Bottle Cages
Canadian eh?
Bikes: 2020 Specialized Roubaix Expert
Quoted: 131 Post(s)
Liked 96 Times
Bottle Cages
Hi There
I currently have the Z style Specialized Bottle Cages on both the seat tube and bottom tubes of my 54cm bike.
I use the larger 25oz Camelbak Podium bottles and thought the Z cage style would make it easier to get the bottles in and out, especially on the seat tube.
Suffice it to say, getting the bottle in, while in motion, is a bit of a balancing act.
Wondering if anyone has any other ideas, other than getting smaller bottles.
Likes For WorldIRC:
Bikes: Trek Emonda SL5, Trek Fuel EX7, Specialized Roubaix Elite
Quoted: 17 Post(s)
Liked 20 Times
I use the Fabric cageless bottles and have no issues sliding even the largest bottles into the pegs.
Canadian eh?
Quoted: 131 Post(s)
Liked 96 Times
Maybe something like the Blackburn Slick Racing Bottle Cage would work. It has a wider opening (and its super light, not that I am looking to save weight here).
https://www.blackburndesign.com/p/sl...r-bottle-cage/
However, since its Polycarb and pretty light, it may not be "stiff" enough.
Thoughts?
Thoughts?
Zoom zoom zoom zoom bonk
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35, Kona Rove, Trek Verve+2
Quoted: 551 Post(s)
Liked 722 Times
My bikes are around 54 and I don't have problems with regular type elite cages even with 950ml bottles. Is it just awkward and you need more practice? Did you get the opposite side cage for the seat tube?
Canadian eh?
Quoted: 131 Post(s)
Liked 96 Times
I meant the Fabric cageless bottle that comes in 750ml doesn't have an insulated option. I'm happy with my Camelbak bottles!
Likes For WorldIRC:
Canadian eh?
Quoted: 131 Post(s)
Liked 96 Times
I could give it some more practice of course. I think it's just the combination of a larger bottle, stiffer Z cage, and in motion, all at the same time. You have to force the bottle in (which in turn means it'll likely never fall out).
Quoted: 642 Post(s)
Liked 1,526 Times
My Roubaix is a 54 and I have the Specialized Rib Cage II cages. I'm using 24 oz Polar bottles so i'm guessing a similar size to the 25oz podium. After installing the cages and seeing how little space was left above the bottle I wasn't sure it would work out. What I've found is that getting the bottle in/out of the cage on the down tube is no problem. The seat tube one is a little more trouble so I just use up the down tube bottle and then swap the two. It's worked out so far.
My only issue with these cages is that they leave black marks on the bottles. Not a big deal for me but some might have an issue with it.
Likes For noodle soup:
Likes For eduskator:
Quoted: 18883 Post(s)
Liked 10,646 Times
Likes For Seattle Forrest:
Liked 10,646 Times
I bought cheap cases from Amazon. You can get a pair for $10 in carbon. There's a lot of variation, I got a pair that was too tight to use with most bottles. But in general they tend to work well.
The thing I like about the cheap ones is making the bike look slightly different every now and then. It's like changing your bar tape to a different color, but less pain in the ass.
I also like to have an icy brawndo waiting for me when I get home (or back to my car).
Quoted: 4717 Post(s)
Liked 1,882 Times
BTW, these bottles are what you want if you like cold liquids while riding.
https://www.camelbak.com/en/bottles/...f043375b859707
Quidam Bike Super Hero
Bikes: 1995 Trek 800 Sport, aka, "CamelTrek"
Quoted: 331 Post(s)
Liked 415 Times
Salsa side loading cage is not expensive. Check @ rei.com
Quoted: 426 Post(s)
Liked 274 Times
Thank you
Quoted: 642 Post(s)
Liked 1,526 Times
I've been using these since I started road riding 3 years ago or so. Haven't used an uninsulated bottle so not sure how they compare. In the summer, I usually fill them about 1/3rd and freeze them.On a warm day, the ice is melted in 1-2 hours so the insulation isn't all that great but I would guess it's better than nothing.
Likes For Ogsarg:
Bikes: Factor O2, Caad10, Caad2
Quoted: 365 Post(s)
Liked 122 Times
I use the Blackburn Camber cages, but you can find less expensive equivalents on Amazon. I always use the Podium insulated bottles and don't have any issues.
I've gotten some interesting experience over the last week or two during our current mini-heatwave. I did a couple rides where it was like 100-101 F, interspersed with other rides where I got out early and it was only in the upper 80s or 90 or so, and at 101 F when I kept my heart rate at the same level as the 90 F rides my speed was about 2 mph slower. That's pretty remarkable how much of a load the heat will put on a body.
Quoted: 1814 Post(s)
Liked 923 Times
(to the OP) Have you tried regular bottle cages?
I'm left handed, but usually grab the bottle with right hand. It's about keeping a hand available for the front brake I think,
& also a fumbled bottle is less likely to cause a problem (happened once on a wet cold morning).
Likes For woodcraft:
Non omnino gravis
