Headset install: Fork crown race - damaged crown shoulder
I am not sure how to go about this headset install - see images below. The crown race shoulder is damaged. The quarter of the shoulder is still intact, but the rest is only partially there, and small section is missing completely. The crown race will be held on by mostly the little shoulder left at the bottom - not loose, but I am not sure how long it will last.
I am thinking epoxy for reinforcement. Alternatively, remove the damaged area and insert a shim? Please let me know if you have any other suggestions. Thanks!
The frame is Bridgestone Radac 2000, 1987.
Quoted: 18375 Post(s)
Liked 4,510 Times
Is your crown race 27.0 or 26.4?
Too bad 25.4mm crown races don't seem to have been made.
I'm not a big fan of JB Weld on bikes, but this might be one place I'd make an exception, at least to try it out. Put on the JB weld (clean, loose stuff removed), then cut the fork crown down to 26.4mm. There should be tools to do it.
Liked 4,510 Times
You can probably shape it by hand. However, it does need to be a good tight fit.
Yes, any bicycle specific reamers and cutters are expensive, but as @trailangel mentioned, a bike shop should be able to help you out. Find a good, little older shop. Explain what you have planned before you start.
SE Wis
Quoted: 2746 Post(s)
Liked 3,394 Times
https://www.jbweld.com/collections/m...xy-putty-stick
I've also reinforced JB weld with bread tie wire, steel wool, etc.
Quoted: 4204 Post(s)
Liked 3,861 Times
If this fork was brought in by a customer I would suggest they don't continue to ride it any longer. This is a bonded together AL crown (and blades) to a steel steerer. The crown race "shoulder" has cracked and broken off partially around the steerer. When AL starts to crack wise ones take note
Sure one could make a claim that the broken off portion is only supporting the crown race. As in a non structural failure. Still I'd hate to have to say under oath that I knew the fork had cracked yet I felt it was going to be safe after "repairing" using rather unconventional methods.
I do wonder what was the cause of the broken "shoulder". Was it riding with a loose headset? Was it from some impact long before? Was it from poor initial fitting/bonding? Without this backround I don't see how I can suggest using this fork to keep one's face off the pavement.
Your opinion may differ. Andy
AndrewRStewart
AndrewRStewart
Quoted: 6193 Post(s)
Liked 4,809 Times
How much is a new fork going to cost compared to the amount of time you are going to put into this one?
I agree with Andrew, I would not ride this fork. To me, it appears that the bond of the steerer tube to the crown either was not that good to begin with or just separated. This suggests to me, that the remainder could separate. I'd get a new fork (or bike) depending on what you want to spend.
Liked 4,510 Times
Hmmm...
Reading about the Lambert/Viscount forks.
Lambert & Viscount bikes: About those Lambert / Viscount Death Forks
The issue they apparently had was that the steel steer tube ended at the top of the crown, and was simply pinned to a fork extension.
The "Type 3" fork had the steer tube that extended through the crown, and the brake bolt went through it.
The OP's fork is probably a different brand, but hopefully has the full length steer tube similar to the later generations of Lambert forks (and many composite forks today).
Whether one wishes to ride it or not would be personal preference. It would be worth reviewing information on forks & bonded joints.
Half way there
Quoted: 986 Post(s)
Liked 880 Times
I agree with the above recommendations to consider a replacement. Is the fit of the steerer tube solid? If not, then you should replace without question. If you think the steerer/crown joint is good you will want to examine the crown carefully for any signs of cracking. Be cautious.
To address your initial question about fitting a crown race: Not much you can do but keep what metal is there and use epoxy to fill in.
Quoted: 1438 Post(s)
Liked 1,092 Times
People put too much faith in epoxies IMO. JB Weld is NOT as strong as a weld by a huge factor.
Likes For dsbrantjr:
Liked 4,510 Times
Plus the possible medical/dental bills if it fails; the potential for catastrophic failure (and I don't perceive any "minor" or "recoverable" failure mode on a fork, you are going down hard) is too great.
Perhaps one could make a washer/ring that would do the same thing. Cut off all the aluminum, all the way around. Then heat up and press on a brass ring. Get a shop with the seat tool to finish it to size.
Liked 4,510 Times
There are a few used bonded aluminum forks available.
But, for new forks, is anybody making quality aluminum road forks? Perhaps a couple of aluminum MTB or Cross forks.
1"? Fewer still.
So, that leaves us with Carbon Fiber.
1"? Fewer still.
Friendship is Magic
Bikes: old ones
Quoted: 26418 Post(s)
Liked 10,380 Times
...just looking at the pictures, I agree with the "I would not ride that" crowd. You can see a little rust on the steerer where the crown has flaked away. You can't actually see the hidden surfaces of the bond between the two parts, but it's not worth the risks involved when you can buy a pretty decent new fork on Amazon or Ebay for less than a hunnerrt bucks. Your issue is not whether you can form up a seat for the crown race, but what's going on where you can't visualize the surfaces between dissimilar metals..
Friendship is Magic
Bikes: old ones
Liked 10,380 Times
...I don't think anyone is suggesting an aluminum replacement fork, Clifford. I know I'm not.
Additional images
As far as I can tell, there is no damage to fork crown. The steer tube does go all the way to the bottom of fork crown - @CliffordK. The "shoulder" or seat for crown race is aluminum and appear to be a separate piece inserted into the fork crown but not sure how far it goes down. - like a shim between steel tube and aluminum fork crown.
I cleaned it up for close up images:
Friendship is Magic
Bikes: old ones
Liked 10,380 Times
Vitus, a tube manufacturer of long standing, introduced their 979 aluminum frameset in about
1978. We imported ten in the spring of 1979 in the Mercier Team Cyclamen color because those
were the first available. Yes, ten pink anodized aluminum French frames, no kidding. At $300
they sold quickly.
That product became quite popular in the eighties and Michael Fraysse interjected himself as the
official agent/importer at one time (somewhere in New Jersey). He was a USCF official then.
The Vitus 979 was a clearly superior design to the Fabo-Alan, which had until then been the only
broadly successful aluminum race bike.( Cannondale had not yet come into their own) Some
improvements were added to make the Bridgestone Radac, the Peugeot Comete and the SR-Sakae
Prism/Suntour Litage but the groundwork for that type of construction was all Vitus.
It's a fine bike. Inspect closely in a good light, especially the fork, before riding vintage
aluminum machines.
they sold quickly.
aluminum machines.
...people start threads here all the time about the various aluminum frames of this time period that all shared a similar construction method. Generally, the advice ranges from " a little JB Weld and that will buff up nicely" to "you're gonna hurt yourself and probably die".
It's a problematic frame construction method, that was doubtless never intended to live forever.
It's your bike, and your oral and maxillary facial reconstruction procedure if you guess wrong. While "original" restoration is an admirable goal, sometimes functional modification is a better compromise if you intend to ride something. A chrome finish Tange steel fork would probably not look terribly out of place, and would definitely have a better percentage chance of going the distance. Fork and head tube failures can be catastrophic in nature. Most of us are fortunate enough not to experience them.
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
Hold on now. First, let's recognize that so-ichiro has a very interesting bike. Grant Peterson designed. I'm not an aluminum bike guy, but the Radac were and are gorgeous.
It seems to me that the fork has a couple issues. The first is that a thin spacer/bushing has worn out. The second is that the bearing face (that is, the top of the crown) has been worn, possibly unevenly. If this were my bike and I had access to a machine shop I'd have the bushing turned off (taking care to take nothing at all from the actual steer tube. Then I'd face the top of the fork crown very lightly, leaving no groove anywhere. At this point, inspect and ask how confident are you that the thing is ok. I mean, it's an Al tube bonded into an Al fork in the first place, right (correct me if I'm wrong)? So if the tube itself is ok, maybe there's hope.
At that point, you might be able to find or fabricate an Al washer and an Al bushing to match the original. Light interference fit (that, you make the hole in the bushing smaller than the tube and use a press or temperature to fit it on). Or a slightly looser fit with epoxy to seat the washer against the fork and the bushing on the tube.
I probably wouldn't use epoxy to make up the bushing.
I'd inspect a bit more before giving up. But remember, your decision, your teeth. I've broken my jaw going over the bars on a bike, and its no fun.
Good luck!
Good luck!
Friendship is Magic
Bikes: old ones
Liked 10,380 Times
...do you happen to know how the fork crown and steerer are bonded ? If it's an aluminum steerer, I don't know where the rust in the first couple of photos is coming from.
Liked 3,861 Times
IMO the steerer is steel. The very dark/black edges of the crown/steerer "bond" has me suspect. As in a lack of bonding agent applied, none squeezed out. Of course what I think I see is exactly what really is Andy
AndrewRStewart
AndrewRStewart
Good luck!
Good luck!
@3alarmer, the steerer tube is steel.
Liked 4,510 Times
The Viscount page seemed to indicate heating and shrinking to form a bond, which I would assume precludes using epoxy.
This is a different company, of course, but I wonder if there would be a similar shrink/press bond.
A couple of years ago there was a company that specialized in restoring Vitus frames. Ahhh, I think I found them.
Untitled Document
Anyway, perhaps they would be worth contacting, and might have more specific information about the fork, and perhaps even setup for a repair.
Are you looking at the bottom side of the crown? No obvious glue there, whereas I see some gray glue-ish thing on crown/blade junctions but that is aluminum to aluminum. On top side of the fork crown, some aluminum shoulder piece came off - no glue underneath, but whatever left there is still stuck pretty good.
