Mounting a light on a carbon seatstay?
The Crank
Any 'bright ideas' for mounting a light on a carbon seatstay?
Quoted: 6176 Post(s)
Liked 4,794 Times
How heavy a light are you mounting? My lights are held on by a wide rubbery band that hooks in two places. Most of the small bright lights similar to Bontrager Flare come with that type mount. Lights that are a little heavier use a mount similar to some of the out front mounts for your GPS. All I've seen come new with the adapters to make the mount the right size for the seatpost or size seatstay, or tube you want to mount them on. Regardless of whether carbon fiber or not.
As long as the mount puts fairly equal pressure on every side of the tube, it's not going to crush it.
Last edited by Iride01; 06-26-20 at 06:00 PM. Reason: fare to flare.... spelling correction. Sucks not proof reading carefully before posting!
Likes For Iride01:
wrap it with rubber taped down and it should stay unblemished..
Mount it to he saddle instead?
Blamester
Quoted: 2336 Post(s)
Liked 2,808 Times
https://www.amazon.com/CYGOLITE-Tune...5-4be35d7258cc
https://www.amazon.com/Cygolite-Fron...5-4be35d7258cc
Quoted: 836 Post(s)
Liked 1,058 Times
What light are you mounting and photos of the frame would help. Should not be too difficult to find a solution. Some mfrs. even offer separate mounts for this or Ebay may have something if not wanting to fabricate your own.
Quoted: 336 Post(s)
Liked 309 Times
If one is short, there isn’t room for a tool roll or seatbag to be mounted on the seatpost at the same time, so one has to find another place to keep a light (or tools). I mount on the left side seat stay for exactly this reason, but you have to have a light with an adjustable angle mount. Planet bike lights even come with a separate clamp to mount on the seat stays.
most lights with bungy like attachments will have no problems on a seat stay just be careful you dont sneeze when around carbon frames as they are so fragile they might explode into pieces
Quoted: 1814 Post(s)
Liked 923 Times
Sqirtdad's link has an adjustable mount, 'tho those are excessively bright IMO.
I'd also be concerned about the light possibly rotating into the spokes, & a bit of aero penalty.
