A GOOD commuter Road Tire?
Dancing on the Pedals
I just went for a test ride (12 miles) to my work place, just testing my new
700x25C Vittoria Courier TT25 Kevlar 3D Compound tires. Never made it, I had to turn back after 3.5 miles when going dowm hill at "warp" speed - got a flat on the rear one, it was enough that the rear tire hit a small elevated road crack to
go down flat. These tires proved not suitable at all for commuting, especially here in Northern Jersey where there are lot of rough road imperfections on the side of the roads. Thank goodness I didn't use them on weekdays (real commuting time).
What tires are GOOD (in the 700x25C and/or 700x28C size) for commuting??? Enough to take the roughness and imperfection on most roads?
What's your experience folks? Although I'd prefer in the 700x25C size???
Corsaire
Corsaire
From your description sounds like you got a pinch flat, which can be caused by not having enough air in the tire. Common consensus for the most flat proof is normaly the specialized armadillo tires, but it will protect you from thorns.. glass etc in the road..
Before going out I inflated my tires to 100PSI with my
new JoeBlow, the recommended pressure. The tires were tightly inflated.
The rubber on this tires are buttery soft, that was did it.
How about the Continental Ultragator Skin?
which I hear so much about
Corsaire
Corsaire
I insist on Kevlar lined tires. Particularily on commuter bikes where I hope I can demand reliability.
My touring bike takes 35mm. I can find only Performance brand Touring tires that are Kevlar lined..I think they are pretty good tires. Anyone use 35 mm. Kevlar lined touring tires...Any recommendations.
A Heart Needs a Home
RichC
Training: 2002 Fuji Roubaix Pro (105 triple)
Commuting/Daytripping: 2001 Airborne Carpe Diem (Ultegra/XTR, touring wheels)
Commuting/Touring: 2000 Novara Randonee (Sora/Tiagra/LX, fenders, lights)
Rich.. Again are all those tires you mentioned in 35 mm? Not sure a rim for a 35 mm. tire will accomodate a smaller sized tire?
Corsaire
Corsaire
You might also want to look into the Rivendell Ruffy Tuffy or Roll-y Pol-y tires, which are very highly regarded. https://www.rivendellbicycles.com/html/parts.html
My own commuters run wider tires -- 700x32 -- and so my personal experience probably isn't directly transferable to your situation.
However, I agree with the assessment that you had what sounds like a pinch flat. You can prevent them only by increasing tire pressure or going to a bigger tire, if one will clear your brakes and frame.
RichC
RichC
I purchased my new commuter road bike at the beginning of April this year. Continental Top Touring 2000 tires 700 x 28c were spec'd and were installed. To date I have put on 4,200 kms on these tires. And have had no problem except for the one flat which was in June after two and a half months of riding. I cycle over sections of rough roads to and from work plus I've gone over broken glass, run over small stones and branches, etc. My commute is 22km one way.
It is very important for me not to have any downtime on my commute, especially to work. So having good tires is very important. Since I started cycle commuting in June 2001, I have had numerous flats on the two types of bikes I used before my current model - one was a MTB converted to commuting with slimmer tires and the other was a twenty year old road bike. I normally spent no more than $ 15 CDN per tire. I experienced on average 3 to 5 flats per month. I don't know what the TT 2000's cost (they came with the bike and I didn't get a cost breakdown of each component) but they are worth the price.
I highly recommend the Continental TT 2000's and I will replace only with the same.
Life is good
Bikes: 2018 Lynskey Helix Pro
Quoted: 522 Post(s)
Liked 10 Times
I have Continental Grand Prix 3000 on my road bike. Average mileage between flats ~2000 miles.
I have Vittoria Rubino Intrepid PRB Kevlar 3D Compound on my commuter. Haven't had a flat yet.
700x25 size available in both tires.
I checked the 04 All Conditions Armadillo 700x25C, looks strong and good.
The Nimbus Armadillo looks strong also, but only 28C
How about performance on these tires?
has anybody notice improved performance as well?
besides the flat protection feature?
Corsaire
Corsaire
Quoted: 12184 Post(s)
Liked 1,492 Times
Hi,
take a look at the Rivendell Ruffy Tuffy.
It is very rugged without weighing a ton.
https://rivendellbicycles.com/webalog...bes/10043.html
You know, if it WAS a pinch flat, you could have had a defective tube.
I've got 2002 Specialized Armadillos on my commuter. It's a mid-90s heavy steel road bike, and the heavy tires roll VERY smoothly when I'm going. The older Armadillos had a bad shoulder corner that impeded fast cornering, but the 2004 tires have a redesigned tread/shoulder that's much better. If the Specialized Rep ever will give my LBS 700X23s, I'll have a new set. The rated pressure for the Armadillos is 125, and I keep them there. The ride is supposed to be rougher, but with my heavy frame I don't notice it.
I use the Continental Gatorskins on my Lemond Zurich. They have a Kevlar belt, and roll very nicely.
It WAS a pinched flat caused by a strong blow/impact of the rear tire by going down hill at high speed. The rear tire hit strongly a little part of raised pavement. (roughed out road side) The Vittoria tire is ok, but the tube pretty much blew inside. It's not the first time I ride this road, it's my commuting route.
I had switched from Specialized Nimbus EX, these tires took very well all this road imperfections. But I changed to Vittoria just to gain for speed and lightness, only to realized I had sacrificed strenght and durability.
That's why I'm looking for a strong, dependable, highly puncture resistance tire, enought to take a blow over an imperfect road.
The All Condition Armadillo looks like the ticket so far @ 700x25C, hopefully it can take it.
Corsaire
Corsaire
Corsaire
Corsaire
RichC
Bikes: 2012 Schwinn Slicker, 2011 Trek Sawyer, 2014 Kona Unit
After having 4 flats in 200 miles along my route, I put on Performance Forte Kevlars in 700x23 size about 800 miles ago. I've had one flat since then. They run about $22.
Location: The Alta Loma area of Rancho Cucamonga. About 45 miles east of Los Angeles, California. Uphill, downhill and across hill riding; not too level!
Corsaire
Corsaire
8speed DinoSORAs
I have just invested in a set of Continental Gator/Dura skin tires to compare against the Hutchinson Excel Kevlar types that have been a mainstay for a while. I run 700x23. The Hutch's have good puncture resistance but are prone to failure of the fabric at the sidewall, close to the bead, always on the rear tire.
The Conti's seem to ride better, although I managed to flat them first day out. I think this was exceptional bad luck though - I pulled out a 3/4 in thorn from the very edge of the tread that was like a hypodermic needle.
I hope they will last better than the Hutchinsons - I like them very much so far.
Cheers,
Ed
Cheers,
Ed
Get a bicycle. You will certainly not regret it, if you live.
Liked 1,492 Times
Hi,
the Gatorskins look really tough. I bought a pair, went for one ride, and had my dealer swap them out for something else. They rode like a truck. The problem is the belt goes up the sidewall, so it doesn't absorb as much shock as a regular tire would. I think the Rivendell Ruffy Tuffy would make a good tire for commuting. My wife has been having good luck with her 25c Fortezzas , and the ride quality is excellent. I don't run them at high pressure. I put in just a few more pounds
than is neccesary to let the tire roll on the flat without the sides bulging. This gives a very nice ride qulaity; with the Fortezza it's especially nice.
The Flying Scot
Location: North Queensferry Scotland and London (and France)
Bikes: Custom (Colin Laing) 531c fast tourer/audax, 1964 Flying Scot Continental, 1995 Cinelli Supercorsa, Holdsworth Mistral single speed, Dahon Speed 6 (folder), Micmo Sirocco and a few more
I've got about 4000 miles on my Conti TT2000's (700x28)
Only one puncture and that was a huge thorn.
plus je vois les hommes, plus j'admire les chiens
1985 Sandy Gilchrist-Colin Laing built 531c Audax/fast tourer.
1964 Flying Scot Continental (531)
1995 Cinelli Supercorsa (Columbus SLX)
1980s Holdsworth Mistral fixed (531)
2005 Dahon Speed 6 (folder)
(YES I LIKE STEEL)
2008 Viking Saratoga tandem
2008 Micmo Sirocco Hybrid (aluminium!)
2012 BTwin Rockrider 8.1
(YES I LIKE STEEL)
Does anybody know HOW the Armadillos ride?
Does it roll easily, smooth or is it rough??
Corsaire
Corsaire
I have 700X23 2003 Armadillos. They have a stiff sidewall. I keep them at the max, 125 psi. They roll very, very smoothly, but transmit a little more vibration than other tires I've used. That's on an older steel bike that weieghs about 25 pounds.
I guess it's a trade off, a mix of smoothness with some road vibration....hey! it's not a perfect world I guess...
I hear people raving about these RUFFY TUFFY tires , what gives I wonder....?
Corsaire
Corsaire
Got it! made a decision:
I'm getting the All Condition Armadillo 700x25C for the rear tire and the Ultra Gatorskin for the front, also @ 700x25C. I hope this combo will give me the best of both world, given that all my experience with flats/pinch or puncture have always been on the REAR tire.
What about it?
Corsaire
What about it?
Corsaire
Interesting decision.
I while ago I replaced my TT2K's (the rear was worn out) with Pasela TG's. The TG is a much lighter, thin-sidewall, kevlar-belted and -beaded foldable tire.
I immediately started getting rear flats. So I put the old front TT2K on the rear, and left a TG on the front. This combo is working quite well, and the lighter front tire is a noticeable improvement.
Good luck with your plan!
RichC
RichC
