Components compatibility database
Quoted: 257 Post(s)
Liked 70 Times
Does anyone know if there is website where you can plug in parts and it tells you if it is compatible or how to make the combos compatible?
For example different speeds compatibility for Shimano or Shimano vs. Campy vs. SRAM. There's so much info out there with many not so accurate and I like a simple answer than reading a long response which may or may not answer my question.
Thanks all for the replies.
Sunshine
Quoted: 10947 Post(s)
Liked 7,474 Times
Better yet since the search function is bad and the question has most likely already been asked many times, just google the compatibility question. Results from here and elsewhere will be right at your fingertips.
For a second there Thought you might be one of the computer code writers and have chosen to create one..
