Go Back  Bike Forums > Bike Forums > BMX
Kush 2+ BB spindle stuck!
BMX Dirt, vert, flatland or street? Drop in the BMX forum to talk to other 20" riders around the world. What is the best BMX bicycle for you? Learn all about it here.
Old 08-10-23, 08:27 AM
Decalzone
Hi all, I'm new in here and looking for a bit of BMX help, if possible.
I am looking to remove the BB and spindle so i can do a respray. But the spindle is stuck inside of the 2 large bearings pressed into the shell.
Ive seem some vids that suggest you just hammer it out, I have tried this but its stuck fast so not sure if its the right thing to do!
Any help is appreciated.
Id submit phots but cant until ive added 10 posts......
Cheers
Decalzone is offline
Old 08-10-23, 08:49 AM
3speedslow
3speedslow's Avatar
Bikes: A few
Quoted: 1942 Post(s)
Liked 1,073 Times in 637 Posts
I have had the same situation with a Felt I was working on. Spindle could not be pulled out.
first make sure you give both sides some thin lube. Let it sit for a bit. Then bring out the soft hammer. Gentle taps with increasing force should do the job.
3speedslow is offline
Old 08-10-23, 08:52 AM
3speedslow
3speedslow's Avatar
Bikes: A few
Thinking for a second… make sure this spindle isn’t a one way exit model. Manufacturers descriptions should tell you.
Old 08-10-23, 08:54 AM
Decalzone
Ok chap, good advice. Cheers Ill check and hammer out
Many thanks
Martin
Old 09-25-23, 02:14 AM
Decalzone
aha the circlip
Cheers all. a bit of working through it and once all the grease and dirt was removed I found a circlip holding the non drive side bearing in place, once that was removed a light tap and all came out.
Problem solved. But this leads to another question the circlip has a rubber seal built it which is a bit perished any one know where i can locate one, I understand SALT is in-between UK distributors at the moment?
Cheers
