downhill windy road help
Old 07-23-20, 07:12 PM
Symox
Bikes: '23 Poseidon Redwood, '07 Specialized Roubaix Comp Triple, '12 Gravity Fixie, '21 Liv Rove 4, '06? Giant EB Spirit
Quoted: 345 Post(s)
Liked 237 Times in 151 Posts
I have a 2007 Specialized Roubaix Comp triple. Great bike. However, I have never felt confident going downhill on windy roads that weren't completely smooth. I always feel like if there is some bumpiness (gravel or those "wake up you are about to go into the opposite lane divots") and I am riding the brakes that I'm on the verge of losing control. I get the sense that the brakes are about to chatter locking up after losing contact with the road momentarily. I have felt this with other bikes so I think it is my technique more than anything.
Doesn't seem to matter if I'm using the drops or top of the bars, as soon as I use the brakes with road chatter I feel like "this might be the ride". Probably doesn't matter that I'm on a straight or windy road, I guess I just ride windy hills more often. Any suggestions? I'm not going super fast, maybe 30mph max.
Anybody else have this experience?
Symox is offline
Old 07-23-20, 07:18 PM
Koyote
Quoted: 6963 Post(s)
Liked 10,963 Times in 4,688 Posts
It's not your technique; it's normal. When you hit bumps, your bike (front tire, rear tire, both perhaps) bounces slightly off the pavement. If you are applying your brakes at that moment, then sure, one (or both) wheels can lock up. That's possible because, when the wheel loses contact with pavement, it will take very little braking power for it to lock up.
The solutions are to (1) use your brakes lightly and judiciously, (2) shift your weight back and get low on the bike (to aid with stability), and (3) avoid the bumps by looking ahead at the smooth portions of the pavement. (We tend to steer in the direction we are looking.)
I'm sure others will chime in with more advice, but that's mine.
Koyote is offline
Old 07-23-20, 10:09 PM
njkayaker
Quoted: 4257 Post(s)
Liked 1,357 Times in 942 Posts
The above advice but also get your weight off the seat (if you are coasting).
With your weight off the seat, your legs will be able to quickly act as shock absorbers.
You'll be able to stop/slow-down better if you can move your butt behind your seat. Practice (get used to) doing this on a normal (flat ride).
Also, try to take the lane rather than riding close to the right side of the lane. You'll have more space to maneuver and more options to avoid rough spots. Doing that entails checking traffic before the decent and takes some practice and experience.
njkayaker is offline
Likes For njkayaker:
Old 07-24-20, 04:45 AM
krecik
Quoted: 137 Post(s)
Liked 86 Times in 54 Posts
krecik is offline
Old 07-24-20, 05:18 AM
Ray9
Bikes: Cannondale six-13
Quoted: 144 Post(s)
Liked 108 Times in 24 Posts
If you are riding down steep hills on rural roads for the first time you need to use extra care. On occasion these roads offer not only potholes but craters. I don't ride in groups much anymore but if you do let the cowboys go. Do not get on wheels to draft on on downhills. In 2008 a young man who rode with us forgot to tighten his front wheel quick release and the wheel separated after a bump. He took six riders down at 40+mph. It took 30 minutes for an ambulance to arrive. I barely missed a bike frame.
I almost never use my brakes, especially the rear one. I am always looking ahead to anticipate hazards. Stay off the drops unless you are clear of dangers which can hit with no warning. I almost hit a chicken once in farm country. Anyone can go fast on downhills; it is the climbs that separate the men from the boys. this does not mean that brakes are not important. Keep them well maintained but use them sparingly. Happy cycling.
Ray9 is offline
Likes For Ray9:
Old 07-24-20, 06:04 AM
Kapusta
Advanced Slacker
Kapusta's Avatar
Quoted: 2762 Post(s)
Liked 2,537 Times in 1,433 Posts
Riding on those lane divider bumps is a bad idea, and a terrible place to be braking.
You sould almost never be “riding the brakes”. Brake harder when conditions are good (going straight, smooth pavement) and then let off them when thing are bad (cornering, bad road conditions).
Sometimes you just have to make the best of less-than-stellar options, like if the whole road is bumpy and gravelly. In that case, brake as much as you can on the straight sections.
Also, try larger tires at lower pressure.
Kapusta is offline
Likes For Kapusta:
Old 07-24-20, 06:24 AM
shelbyfv
Expired Member
shelbyfv's Avatar
Quoted: 3674 Post(s)
Liked 5,431 Times in 2,759 Posts
As others have pointed out, you should be in the drops and weight well back for safety. Personally, I can't just let-r-rip even on familiar descents. I've seen too many deer, dogs, cats, turkeys, chickens and squirrels turn suicidal to trust that one won't pop out of the roadside. I actually know folks who have been wrecked by all of above with the exception of turkeys. In truth, I'm probably no more likely to be able to avoid such at 35mph than I am at 50mph. I guess it's a mental failing but I can't see trying to overcome it at this point.
shelbyfv is offline
Likes For shelbyfv:
Old 07-24-20, 06:43 AM
Kapusta
Advanced Slacker
Kapusta's Avatar
That is not mental failing, that is simply good risk/benefit analysis. Crashing at 50 mph may well have life-changing consequences so the benefits better be good, such as REALLY enjoying it (which I gather you do not), or there being a prize at the end of the ride for the fastest person
Kapusta is offline
Likes For Kapusta:
Old 07-24-20, 06:49 AM
krecik
Quoted: 137 Post(s)
krecik is offline
Likes For krecik:
Old 07-24-20, 08:26 AM
CAT7RDR
Quoted: 822 Post(s)
Liked 1,960 Times in 943 Posts
+1 on wider tires. Just going to 28 mm from 25 mm made a significant difference with road vibration and cornering. My 29er with 2.2 treads is a blast on roady downhills.
CAT7RDR is offline
Likes For CAT7RDR:
Old 07-24-20, 09:57 AM
Chuckles1
Bikes: 2007 Motobecane Fantom Cross Expert, 2020 Motobecane Omni Strada Pro Disc (700c gravel bike), 2021 Motobecane Elite Adventure with Bafang 500W rear hub drive
Quoted: 174 Post(s)
Liked 143 Times in 94 Posts
Los of excellent advice. The only thing I would add is, if you're uncomfortable at 30mph, brake earlier and don't let your speed get that high to begin with.
Chuckles1 is offline
Likes For Chuckles1:
Old 07-24-20, 09:16 PM
Symox
Quoted: 345 Post(s)
Thanks everyone. Anyone know if a Specialized Roubaix can accept 28s? It definitely can do 25s.
Why do wider tires help?
Symox is offline
Old 07-24-20, 09:21 PM
Kapusta
Advanced Slacker
Kapusta's Avatar
Mostly because you can run your pressure lower.
Kapusta is offline
Likes For Kapusta:
Old 07-24-20, 10:38 PM
Symox
Quoted: 345 Post(s)
Lifting my butt off the seat felt much more unstable to me. I felt like my shoes were "floating" on the clipless pedals and I felt like I had less control. I must be doing something wrong.
Symox is offline
Old 07-24-20, 11:35 PM
Symox
Quoted: 345 Post(s)
Just checked and I am using 700x23 Michelin Lithion 2 tires. I'm gonna try the 28s. Any recommendations? Gatorskins?
Symox is offline
Old 07-24-20, 11:37 PM
spelger
spelger's Avatar
Bikes: yes, i have one
Quoted: 1138 Post(s)
Liked 1,182 Times in 687 Posts
I think a lot has to do with familiarity with the descent. I am very familiar with the ones here, every nook and cranny and scrape from plows. Not so much when I first rode but more so as I rode more. Now I barely break and pedal all the way down. You will get there.
spelger is offline
Old 07-25-20, 02:40 AM
justslow
Quoted: 43 Post(s)
Liked 31 Times in 20 Posts
If you're uncomfortable, you are going too fast. Don't let your speed build up to the point of discomfort.
justslow is offline
Old 07-25-20, 04:05 AM
njkayaker
It's the same weight pressing the tires to the road. So, it shouldn't be actually less stable.
For road bikes, most of the shock absorption is in your legs (some is in the tires). With your weight off the seat, your legs are active and can deal with bumps much more quickly.
You really don't want to hit a bump at speed with all your weight on the seat.
I have the habit of lifting my weight whenever I'm coasting. That way, if I hit a bump I missed seeing, I'm already dealing with it.
Old 07-25-20, 06:48 AM
frogmorton
Quoted: 12 Post(s)
Liked 29 Times in 17 Posts
A little googling says that you shout early able to put 28mm tires on a 2007 Roubaix. I have put 32mm on my 2017.
frogmorton is offline
Old 07-25-20, 07:19 AM
Kapusta
Advanced Slacker
Kapusta's Avatar
Yes, at high speeds if you eliminate all contact with the saddle it can feel a bit less stable. When I lift my weight off the saddle in this situation, the saddle is still braced against one or both of my thighs.
Kapusta is offline
Likes For Kapusta:
Old 07-25-20, 09:44 AM
cyccommute
Mad bike riding scientist
cyccommute's Avatar
Quoted: 6219 Post(s)
Liked 4,218 Times in 2,365 Posts
That’s only part of the story...and not the most important part. Wider tires have a large contact patch which means stability. Wider tires float over road irregularities while narrow tires either bounce off them (rocks) or knife into them (sand and soft spots).
The “lift” shouldn’t be very much. You don’t need to stand over the bike but only need to unload the saddle. One thing I haven’t seen mentioned is that your feet should be parallel to the ground you are riding over. If the road is flat and straight, the pedals should be even and horizontal. If the road is going down adjust so that your feet follow the terrain as you coast. Your knees should be flexed and taking the impact rather then the bike. Think of your legs as your shock absorbers. Your arms should be relaxed too. They are secondary shock absorbers.
When you get to a corner, put the inside pedal up and push hard on the outside pedal. This loads the tires on the outside edge and pulls you around the corner. Use brakes sparingly in corners but don’t avoid using them if you must. Part of the reason people tell you not to brake in corners is because the tire’s footprint is smaller and thus the friction is less. The bike will slide out to the side more quickly and is harder to recover from.
Body lean on corners is something else you need to think about. Bicycles have a high center of gravity. It’s located in your hips or a bit higher. You can’t lean into a corner like you would on a motorcycle because the wheels would slip out from under you. You want to lean over but you won’t be able to lean like a motorcycle racer. You have to lean the bike but lean “you” less.
The way to think of it is that your bike isn’t the heaviest part of the system. You don’t really have to manage it’s momentum. You are the heaviest part of the bike and you have to manage your body’s momentum. If let your bike bounce around under you, your body will just keep going in the same direction it was going before...Newton’s Laws of Motion and all that.
I really doubt that you’ll be able to use 28mm tires on that bike. The tire probably won’t clear the fork. I hate to say this but you have the wrong tool for the job. There is no way that you can make this bike into a “gravel” bike. You can ride it on gravel but, as you are finding, it’s a struggle.
Stuart Black
cyccommute is offline
Likes For cyccommute:
Old 07-25-20, 02:38 PM
Kapusta
Advanced Slacker
Kapusta's Avatar
Well you’re certainly entitled to your opinion as much as anybody else, but I disagree.
In my experience, going bigger without lowering the pressure on the road provides marginal benefit.
The size of the contact patch has mostly to do with the pressure, not the size of the tire. The benefits you are describing for a larger tire will not be realized unless you lower the pressure.
Kapusta is offline
Likes For Kapusta:
Old 07-25-20, 03:01 PM
Symox
Quoted: 345 Post(s)
I ordered some 700x28 gatorskins. I'll keep you posted - thanks everyone!!!
Symox is offline
cyccommute
cyccommute's Avatar
Lowering the pressure increases the rolling resistance. Using a wider tire reduces rolling resistance over a narrow tire but not if you lower pressure at the same time.
There is also a practical limit to lowering the pressure and, in my opinion, most people are below that limit. A tubed tire will pinch flat if the tire pressure is too low. What many people don’t understand is that pinch flat is telling you something. The tube is pinched when the tire is trapping the tube between the tire and the rim. You are risking impacting the rim on the ground and the result could be a damage rim. Damaged tubes are fairly cheap to fix. Damaged rims are far more involved and far more expensive.
However, in Symox’s case, going from a 23mm tire to even a 28 isn’t going to result in much protection nor in a significant decrease in rolling resistance. A 28mm tire is still a very narrow tire.
Stuart Black
Old 07-25-20, 04:17 PM
Kapusta
Advanced Slacker
Kapusta's Avatar
Yes, there is a lower limit... and the larger the tire, the lower that limit is. Thus, as a I said, the larger tire alows lower pressure.
As far as rolling resistance.... Sure, if you drop it too much you will have more resistance. But if - as you say - the larger tire rolls faster at the same pressures, then you can drop the pressure until the RR is the same.
Out of curiosity, do you run the same pressure in a set of 25s and a set of 38s?
Kapusta is offline
