Any drawbacks with a women-style "step-through" frame?
#76
Count Orlok Member
+1. Pulled a muscle in my back trying to get my leg over the top bar without kicking my kid. That's why I'd like a mixte. Can't find a 23" one, though.
#77
Bikes: 2010 Davinci JointVenture, 1994 Specialized Epic Comp, 2007 Steelhead custom road bike, Surly CrossCheck, 1999 Kona MuniMula MtB, Wife:Civia commuter, Steelhead custom road, 1993 Marin Mtb Extracycle , Kids:Trek tag-along, Jet20, Trek830
Bikes: Reynolds 531P road bike, Rocky Mountain Metropolis, Rocky Mountain Sherpa 10, Look 566
#79
barkin' at the moon
Bikes: bianchi MTB,several old schwinns
I used an old women's frame middleweight cruiser as a paper route bike.It was easy just to lay it down and put the paper where the customer wanted it them just step over it,grab it and go.Alot easier than a"boy's" bike when you had to repeat the drill 30 times a day.Beat it hard and never had a problem.sold it to the kid who took over the route.I think he rode it for a few more years.
#80
Did you read the part that I said that the inherent loss of stiffness in a step-through frame was unimportant? I've said three separate times in this thread that there's nothing wrong with step-through bikes and that I think that riding them is a fantastic idea. But, while the ability to mount a bike without kicking your child in the head makes a step-through the best choice for most people carry children in child seats, you are fooling yourself if you think it's not going to have a greater negative effect on the handling than it would on a similarly built full-diamond frame. What I said you were wrong about was the claim that step-through frames are not inherently less stiff than full-diamond frames. They absolutely are. And stiffer bikes handle better with heavy loads (and yes, children count as "heavy loads"), full stop. The question is whether you should care. The answer, under most circumstances is "probably not." This is a matter that can be compensated with by overbuilding anyway, so chances are that your ladies' bike is comparable in stiffness to similarly-designed mens' bikes.
#81
Real Men Ride Ordinaries
Quoted: 17 Post(s)
how is this thread still going with such vitriol? For a given stiffness, a step through frame will be slightly heavier. That's it.
The main thing I dislike about mixtes (only mixtes, other step throughs don't have this problem) is you have two choices of brakes (if you want to do it right) you can either mount a pair of Mafac centerpulls, or spring for a pair of Pauls. A mixte doesn't look right without the rear brake cable coming down between the two top tubes, attached to the straddle wire of a nice centerpull brake mounted on the middle stay. V-O almost has it
#82
Count Orlok Member
The new V-O Mixte is supposed to come in larger size, too.
What I meant to say is I can't find a 23" mixte on my local Craigslist (I'm on a budget).
#83
Back Wheel Carries More Weight
I entered this thread looking for the answer to this. No one seems to have mentioned it. Step-throughs put massively more weight on the back wheel, its not even close. Its like 3 to 1. I kept breaking spokes on my back wheel but never my front so I got curious and weighed each wheel with me sitting on the bike. I tried posting a picture of each wheel but I guess this forum wont let me unless I make 10 posts. Its 183 pounds on the back wheel and 65 pounds on the front.
I did not measure a triangular frame but I would assume that front bar would help it spread out more evenly. As such, a triangular frame would likely have better weight distribution and reliability as far as spoke breakage goes.
#84
Quoted: 7348 Post(s)
Liked 2,461 Times
#85
Quoted: 5 Post(s)
I'm a guy. I like my saddle high for good leg extension, and I sit more upright for comfort. I usually have to buy aftermarket seat posts for my men's bikes, and the handlebars are good. On the few women's bikes I've had, the stock seat post raised high enough but I had to change handlebars cause the stock ones felt like they were in my lap, even rotated forward.
#86
Quoted: 5 Post(s)
Oh, and all the comments in here about women's frames being inherently cheaper and of poorer quality than men's bikes is patently nonsense .The one I have now is a Trek hybrid, and it is a SWEET ride.
#87
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
#88
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,103 Times
A lot of Trek FX models are available as step-through, up through the FX 3. The women's diamond models are distinctly different geometry than the men's but the step-through are the same as the men's. Or at least they were a few years ago when I was shopping for a tug and kid seat rig.
Genesis 49:16-17
Genesis 49:16-17
#89
Bikes: 1969 Peugeot PX10, 1992 Della Santa, Linus Roadster 8, Biria 700C ST-8
Quoted: 794 Post(s)
Liked 508 Times
It is a pretty minimal drawback but real. The first day I rode my new Biria Easy Boarding 8 bike I stopped and the thing flopped right over. I was so used to the top tube hitting the inside of my thigh that I didn’t even think about it. Since my feet were in toe clips I think it made for a pretty comical scene. But I really like that bike. Just hop on and go, no excuses. And I even saw another one yesterday! He said he’d bought it in Florida.
#90
Disco Infiltrator
Liked 2,103 Times
#91
I've only found them to be more comfortable and easier to ride. I always usta end up with men's bikes for some reason and since I switched I could never go back!
#92
Quoted: 2236 Post(s)
Liked 1,314 Times
I have had a few "step-thru". There were two that I would constant bang my knee into the frame while stepping-thru.
My knee got really bruised up after a while.
I find stepping-thru to be very awekward way to get on a bike.
I find it much efficient and graceful, to swing a leg over the saddle instead.
Unless there's some medical reason why you cannot swing a leg that high...I would avoid "step-thru".
Or I guess if you wear skirts frequently...but I don't see women rider wear skirt .
This is my daily summer/winter commuter. 91 or 92 Trek Multi Track. Hi-Ten but surprisingly light. The low geared triple is great for hills and there's wheel clearance for fat gravel grinding tires if wanted. Shown are 38's. Also cheap enough not to worry unduly in regards to theft, sand or salt.
#93
I have an 80s Women's Gazelle. This bike has a 60 cm frame which works great for my size. I like the step through when running grocery trips with loaded baskets at the back or when pulling a trailer hauling groceries. This way I don't have to swing my legs over and don't have to watch my feet/legs hitting any of the groceries sticking out at the top. But when fully loaded the step through bikes flex a lot more than bikes with a top tube frame.
But last year I moved to an upright recumbent which has become my daily commuting bike.
#94
Quoted: 2323 Post(s)
Liked 4,981 Times
So funny reading some of these comments from 10 years ago.....entertaining. Found this thread while googling Azor and figured why not bring it back from the dead?
For years I "got by" with an old english three speed but it was always a compromise. Not to mention too small. Used mainly to run errands around town.
Then I graduated to this crazy Trekking bike that once again was a compromise. Heck I ride road bikes every day and getting on this is a pain in the butt. Swinging the leg over the basket is not very easy nor stepping over the top tube. Even when you can tilt it. The add a load into the basket and it's even more of a chore not to spill stuff out when you try to get on.
So I figured it was time to get smart. Did a ton of research and settled on the custom build of an Azor bike with a step through frame. Once this baby is built and delivered I'll honestly post my thoughts on modern step through frames.
This is what I should have my hands on in a couple of months at most.
Steel is real...and comfy.
Likes For jamesdak:
#95
Liked 2,461 Times
@jamesdak, another option is swinging your leg over the handlebars. It's not necessarily easier.
#96
Liked 4,981 Times
Likes For jamesdak:
#98
Disco Infiltrator
Liked 2,103 Times
Genesis 49:16-17
Genesis 49:16-17
#99
#100
Bikes: A few
Liked 7 Times
There are many videos on Youtube that talk about the benefits of step-through bikes for every day travel. Here are a couple
and
Noticed that all bike share bikes I've ever seen are step-through.
Likes For Ciufalon:
