Radial spoke vs spiral
This might be a sort of esoteric question, but I'm really curious to know if using a 'spiral' lacing pattern is sacrificing strength/rigidity vs a standard radial pattern. Normally, when I lace a front wheel, I cross spokes, but I happen to have a front hub with straight pull format, which doesn't lend itself to crossed spoking. I'm skeptical of radial wheels generally, but this is a front wheel that I won't be too hard on. The reason for my question is that I'm thinking of lacing this hub to a rim of a slightly different ERD and out of pure stinginess, I want to reuse the decent spokes that I already have. This would require me to compensate the length a little by angling the spokes to an adjacent hole. I think the effect looks kind of cool, but appears to my eye as though it wouldn't be as strong or stiff as straight radial. Anyone have some engineering perspective on this? Is the angle sacrificing anything? I'm wondering if I should just buy some correct length spokes.
Quoted: 4408 Post(s)
Liked 1,562 Times
I don't know what you mean by "spiral". If the spokes aren't radial they have to be in opposing pairs. The minimum way to offset the spokes is a one cross wheel.
Crossed spokes are less rigid than radial, but make the wheel tougher - able to absorb more shock. I've built 1x front wheels for that reason.
Quoted: 1814 Post(s)
Liked 923 Times
If one side of the hub is pulling one direction,
& the other pulling the opposite direction,
It sounds like a short-lived experiment.
Quoted: 1074 Post(s)
Liked 295 Times
It’s entirely possible to build a tangential laced wheel w/o crosses.
You’ll have all spokes on one side leaning clockwise and all on the other side leaning counter-clockwise.
You can even use the same spoke calculations as for a regular crossed pattern.
It will expose the hub shell to a twisting force, so don’t do 3x on hubs with narrow hub shells/spindles.
I’ve got a pic somewhere of a hub that twisted during final tensioning on such a build.
For 1x and/or hubs with wide shells it’s no problem.
On a rim brake front wheel there are no particular concerns for use.
But I wouldn’t want to use one for a torque-carrying hub.
One whole side going floppy simultaneously from torque is an experience I’ll happily leave to others...
Bikes: 1979 Raleigh Team 753
Quoted: 3375 Post(s)
Liked 371 Times
I built a lot of wheels. Hundreds. But all alloy. I am not certain, but of the opinion the rim material - and profile matters.
A thinner "weaker" rim might work better with more crosses.
For a fewer spoked wheel a 2X is more significant an angel than a 3X on a higher spoked wheel.
Quoted: 2483 Post(s)
Liked 2,955 Times
On the other hand, a Campy rep once mentioned that they occasionally had to turn down warranty claims for hubs that had been twisted as a result of incorrect spoking. "Campy hubs don't come out of the box with oval oil holes," he said.
Quoted: 6556 Post(s)
Liked 58 Times
Just do it right and be done with it. Straight pull spokes can be crossed if the hub is set up for that. If the hub is set up for the straight pull spokes to be radial, then that is what you have to do. Don't screw around. If you have to buy new spokes, so buy new spokes.
Thanks for all the feedback. I probably should have been clearer in saying that this front hub I'm considering is intended for straight pull radial spoking, and that what I mean by 'spiral lacing' is to lace each side at roughly a 20deg tangent, uncrossed. I've seen it done enough times to feel like it might not be a disaster. It's usually on BMX or street freestyle single speeds, which often put aesthetics above sound function, though. Obviously you'd never want to do this to a drive wheel, but for a front wheel, it might not be much worse than radial. I didn't feel like the angle of tangent I'm considering would be a detriment to the hub flange, and I was sort of curious to see how the spiral lacing would perform. I think the main stress would be from converting and redistributing the vertical forces around the circumference of the rim, which would seem intuitively to work ok. Ultimately though, I think a straight pull radial hub is the wrong thing to try this on, so I'm just going to do what I know to be optimal.
Liked 1,562 Times
What I refer to as spiral lacing is an uncrossed pattern laced at opposing tangents for each flange. I'll try to attach an example:
Go to DAN'S COMP - Bmx Bikes, Bmx Parts, Bmx Clothing, Bmx Shoes and Bmx Accessories!, find their phone number and call them, and have brand new Sapim spokes of the proper length delivered in a few days for <$20.
Quoted: 5790 Post(s)
Liked 2,581 Times
The only issue with spiral patterns on front wheels, is that they impose a torque between the flanges which want to twist in opposite directions. Some hubs can take it, some can't.
FB
Chain-L site
FB
Chain-L site
Liked 1,562 Times
I've heard of twisted Dura Ace hubs doing something like this.
Liked 2,581 Times
Yes, this is what I was referring to.
It's relatively easy to twist the barrel (section of the shell holding the flanges apart) on hubs where it's in the 15-20mm range. Many others, mostly of the machined from billet type with barrels in the 30mm range can take this build OK.
FB
Chain-L site
FB
Chain-L site
Liked 1,562 Times
Quoted: 18378 Post(s)
Liked 4,512 Times
Such a lacing pattern may be aesthetically pleasing, but wouldn't be my choice.
The vintage hubs had a relatively small diameter center barrel sections, and would be a poor choice. More modern ones may have a larger diameter center section, but may also use thinner walls. There are a few offroad hubs with enormous barrels, and perhaps would be OK, but there would be no benefit of such lacing.
Radial front seems to be increasingly popular (with rim brake front wheels), and makes some sense with the hub hanging directly below the rim.
Liked 1,562 Times
Bumps shouldn't affect the wheel as a whole, just the section that is right around the impact.
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
