Ankle stability on the bike
Quoted: 27 Post(s)
Liked 9 Times
Hi all, has anyone else out there experienced instability in their ankle in that you can’t hold the ankle from flexing during the pedal stroke? I’m 52 years old and I have had this issue on my left leg on and off at times for months. Probably a fatigue thing. I mentioned it to my physio when I was there for something else and he kind of shrugged it off. Now, some months after I first noticed it, I’m having troubles with Achilles tendonitis (mid-tendon) on this leg. It first showed up a couple of months ago, I’ve gradually got back to normal riding and now just had a relapse. I’ve been prescribed using a foam roller on the calves and doing calf raises.
The left leg is weaker than the right, particularly noticeable in the quads & glutes and had been doing a lot of squats & lunges prior to this to improve things. Also was planning on doing some single leg work on a the stationary bike but hadn’t gotten around to it.
Thanks in advance for any thoughts or similar experiences you might have.
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times
Can't hold the ankle from flexing in which direction?
My ankles flex upwards and downwards significantly at different cadences and intensities (I ride with my seat slightly lower than most), but doesn't roll from side to side very much.
Quoted: 6193 Post(s)
Liked 4,809 Times
Put your feet further forward on the pedals. It'll feel very odd till you get used to it. If your shoes have too much flex in them, then find something better for riding. IMO.
You might need to lower your seat some. When you are pedaling correctly, the ankle shouldn't move much at all. If you are having problems with you ankle wobbling side to side and you are using SPD cleats, then maybe an spd pedal with a little bit of platform around it may help.
If you truly have weak muscles around your feet and ankle, then see a gym or physical therapist. I feel that in general, strength training is better done off the bike.
Quoted: 18883 Post(s)
Liked 10,646 Times
Your doctor probably shrugged it off due to a lack of specialist knowledge. See a foot and ankle doctor.
Likes For Seattle Forrest:
Quoted: 27 Post(s)
Liked 9 Times
Sorry, I should have explained. Not so noticeably sideways. I realise that there's upwards and downward flexing but I'm more talking about uncontrolled excessive movement. I feel like I have little control over my ankle joint when it happens.
Quoted: 27 Post(s)
Liked 9 Times
Liked 4,809 Times
I don't feel bikes are the proper place for strength training. So I might disagree with your physiotherapist, unless your riding is limited to 30 minute sessions or less.
As for where you cleat is currently, You've not said. So I can only say, the more forward the cleat, the more unstable the foot and more work your calf and ankle muscles will have to do in order to keep the foot stable.
https://www.stevehoggbikefitting.com...leat-position/
https://www.cyclingweekly.com/fitnes...orrectly-23575
Too far back and you might loose some of the smoothness a slight movement of your ankle adds to the pedal stroke. However I don't really think I've owned a pair of shoes that would allow me to move the cleat so far back that would be a real problem. It's more that it just feels so odd to so many that won't give themselves sufficient time to get used to it.
Certainly I'm not saying rearward is best and everyone must do it. However neither is it good to have your cleat too far forward and your muscles not being able to control and stabilize your foot for an hour or more riding. Certainly your physiotherapist wouldn't have you doing any other repetition for that long a time if it was actually hurting you.
just another gosling
Quoted: 3889 Post(s)
Liked 1,938 Times
I recommend hiking, preferably on rocky trails. That's how I've rehabbed lower extremity weaknesses. If those aren't available, try lots of walking. When you can walk or hike say 4 miles no problem, then try calf raises on a stair, full range of motion. Start with both legs together, progress to single leg calf raises. I wouldn't move your cleats. Your problem is weakness. Hiding from weakness only allows it to continue. Better to strengthen.
I see you have a PT. They should be able to help you a lot more than we can. Although squats and lunges certainly aren't what I'd prescribe for ankle weakness. Bosu ball would be more like it. You just do what this woman does, you'll be fine:
Results matter
Results matter
Quoted: 27 Post(s)
Liked 9 Times
Have done a bit of hiking before. Wouldn't mind doing some more.
Quoted: 27 Post(s)
Liked 9 Times
Liked 10,646 Times
I moved my cleats back a couple years ago and find it to be an improvement.
Single leg deadlifts are great for ankle strength/stability, and balance in general. You can do them with body weight and get 99% of the benefit. But your PT probably has exercises specific to your condition, so trust him or her over us.
Quoted: 421 Post(s)
Liked 379 Times
I recommend also specific exercises for strengthening ankles and feet. Any dancer you know will be able to give you tips; there are also videos from both dancers and physios online: https://www.youtube.com/results?sear...+strengthening
