GT triple triangle frame thread
#101
GT Timberline
I picked his up at auction and thought I'd post pictures...I'm guessing 1988 Timberline?
#102
Quoted: 2362 Post(s)
Liked 1,749 Times
Picked what up? Not seeing a pic....
#104
Bikes: 1987 Centurion Ironman Master, 1989 Centurion Ironman Expert, 1972 Motobecane Grand Jubilee
Quoted: 119 Post(s)
Liked 171 Times
Here's my recent GT Lightning TI drop bar hardtail build.
Likes For Brewsmith:
#107
glorified 5954
I would throw on a CX or road drive-train and ride the hell out if it! Maybe also a carbon fork?
#108
Thanks for the kind education!
CR
#109
glorified 5954
I guess there would be a change in handling characteristics depending on the material type. I was however thinking of aesthetics alone. Carbon fork would just look better! It would also open up the front brake type possibilities.
#110
Death fork? Naaaah!!
And the 'ol switch-a-roo is done:
The 56cm frame and fork will be up on the 'For Sale' thread, if anyone is interested.
Top
Top
#111
Bikes: Trek Farley, Giant Trance X, Salsa Vaya
Quoted: 89 Post(s)
Liked 77 Times
That ride looks sweet, Top. Love the other stuff in the shed too - 'let's just pile these handlebars right...here.'
I just got a GT Tequesta that I did my first drop bar conversion on - I'd post some pics but you'd all laugh at the adjustable stem I used to figure out what felt decent, lol
#112
glorified 5954
The Tempest has finally seen some decent use this year and I am ever more impressed with how stiff, light and agile this bike is.
After a couple of long rides I felt that the large chainring could be larger and that the brakes were not perfectly set up. The crank was a 40/28 and after much reading and deliberation is now successfully a 44/28. It rubs only very slightly on the bottom of the front derailleur whilst in 28/11 which is no problem and the chainring still has about 3mm of play between the teeth and the chainstay. This is accomplished without the use of a drive-side spacer, so the chainline is really optimal!
The resulting gearing is now great for the flats and does not rob my bottom end which I ensure is required! The brake levers went from XT (V-brake, non-adjustable) to Ultegra (Cantilever, adjustable) and I find that they are only OK. Primarily because they are only 2.5 finger where the XT's are 3. The only drawback from the XT's was the longer cable pull, as they are intended for v-brake use. When used with the cantilevers, the pads would kick out very far and the kool-stops would rub on the tires. It was hoped that this would be remedied with the new Ultegra levers, but regretfully was that not the case as the cable pull is still somewhat longer than hoped. What I ended up doing was filing down the upper-rear edges of the kool-stops and now have no rubbing.
The XT levers will most likely get re-installed as they look better and allow more easily, more power application. I am also playing with the idea of installing XT v-brakes to go with the levers. The bike would be slightly heavier but I feel that the braking power and modulation will benefit. I don't feel that they would look as nice as the cantilevers but perhaps after having the arms of the v-brakes polished to a high-shine would they look even better!
Anyhow, the bike was cleaned and I took to it with some metal polish/protectant. It has after all been a couple of years and the aluminum was needing some attention.
Likes For pressed001:
#113
Bikes: 85 botteccia, 85 mcmahn tiatainium, 90 something trek clyde, early 70s schwinn tandem single speed, early 90s gary fisher aquila (the daily rider now!)
Quoted: 11 Post(s)
Liked 18 Times
Good looking ride.
#115
wonder if my 1985 Backwoods is still welcomed although it was pre Triple Triangle for GT, pics are as i got it and its in queue ..deciding on how to build it.
1985 Timberline , as i got it. not much is original
Proof its a GT
Yes stock with a GT Epoch headset.. basically it has a spring in the headset that keeps the top race from loosening . it was a mainstay on the GT Freestyle bikes
Proof its a GT
#116
^^ Heck yes! Roll it out and get it built! Those top tube end caps are just like the hangers they used to sell mech in the stores. I’m one to talk, my 91 Karakoram Elite is taking forever as well.
#117
I see it as a urban cruiser as sorts since it was not a great ATB as new. and its got the long lines on it..
#118
Bikes: TRIMMED DOWN THE HERD
Quoted: 1090 Post(s)
Liked 935 Times
Proof its a GT
Proof its a GT
My Muddy Fox Explorer has a similar headset. Pretty cool engineering, IMO.
#119
glorified 5954
I don't know if you will find this outside of Europe. Sonax Chrome and Aluminum polish.
#120
glorified 5954
#121
@2cam16, I totally forgot about these headsets, i remember hearing about them back in the 80's, but never tore one apart.. til this one!
@pressed001. Thank you, your tempest is beautiful! I will start a thread for it when i start building it, just have to figure out how i want to build it..
#122
1999 Korakoram hardtail
I am the original owner of this. I believe it's a 1999 based on bikepedia (although their photo is terrible and does not show the true color). I rarely use the bike and when I do it's mostly on the flats. Unfortunately never got into taking this off road. It's a time capsule of original parts as I don't remember replacing anything (the gt pedals are somewhere).
Just sharing...
Just sharing...
#123
glorified 5954
#124
Bikes: '73 Motobecane Mirage, '94 GT Karakoram, '14 Surly Pugsley
Quoted: 38 Post(s)
I posted in this thread last year and I have since converted my 94 Karakoram to a drop bar build.
#125
Liked 1,749 Times
^^^^^ (Gasp) You didn't post it to the August "Show us your purple bikes" thread? Tsk, tsk.....
