Carbon fiber fork sound test
Hi all,
I had a spill on my bike the other day, completely my own fault and fell on some asphalt. Right handlebar and pedal got the worst of it, but some nicks on the right backside of the fork. Didn't really look like much but tried the coin test and sounds like damage. Link to vid is below - sorry not able to post hyperlink yet.
Curious to hear thoughts - thanks!
streamable.com/8v6b1k
Quoted: 303 Post(s)
Liked 136 Times
What I am hearing is the transition from the more substantial thick part at the top of the fork to the thinner
all CF portion of the fork. Fork crowns are reinforced thicker areas. Nothing to be concerned about there.
IOW tapping doesn't help in this area. Nice video though.
Quoted: 837 Post(s)
Liked 1,061 Times
The video is pretty pointless IMO. sch had it right. Try this on your entire frame and you'll notice there are varying sounds throughout the tubes.
Blamester
Hi all,
You will have too decide or bring it to someone who can.
I would start with a test.
Do the brakes line up correctly?
Is the wheel position correct?
Rock the bike back and forth hard on the brakes lean you body weight over the saddle. Do it as hard as you can.
Is it different then before?
Does it make a noise?
Does the damage look different?
Is the wheel position correct or has it moved?
Take the wheel out twist and turn the fork blades.
Are they both the same?
Does the damage change shape?
If everything is normal
Short slow ride
This is a start. Go from there.
If any of the answers where not satisfactory then there is a problem.
And you must decide what needs doing.
Bye the way I didn't even look at the video.
I took a couple more just so i don't exclude anything:
Here is the back of the fork with the marks, the left side is where the duller sound comes.
imgur.com/fCssRFR
Here is sound of the "ok" leg:
streamable.com/dma5mr
And leg in question (duller sound at end)
streamable.com/kpcw9z
Thanks again for looking at it
No one here can tell you if it's o.k
Short slow ride
Short slow ride
