insulated box/cooler and heat that with something equally simple. Don't have to keep it warm, just keep it from freezing. One could download a controller from an Arduino site or repurpose an aftermarket radiator fan controller from a car catalog.
Whatever you do I wouldn't wrap heat tape on a battery and would definitely include some sort of over temp cut off.
My $600 Luna battery is coming in the house with me. Let the wife sleep in the paint locker.
Quoted: 668 Post(s)
Liked 529 Times
This should be required reading for anyone with an ebike
https://electricbike.com/forum/forum...ter-repository
Liked 415 Times
Or for this thread:
- Do not store in temperature extremes of hot or cold. If you must, then cold is better than hot.
- VERY important: Unplug your battery from the controller and the charger even if not plugged to the wall outlet.
- Check the state of charger every month or so.
- IF you leave the battery go empty for too long the battery will likely need to be replaced (and that is not covered under any warranty.)
- When you are ready to use it, make sure it's at room temperature and slowly charge it fully!
cyclotourist
Quoted: 443 Post(s)
Liked 205 Times
Likes For alloo:
Quoted: 94 Post(s)
Liked 151 Times
Bosch has a battery guide with good tips that can be found here:
https://www.bosch-ebike.com/fileadmi...f?_=1597732627
Here are Bosch tips for optimum service life:
Randomhead
Liked 3,699 Times
It would be nice to have a storage charge option for batteries. RC chargers have that
Likes For unterhausen:
Yes, I put my R/C airplane and car batteries at “Storage level” if I won’t be using them for a few weeks. My lipos last a long time that way. I wish chargers for electric devices like bikes and snow blowers had a discharge feature like this.
Just an idea. If you are going to store the ebikes in a cold garage for long periods and not use the bikes this will help preserve the battery. ( best to store at less than a full charge ). Now if you plan on riding the bikes every day I would recommend bringing the battery inside the house. You do not want to charge the Li-ion cells at freezing temps . Now if it's too much trouble to remove the battery from the bike you can go out to CVS and buy a cheap heat pad , wrap it around the battery and set it on low. This should be enough to keep the battery at ambient room temp and allow for charging while in the garage if that is the way you want to go. Personally my ebike battery is very easy to remove so I'd just take it in the house every night. That said I store all my bikes inside the house where it is warm so condensation doesn't form on the metal parts and speed up any oxidation processes. Anyway, if you ride in freezing temps and want to recharge the battery, it would be best to let the battery acclimate to ambient room temp before recharging. ( give it at least 2hrs to warm up before charging. )
Quoted: 166 Post(s)
Liked 252 Times
Heck you good find a old steel igloo and use it as a fire box and add the heating pad.
