How many shims can I put under these handlebars?
I'd like to make the drops on this 56cm bike a little taller to hopefully take some pressure off my neck. How many shims could I safely fit?
Bikes: Bicycles? Yup.
Quoted: 482 Post(s)
Liked 1,593 Times
You need some width of spacer on top.So not much, say about half that top spacer. I'd grab that ~2mm, plus I'd look for stem with a steeper angle. The last bit of height could come from bars with about a cm of rise, but that's the most $, so last in line.
Quoted: 6199 Post(s)
Liked 4,816 Times
You might try looking for some riser drop bars to get you a little higher. You aren't going to raise that stem and handle bars by more than what's on top of the stem. If your steerer tube is steel, you might can put that spacer on top the stem underneath. But that isn't going to get you much useful height to make a difference. If that is a carbon steerer, then for sure you should leave a spacer on top and 2mm is about as small a spacer I've seen for steerer tubes.
Make sure you know how it all goes back together. That stem is what's holding the headset bearings in proper compression so there isn't any play. When you take that stem off, your fork might fall off if the bike is hung in work stand.
Is the stem change something a newbie could do? I have basic tools, used to fix/maintain my own motorcycles but I have no work stand.
Quoted: 1613 Post(s)
Liked 2,598 Times
Quoted: 482 Post(s)
Liked 1,593 Times
Liked 4,816 Times
Technically this is more a thread for the Bicycle Mechanics sub-forum.
While moving the bars higher will impact the fit of the cyclist, the actual moving of the spacers, stem and related things are mechanical issues.
Bikes: Paramount Track Bike, Colnago Super, Santana Tandems (1995 & 2007), Gary Fisher Piranha, Trek Wahoo, Bianchi Track Bike, a couple of Honda mountain bikes
Quoted: 58 Post(s)
Liked 31 Times
You might try an adjustable stem like this https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
The Ritchey brand has two bolts on the pivot which makes it a lot more secure (and quiet) than most of the other brands.
Liked 2,598 Times
Liked 4,816 Times
No, I'm saying this sub-forum is for discussion about how a person fits themselves to their bike. Not how you fit parts and components to your bike and adjust them.
While discussion about how high or low the bars should be for any person is a valid topic. The actual mechanics involved for changing the bar height is not.
Besides, theory requires some scientific facts. We don't always work off of facts. At best maybe a hypothesis.
Quoted: 514 Post(s)
Liked 451 Times
Before purchasing more stuff, try rotating your handlebar so you have a flat spot to place your hands. As it is now, your hands are probably sliding down the bar into the crook of the STI levers. The reach portion of a compact style bar is ideally perfectly horizontal but may be tilted slightly upward in front. You can also go for a horizontal bar while moving the STI levers upward a degree or two.
Liked 2,598 Times
Likes For curbtender:
no you do not need a spacer on top. depending on the how long the top bolt is, he might be able to go twice the size of the spacer on top placed under his stem. but that is about it
I'm new to cycling as an adult, but I was able to install a stem riser very easily with just some allen wrenches. I also added a shorter stem, and the addition of these two items did wonders for my back, arms, and palms (numbness). I did also learn that I need to engage my core more as well.
From the picture, I don't think it will make a difference, but I did this on a mountain bike.
