Stan's Notubes ZTR Alpha 340
Old 05-06-12, 03:52 PM
shokhead
Bikes: 2012 Trek Madone 6.2
LBS are building some ZTR Alpha 340 rims with 24/28 Wheelsmith 2.0/ 1.7/ 2.0mm black spokes with the red Chris King R45 hubs and black brass nipples.
They said at 200 pounds I shouldn't have any porblems. This is true, right?
shokhead is offline
Old 05-06-12, 04:14 PM
halfspeed
halfspeed's Avatar
Bikes: are better than yours.
Liked 3 Times in 3 Posts
If the wheel builder is competent and you don't abuse them, it's probably true.
Telemachus has, indeed, sneezed.
halfspeed is offline
Old 05-06-12, 04:33 PM
rruff
Liked 2 Times in 1 Post
I'd put 32 in the rear. And if you are kinda hard on equipment, then these aren't the right rims.
Do they build a lot of wheels? It takes a little bit of talent to do it well, and not many bike shop employees know how anymore.
rruff is offline
Old 05-06-12, 04:44 PM
shokhead
Guy worked at Velomax pre easton.
shokhead is offline
Old 05-06-12, 04:47 PM
halfspeed
halfspeed's Avatar
Are you planning on running them tubeless?
Old 05-06-12, 05:22 PM
plpete
I was thinking of building a set with those rims. I'm 30lbs lighter but heard quite a few stories of the wheel coming out of true and not being as stiff. Its one of the lightest ally rims out there and it takes a great builder to make them durable. I was thinking of doing 28 spokes in the rear at my weight. With such light wheel 32 might be a better idea for you unless you're easy on the wheels.
plpete is offline
Old 05-06-12, 05:45 PM
shokhead
Not right now!
shokhead is offline
Old 05-06-12, 08:14 PM
mechBgon
mechBgon's Avatar
Liked 6 Times in 5 Posts
+1. I weigh 155 pounds and went with 28/32, and if I were going to use these wheels as daily drivers, I'd keep a close eye on the brake tracks for wearout.
Regarding nipples, my first pick would be alloy DT ProLock. Why pick superlight rims and then add the weight back with brass nipples? It is not logical, Captain
mechBgon is offline
Old 05-18-12, 09:47 AM
shokhead
Weight difference is miniscule vs not worring about the nipples. BTW, what's the price difference between the DT ProLock and brass? Just ask'n. Also if weight is that big of a concern then at 155 24/28 would have been just fine imo of course.
shokhead is offline
Old 08-26-12, 11:35 AM
shokhead
The rear 340 just cracked so they are rebuilding with a 400 instead.
shokhead is offline
Old 08-26-12, 04:52 PM
shelbyfv
Expired Member
shelbyfv's Avatar
Quoted: 3674 Post(s)
Liked 5,437 Times in 2,763 Posts
Yes, a friend just cracked a rear 340. She might weigh as much as 110, soaked.
shelbyfv is offline
Old 08-26-12, 07:08 PM
mechBgon
mechBgon's Avatar
I've had dozens of customers crack ~500-gram Bontrager rims, to the point where they have their own special "check for cracks" line on our check-in procedure. Seen a fair number of cracked Open Pros too. Wheels, they're out to get us
mechBgon is offline
Old 04-03-16, 11:23 AM
shokhead
20,000 miles and all rims are well!
shokhead is offline
Old 04-03-16, 02:08 PM
jdjones
Bikes: Moots Vamoots CR
Quoted: 17 Post(s)
I've got that same setup (340s &R45s) but with Sapim spokes. I weigh 210 and have no problems.
jdjones is offline
dim
General Cycling Discussion
3
08-02-17 09:12 PM
dkyser
22
04-19-14 09:23 PM
pbd
15
10-11-11 09:17 AM
ropke
Road Cycling
20
08-25-10 02:25 PM
JayhawKen
Road Cycling
12
04-23-10 06:59 PM
