Tight tires - Bead won't seat right
So we have all had problems putting some tires on the rim where the tire is a tad small or the rim is a bit big and they can be a pain to mount. Well, what do you you do after you mount them and the tire bead won't seat properly? I have a brand new and supple set of Continental Ultra Sport 27 x 1 1/8" tires on set of Ukai 27 x 1 1/8" rims. Rims are dead straight. Tires were difficult to mount and when inflated the lip of the bead at one point on the tire won't sit properly and is too low...meaning it won't expand far enough for the tire bead to properly seat itself. I have tried releasing most of the air and working the tire bead into the channel all the way around and slowly adding air while doing this. Same thing. So the end result is a low spot on the circumference. What to do?
Quoted: 2026 Post(s)
Liked 1,096 Times
A low spot implies a high spot 180º away. Is the valve area of the tube seated in the tire properly? Reduce the pressure and push in on the valve stem to be sure.
My son also had a tire that he couldn't get to seat properly and that was the problem.
Quoted: 887 Post(s)
Liked 335 Times
Are the rims rated for high pressure?
Quoted: 2483 Post(s)
Liked 2,955 Times
Really Old Senior Member
The valve stem area is fine and the tire is seated well there. Tires are rated for 102 PSI. The rims did not have any damage or flat spots on the lip....they look like new. Like what was said, I was going to let them sit at full pressure for a while, maybe put them out in the sun and try again with the soapy water. Thank you.
Wow, fixed already. That soapy water was magic! Tire is on and properly seated and as a bonus....my hands are clean!
The Infractionator
Bikes: Classic road bikes: 1986 Cannondale, 1978 Trek
Quoted: 875 Post(s)
I've found that bouncing a nearly fully-inflated tire sometimes makes it seat.
Quoted: 4208 Post(s)
Liked 3,874 Times
No mention of tire seating pliers? Andy
