New Bontrager rim is cracked
Old 07-30-20, 07:52 PM
koenbro
Bikes: 1994 Trek 520, 1987 Bianchi Brava, 1962 Ideor Super
Quoted: 54 Post(s)
Liked 15 Times in 13 Posts
My daily driver is a 2021 Trek FX 4 Carbon that I got IIRC in May. Have about 300 miles of smooth road on it, certainly under 500. I put on tubeless tires on the stock Bontrager and noticed air loss, and When I went to look for where the latex leaks out, turns out the rim is broken. The bike is out of the 30-day warranty, but not sure what to do about the rim. Any suggestions?
koenbro is offline
Old 07-31-20, 12:51 AM
katsup
katsup's Avatar
Bikes: 1995 ParkPre Pro 825 2021 Soma Fog Cutter v2 and 2021 Cotic SolarisMax
Quoted: 607 Post(s)
Liked 560 Times in 318 Posts
Contact the bike shop to see if its covered under warranty, 30 day sounds too short, especially for Trek. Look for a used wheel to use for the time being.
katsup is offline
Old 07-31-20, 02:53 AM
dabac
Quoted: 1074 Post(s)
Liked 295 Times in 222 Posts
Is that straight opposite the valve?
If it is, odds are you’re looking at the seam, not a crack.
Just about all rims start life as a straight piece that’s rolled into a hoop and joined together. Some are welded, some are pinned. Pinned is generally functionally just fine, but the hairline split will remain visible.
dabac is offline
Old 07-31-20, 11:46 AM
koenbro
Quoted: 54 Post(s)
Yes it is diametrically opposite and now that you mention, there is a seam line. So it was not joined properly. The rim is advertised by Trek as being "Tubeless ready" which evidently implies you don't lose air through the rim. I mean latex was bubbling out. Now it has cured, and it holds air at low pressure (20-something psi) but can't hold 40psi. I will call Trek and see what they say. Unimpressed by quality, have to say.
koenbro is offline
Old 08-01-20, 10:18 AM
hokiefyd
hokiefyd's Avatar
Bikes: More bikes than riders
Quoted: 1444 Post(s)
Liked 761 Times in 569 Posts
I am nearly 100% certain Trek will cover this with no questions asked. Take it to your local bike shop -- they'll look at it, say it's obviously not right, and theyll warranty it through Trek. Trek will likely send them a brand new wheel assembly. I had a loud freehub body on my Giant Roam and the bike shop said Giant would probably just send them an entirely new wheel (which they did), complete with disc brake rotor).
hokiefyd is offline
Old 08-02-20, 08:04 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Cool
New components..warranted 12 months.
fietsbob is offline
