Seating on an Evox
Totally Bent
Hi
I recently bought an Evox (modified long wheelbase, (a so-called semi-recumbent)) bike. The Evox is also sold under the Quetzal and Mikado brands. This is along the same lines as a BikeE but the tubing is oval, not square and the bike has a typical crank/ring/bb arrangement. Overall, I find the bike to be good value for the money, but I have one concern. The seat is very uncomfortable. It is hard to detect just how uncomfortable until the bike is ridden for some distance. It is ok starting out, but by the time I’ve gone 10-12 km, my lower back and hips begins to ache. Had this been apparent at the time I was considering the purchase, I may have given the bike a pass.
The seat is a large, overly cushioned saddle style mounted on large springs. The brand printed on the seat is “Drifter.” It is attached using standard hardware to a seat post welded to the end of the seat boom. The bike is adjusted to the user by loosening a couple of Allen bolts and sliding the boom back or forward with respect to the pedals.
There is also a small seat back welded to the end of the boom. This is a padded oval cushion which supports the lumbar spine. When riding the bike, the springs allow the seat to rock from side to side which I suspect is a large part of the problem.
My question is: has anyone any experience riding this bike? Do they have the same seating problems? I was wondering if a BikeE seat may fit. If so, I am not certain that they are still available as I have heard that BikeE is no more. I may try a conventional seat on there and see how it fares. Any advice would be welcomed.
Thanks
Charles in London Ontario
Thanks
Senile Member
I don't like to be so blunt, but frankly if I were you, I'd sell the bike while it's new and still has resale value and get a cheap CLWB instead, with a proper riding position. I'm not sure it's worth the effort of upgrading it...
Totally Bent
Thanks for your well-reasoned response. I'll play with the seat for now as I feel I would lose too much selling it. Perhaps I can fashion a seat back for it. Maybe a more rigid seat would help. If worse comes to worse I'll reserve it for trips to the grocery store.
Cheers
Charles
Cheers
Charles
Totally Bent
Hey, I got my seating issues worked out! I was out for a 30km ride with no discomfort. It was all a matter of adjustment. Now the worst thing about the Evox is that they changed the name from Quetzal. The Resplendent Quetzal is a beautiful S.A. bird which is on the endangered species list. I have put up a photo of a mom and her chick as an avatar.
Cheers
Charles
Cheers
Charles
Senile Member
Luv2ridebent
Bikes: WhizWheelz 3.2, Quetzel Presario, Cannondale (upright)
I have a 'real' Quetzal recumbant, that darned thing has 120 gears. It'll take me a while to go through all of them. ) It has underseat steering that, frankly, scares the bejeebers outa me. <g>
Lynn
Lynn
Totally Bent
I heard that the earlier series had a wide gear range. The newer Quetzals such as the Azteca are undistinguishable from the Evox. Some of the up-market Quetzals have better components and I believe that there is an aluminum model available. Had I known that at the time I bought mine, I would have spent the few extra bucks to get a lighter bike. However, all things considered, the bike is working out ok. There is a third name these bikes sell under. It is Mikado as in the G&S Operetta. My bike even says on one of the tubes "designed by Mikado."
Cheers
Charles
Cheers
Charles
Cheers
Charles
Cheers
Charles
Diane
I almost picked up one of those for a project bike, back when Dick's was closing them out for <$99. That seat put me off, though. The bike itself would be OK for what it is, except for the seat. I suppose a seat could be fabricated, along with a method to mount it. I think what would work best would be a Bike-E type seat with a padded plywood base and a mesh back that reached maybe to the rider's shoulder blades. It would be very easy to spend more than the cost of the bike just to put a decent seat on it. I wonder if AD Carson over at recycledrecumbents would be willing to make something? He's been known to fabricate a solution or two.
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
Don't expect a response from bianchiriderlon as he hasn't posted on BF in more than a decade. (This Zombie Thread had been asleep for 12 years.) I have no experience with semi-recumbent bikes.
