Brakes
Brakes
Good afternoon
I have just got my mtb out after long time and having brake issue the front brake is nowhere near as strong as rear is this normal using disc brakes
Quoted: 4195 Post(s)
Liked 3,837 Times
No, generally most feel that the front brake is the more powerful one (and at the limit of going over the bars it becomes the only brake. Does the lever pull feel solid and remain the same after repeated pulls? The two first possibilities are the pads are contaminated with something that reduces their friction (or are badly glazed) or if the brakes are hydraulic there's air in the line. Andy
AndrewRStewart
AndrewRStewart
Brakes
I have removed the pads and sanded and cleaned disc but still same
When I pull leave it doesn't go solid but the piston move ??
Quoted: 2493 Post(s)
Liked 738 Times
What kind of disc brakes are these? Brand? Model? I think it is now time to check the brakes themselves and it sounds to me like you may want to take it to the shop to have it done right by people who have done it hundreds of times.
Quoted: 1438 Post(s)
Liked 1,092 Times
It sounds as if the brake needs to be bled, to start, but specific tools are needed and since it is a safety item someone who is skilled should probably do the work as Leisesturm suggests..
worldtraveller
Bicycle Mechanics
2
07-18-12 11:09 PM
worldtraveller
Bicycle Mechanics
0
07-13-12 04:28 AM
