Rusty BB tale of woe
Bikes: 2004 Trek 520, resto-modded 1987 Cannondale SR400, rando-modded 1976 AD Vent Noir; 2019 Wabi Classic; 1989? Burley Duet
Quoted: 213 Post(s)
Liked 93 Times
Noticed some rust on the BB of a fairly new bike, 7 months old with ~1200 miles on it. I took it apart and find it completely corroded! A little pile of rust flakes left in the frame (all from the BB- the frame has no rust at all). Bearings spin, but aren’t so smooth.
I rode this bike in the rain only a couple times, and wiped it down afterwards. Bike is stored indoors too.
I have a Shimano UN-55 with 6000 miles on it and it looked brand new when I took it out of the frame. I don’t want to besmirch Tange BBs’ reputation, but jeez.
crap happens
condensation happens,, blow out that stuff , "Framesaver" the inside of the tubes put in a new BB..
save the left mounting piece, after you clean it up, and use a cheaper UN 26 , and that piece if you don't like the plastic one.
Quoted: 213 Post(s)
Liked 93 Times
The adjustable cup is maybe the most rusted part of all. After I cleaned it up it was pitted and corroded like you’d expect on a maltreated 20-year-old bike.
Frame has no rust at all, in contrast to the BB.
Quoted: 213 Post(s)
Liked 93 Times
I already put the thing back together so I can’t take a picture, but no, the frame had no rust at all. I just wiped away the rust flakes and the frame was pristine inside.
It came from the factory with an anti-rust coating, which might’ve helped.
Point is the BB is pretty low quality.
Spend more to get better https://www.renehersecycles.com/prod...ttom-brackets/
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times
Tange is higher quality than the Shimano BBs. You have something going on in there. Water got into your frame. You say 7 months old bike, but I have never seen a bike come with a Tange BB. Who put it together when it was new? BB looks like an older version to me.
Friendship is Magic
Bikes: old ones
Quoted: 26402 Post(s)
Liked 10,374 Times
...this is also my experience (better quality) with Tange sealed units. There's something else going on, but I have no idea what it is.
If it were me, I'd switch to using a nylon plastic adjustable side retainer, and drill some weep holes in the BB shell while it is empty.
At the very least, I'd probably install the new BB unit with some kind of anti-seize on the threads, if I didn't use a plastic ring.
Quoted: 213 Post(s)
Liked 93 Times
Bike is a Wabi Classic. The BB appears to be a lower end model, with a steel retaining ring and a solid axle.
Also - this is probably relevant - I don’t think it was installed properly. The BB was barely torqued down when I unscrewed it.
Liked 742 Times
Hmm. When I search for this BB number it comes up with a TH industries or FSA bottom bracket, not Tange.
Did somebody switch?
Quoted: 213 Post(s)
Liked 93 Times
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
IIRC, Tange made the Shimano-branded cartridges.
