Rear rack recommendations, please
Thank you all for the responses. Didn't expect so many! Thank you to the guy who corrected me and said its a Bontrager item. Will read the rest at camp and reply if nedded.
Clark W. Griswold
Quoted: 4359 Post(s)
Liked 4,000 Times
I mean they are an excellent price to performance ratio they work really well and last a long long long time I cannot really say they are poor price in that situation. They are quite lightweight and hold a ton of weight and have good support behind them that you probably won't need. There are tons of racks but for touring but none I would trust as much as those beyond custom made racks but those would be more expensive.
Likes For veganbikes:
would one of you Americans give a realistic price for a tubus rack to this person, so they can have an idea of what you're all talking about. A rack of this value may not be something they would need on their bike, which could also have the risk of theft going on.
I'll leave it to the person in question to add a cost budget if they would like, but they may be surprised at folks suggesting a $200 bicycle rack.
Squeaky Wheel
I've been riding with a Tubus Airy since 2008. I have ridden over 80,000 miles with the rack attached to my bike and have hung at least one pannier on the rack for the majority of those miles (full-time bike commuter, part-time bike tourer). I've used the rack so often that my pannier has worn a groove in the titanium. The rack is unbelievably light and strong. It's also eye-watering expensive (you can find them for about $270). I would buy another one in a heatbeat.
Quoted: 3462 Post(s)
Liked 1,468 Times
Lowest price in USA, $150:
https://www.amazon.com/Tubus-LOGO-Re...dp/B007Y3D5LW/
Lowest price if imported into USA from a foreign seller was from BikeInn, they are very slow on shipping but I have bought from them before and would again, shipped from Europe, with shipping $120 (I have an account with them, so priced shipping cost to my location, Madison Wisc, cost may vary for shipping.)
https://www.tradeinn.com/bikeinn/en/...ck/136754135/p
Racktime as a brand and the Racktime Addit was also suggested in this thread, and I have two of those racks, so priced that too.
Lowest in USA, $67 but I did not check shipping price from this seller (Amazon has it for $80).
https://carsoncitybikeshop.com/bike-...e-addit-28-bk/
An Addit may be cheaper from Europe, I did not check. I own two Addit racks, I bought one of mine from Europe about six years ago.
Local retailers are likely more.
thanks tourist, I have my doubts if the person asking here is interested in a rear rack this expensive, they know what budget is realistic.
I hope they find a rack that will work suitably for their needs of living on a bike.
Mad bike riding scientist
Quoted: 6221 Post(s)
Liked 4,221 Times
I suggested the Tubus Logo EVO in post 2, so that is what I priced, used Google search for Tubus Logo EVO price.
Stuart Black
Stuart Black
Liked 4,221 Times
Not incorrect but wildly inflated.
It also doesn’t change the fact that the company is either lying through omission or purposefully. They are claiming that you can carry around a full sized adult on the rear rack which is obviously not true. I wouldn’t trust someone who makes that kind of claim.
Which makes their exaggeration all the worse. They could have a good product but they don’t need to overinflate its abilities.
That doesn't change the fact that it is structurally solid, a good value at its price, long lasting, and versatile.
It easily handles fully packed touring weights in multiple mounted configurations and doesn't noticeably twist or sway. That's really all that is needed here.
Stuart Black
Stuart Black
Liked 4,221 Times
MY Jannd "Expedition" has been good for many years
Description: The Expedition Rack is the rack of choice for cyclists who require exceptional durability and expanded size, measuring a full three inches longer than our standard rack. Built from 3/8" 6061 aluminum stock, the Expedition Rack is intended to be used primarily with our Large Mountain and Expedition Panniers where additional rear clearance may be needed for large loads. However, the Expedition is also a good choice when more room is needed for carting the evenings firewood or portaging large containers of water. The secret to this racks tremendous strength is a third support strut which angles back 21 degrees from the main load bearing strut. In addition, the rear support strut offers a 6" long section for attaching the lower portion of your panniers suspension system to enable precise positioning of your load. All stress points are double-welded.
Expedition Rear Rack
Product ID: FREXPDescription: The Expedition Rack is the rack of choice for cyclists who require exceptional durability and expanded size, measuring a full three inches longer than our standard rack. Built from 3/8" 6061 aluminum stock, the Expedition Rack is intended to be used primarily with our Large Mountain and Expedition Panniers where additional rear clearance may be needed for large loads. However, the Expedition is also a good choice when more room is needed for carting the evenings firewood or portaging large containers of water. The secret to this racks tremendous strength is a third support strut which angles back 21 degrees from the main load bearing strut. In addition, the rear support strut offers a 6" long section for attaching the lower portion of your panniers suspension system to enable precise positioning of your load. All stress points are double-welded.
I think this is also the reason the Axiom Journey rack is so solid and can hold a lot of weight is the second complete loop to the rear.
One other thing I consider when buying a rack is does it have a top panel on it. Since I don't run fenders, the top panel on the Journey, the Jannd, and that Bontrager keep mud, water and debris from splashing up on my bag that rides on top of the rack and makes sure no material likely slips down to rub on the tire.
The Vega, by the way, doesn’t have the extra leg on it and Tubus rates it at 55 lbs which is still a heathy weight rating for cargo carrying. Axiom rates their similar rack as being able to carry 110 lbs which is still in the small adult category and ridiculously high.
Stuart Black
Stuart Black
Liked 1,468 Times
$150 isn’t even close to the lowest price. Carson City has the Logo for $119. They have the Cargo Classic for $113. Amazon is about the worst place to go looking for good prices.
Again, that’s not the cheapest price. Rose Bikes has the Logo and a number of other Tubus racks for less than that. With shipping, the Logo would $101 from Rose.
Carson City sells other Racktime racks that would be worth considering for around $40 as well.
I was not shopping for myself, so I just used a google search for prices instead of doing a thorough search, you clearly spent more time on this than I did.
Likes For Tourist in MSN:
Quoted: 598 Post(s)
Liked 283 Times
Stuart, please don't misunderstand me, I'm not saying that the aluminum Axiom rack is as strong as the steel Tubus, I'm just saying that it's adequately strong for most people's needs, or at least has worked well for about 10 years now for myself and 2 others.
Likes For robow:
Sunshine
Quoted: 10969 Post(s)
Liked 7,495 Times
- Is the weight rating a static or dynamic load? What other parameters exist for their claimed max weight to apply? I genuinely dont know, and I dont think you know either. You should look into it, if you care this much.
- My oldest kid sat on my rack. It was a couple years ago, so she was 50kg or so. The rack still works.
- Ok cool- you dont trust someone who makes a claim that you dont fully understand. Thats fine. It has 0 bearing on what I posted and my follow up. Once again- the rack has shown to be a good mix of weight, reliability, stiffness, cost, capability, and design(flexible attaching to frame and secure mounting). Its Ok that you dont trust it and prefer a different rack.
You are a man of science. You are a man of binary processing where gray almost never exists. Go find details for that specific rack before you post again with more guesses that are disguised as fact.
I have read reviews and comments online that claim 80#, 100#, a kid, etc were all fine to carry while riding. Who knows for how long. Who knows with how many turns or bumps or whatever. You can go search these answers down and get back to us with actual details instead of guesses.
Liked 4,221 Times
- Ok cool- you dont trust someone who makes a claim that you dont fully understand. Thats fine. It has 0 bearing on what I posted and my follow up. Once again- the rack has shown to be a good mix of weight, reliability, stiffness, cost, capability, and design(flexible attaching to frame and secure mounting). It’s Ok that you dont trust it and prefer a different rack.
Stuart Black
Stuart Black
Sunshine
Liked 7,495 Times
170lb adult bouncing around on the back of the bike: when the passenger bounces left or right, the weight will momentarily shift to just one of the rack legs. When the bike hits a bump, the dynamic load is well above the static load. Both of these will happen at the same time during a ride. The longevity of the M5 bolts are in question even if the rack itself is made of magic diamond metal. It's not a reasonable weight rating for a rack.
Liked 4,221 Times
Stuart Black
Stuart Black
Liked 4,221 Times
That’s a valid point as well.
Stuart Black
Stuart Black
Bikes: Specialized Tarmac Expert, 2002 TREK 520, Schwinn Mesa WINTER BIKE, Huffy Rock Creek 29er, 1970s-era Ross ten speed. All my bikes are highly modified(except the Tarmac) yet functional, and generally look beat to ****. .
Quoted: 68 Post(s)
Liked 88 Times
Having just stumbled onto this thread, I'm still trying to figure out what's wrong with the OP's rack. Is that tape holding it together?
Likes For Thulsadoom:
Quoted: 598 Post(s)
Liked 283 Times
and I doubt that you will. I have owned both their racks and their panniers for many years and everything has been of very decent quality but, try and contact them with a simple question , good luck getting an answer, their customer service sucks
Sunshine
Liked 7,495 Times
You mean like these reviews? It’s also not up to me to show that the Axiom rack can hold a ridiculous amount of weight. It’s up to the party making that claim. Tubus (and their subsidiary Racktime) are up front about testing their products. I can find nothing similar from Axiom.
I had my fun with pushing back on the rack weight rating. In all seriousness, I wouldn't ever try to load 150# onto the rack because that would also likely screw up my wheel.
The rack has lasted years and carried panniers thousands of miles without issue. It has shown to be strong and stiff while being easy to mount to 3 different bikes. The price is great too.
I wouldn't trust it to handle 150#, but I wouldn't trust any rack to handle that weoght. And I wouldn't want to ride with that weight, so this is all quite academic and worthless in reality.
I salute you for your determination, no matter how meaningless it actually is.
Liked 4,221 Times
Wow, that had to have been a heck of a rabbit hole to go down. Strong work finding a couple of reviews from 13 and 14 years ago.
As I’ve said before, I suspect that someone got the unit wrong and Axiom just stuck with the claimed capacity even though it is a stupid claim. 70 lbs (which is a bit too high in my opinion) is perfectly adequate for a load limitation. If you are carrying more than that on a rear rack, you are doing something wrong anyway.
Stuart Black
Stuart Black
Liked 1,468 Times
Sunshine
Liked 7,495 Times
Originally Posted by cyccommute;23092173[color=#c0392b
]Well you seem to get my point.[/color] I don’t doubt that the rack is good enough for most applications. So why did Axiom inflate the weight rating to such stupidly high levels? No one…no one!…is going to carry that much of a load on the rear rack of a bicycle. Like I said above, it’s the equivalent of 2 bags of cement.
The horse was beaten to a pulp days ago- put the stick down. I havent been actually disagreeing with you, Ive just been poking you because you were hyperfocused on something that doesnt even matter to this thread.
