Thru axle question
Thru axle question
I just bought a new road bike that has thru axels. I do not have any experience with these. I noticed that on the front wheel if you tighten the thru axels it creates resistance and the wheel does not spin freely. If I loosen the thru axel until the wheel spins freely, then it seems way too loose. What gives?? Thanks!!
Quoted: 6196 Post(s)
Liked 4,810 Times
Sounds like the bearings may have been put up too tight. Or you are really putting a lot of muscle into tightening the through axle.
If wheel bearings feel perfect when the wheel is not clamped in or the axle tightened, then they usually will be too tight when installed with a QR. I'd think it would be the same for a thru-axle. IMO... of course.
Tightening the QR or thru-axle compresses the spindle the bearing cones are on. Possibly the cones, locknuts, spacers and such are installed wrong.
Bikes: 1979 Raleigh Team 753
Quoted: 3375 Post(s)
Liked 371 Times
Liked 4,810 Times
Oh, I suppose another possibility is that the brakes are rubbing and need adjusting. calipers, disc or cantelever?
Are you certain the spacers are installed and the frame is simply not being tightened against the part of the hub that is supposed to rotate?
Chases Dogs for Sport
I've been using thru axles for a few years on gravel bikes and I have them now on my road bike. I've never had that problem with a hub . . . but I HAVE had an issue with a brake disc / caliper. If I tightened the thru axle too tight, the frame would flex enough to cause the caliper to rub the disc. If I backed the thru axle off 1/4 or 1/2 turn, the problem was solved.
Quoted: 878 Post(s)
Liked 726 Times
