Painting 1977 frame: remove bb and other questions??
#51
Quoted: 2362 Post(s)
Liked 1,749 Times
Likes For madpogue:
#52
har har...
I agree with the repaint. It's rusting and too far gone. Decals are available. If you've got an autobody guy willing to do it, that's a good way to go. Frankly a good powdercoat would be fine too. It's not like old Treks have finely filed lug tips. It is a production bike. Or take up the fellow forumite on his offer...
Spray enamels are unlikely to hold up, unless you can wrangle some old school stove-able enamel. In a way, that's what powder coat is. Stoved on at least.
#53
Bikes: 1977 Trek
Quoted: 34 Post(s)
Liked 22 Times
Check out Randy's site Painting a Bicycle
If funds are short, brush on might be the way to go. You have the winter to wait a week between coats etc. then when you get $$$, get it done right.
Oh, remove everything.
#54
Quoted: 339 Post(s)
Liked 631 Times
You can read my earlier posts detailing how to paint with Rustoleum enamel . I have done quite a few repaints using it and for the money it can't be beat. Just be sure to be careful and after painting don't hang the hardware on it for a couple months to let it dry . Store it somewhere hot while you are waiting . like the attic.
if you are going to all the trouble of painting the bike you would be crazy not to pull the bottom bracket, fork/stem, and seat post. If any of those is frozen and won't come off your bike is basically toast and no point painting it.
I just finished rehabbing an 85 Bianchi and the grease on the bottom bracket bearings was so hard I had to chip it off with a screw driver. Same with the stem. After cleaning and renewing the grease everything works beautifully.
#55
Mr. Anachronism
Quoted: 526 Post(s)
Liked 256 Times
There was a discussion (more like I made an observation) about the ‘ice blue’ early Treks seem to ALL have had the livin’ snot ridden out of them.
I don’t know the exact provenance of my bike- but it shares that “excessively worn” look that most of all the early (read: TX series bikes) ice blue Treks seem to share.
#56
Quoted: 1946 Post(s)
Liked 2,004 Times
Pretty sure he used Rustoleum. That is what I used also. $13.00 total for paint and primer FTW. $20.00 for brushes which are not single use. The key is prep and wait time of at least a week to dry between coats. Colors of course are limited. I've got some safety red that is waiting for a project.
#57
framebuilder
DuPont Imron is a brand name for polyurethane paint that is made by many different companies. It was designed to be used for the abuse aircraft can get flying through the air at speed. It is probably the most durable type of wet paint available. It is actually an epoxy that hardens by chemical action when the activator is added. This paint is too hard to bond to steel directly so that is why a primer is used. The primer is designed to both stick to steel and the top colors. It is also an epoxy paint that requires an activator. Both the primer and color paints need a reducer so they flow out more smoothly. This kind of paint is way more durable than paint designed to harden when left to dry in the air.
There is an experienced amateur builder in Florida that recently wanted to try painting his frames with Rustoleum.He wrote about his issues on one of the framebuilding forums.I’m too lazy to try and find that subject thread.If I remember right he eventually abandoned the idea because of the amount of time it took (even with the help of a hot attic) and the results were less durable than what he was used to.To be fair to his posts I didn’t read them carefully because it wasn’t something that interested me nor something that I would recommend to my framebuilding students.They are making something that will probably be used a lot and will want something more durable.Not only that but fair or not the paint is what will represent the quality of their entire work and there is no way you can get a frame to look as good as a professional polyurethane paint job.Having said that some of the amateur air-dried paint jobs pictured on this forum look good and are a big improvement as well as much more affordable.
Likes For Doug Fattic:
#58
Bikes: '84 Miyata 610 ‘91 Cannondale ST600,'83 Trek 720 ‘84 Trek 520, 620, ‘91 Miyata 1000LT, '79 Trek 514, '78 Trek 706, '73 Raleigh Int. frame.
Quoted: 684 Post(s)
Liked 370 Times
1979 514
It's been touched up with some brushed on flat blue paint by the PO.
#59
Mr. Anachronism
Quoted: 526 Post(s)
Liked 256 Times
BTW, all powdercoat is NOT created equal.
Likes For Hudson308:
#60
Quoted: 796 Post(s)
Liked 522 Times
Glacier Blue 87 MIyata 112
#61
Liked 1,749 Times
+1; this is what I was referring to earlier, about the thickness. Even on a "production" * frame, it makes a big difference visually. Thanks for the pics, they make that very clear.
* Re "production" "Production" meant something very different in the late '70s, in a pole shed in a small town in Wisconsin. These frames were hand built by craftsmen. In today's "production" facilities, the employee break room is probably bigger than the pole shed in which the subject bike was built.
#62
Extraordinary Magnitude
Quoted: 2607 Post(s)
Liked 1,696 Times
Too bad there's only a "like" button, but not a "love" button!
(yes I'm aware of the implications of that statement)
Commence to jigglin’ huh?!?!
Likes For The Golden Boy:
#63
I mentioned this for a practical reason. The lug points in Treks of that era would have been left more or less full thickness. By contrast, the small scale custom American framebuilders of the same period tended to file the points down very thin. Thinner was cooler and more custom, but that sort of frame detail can easily disappear under a thick powder coat job and look pretty bad. An older hand built 'production' Trek frame could potentially look very nice with a thin powder coat if it is done by someone who has experience and cares.
Likes For Salamandrine:
#64
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
Likes For Unca_Sam:
#66
Bikes: 1977 Trek
Quoted: 34 Post(s)
Liked 22 Times
#67
Liked 1,749 Times
The shed's still there, BTW, still red. You can view it on Street View.
Likes For madpogue:
#69
Bikes: 1977 Trek
Quoted: 34 Post(s)
Liked 22 Times
Update: I'm going to have my auto body acquaintance guy do it. He seems kinda excited about it. He asked if I could get codes for the paint or something, but I don't think so. He'll sandblast it and prep it as well as paint it. I just said match it as close as possible. Several automakers have "ice blue" colors that look pretty good. I'll be happy if it's sorta close to the original.
#70
Liked 2,004 Times
You will be happier if you get as close to your color as possible. Search a little. How many Imron colors could there be? Or pick a fresh new color?
#71
framebuilder
#73
Quoted: 226 Post(s)
Liked 258 Times
#74
Quoted: 4510 Post(s)
Liked 6,374 Times
100's if not 1000's, they still use it for big rigs because it's so tough, a good friend of mine works at Fretghtliner in the wind tunnel and paint shop.
You can also still look up old charts on the interwebs too.
#75
Not lost wanderer.
Quoted: 885 Post(s)
Liked 987 Times
Rattle can can be an ok paint job.
Here is a cheapo Hybrid I made into a Covid single speeder coaster brake bike.
I stripped the paint and rust, primered it, let it sit for a couple of days in the sun to harden, then sprayed silver (3 light coats on the frame and 1 silver and 2 metallic red on the fork) and let it sit in the sun for a day and then sprayed 2 coats of clear.
Here is one like above I stripped and made into a coaster brake only bike.
