Flat pedals on road bike w/ Ultegra
Quoted: 22 Post(s)
I own a road bike Cannondale Caad9 with Ultegra crank arms. For city use I would like to be able to sometimes swtich to normal flat pedals so I dont have to wear bike shoes. Being a newbie when it comes to bike mechanics I need help: whats the kind standards for flat pedals? Will any fit?
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Those cranks use a 9/16” pedal thread. 9/16” thread is the modern standard, and most pedals out there these days are that size.
Pedals are one of the few things that component manufacturers have thankfully not overcomplicates with multiple competing standards.
Likes For Kapusta:
Quoted: 6963 Post(s)
Liked 10,961 Times
Depending on the type of cleats/pedals you are using, you may be able to find some two-sided pedals: flat on one side, clipless on the other. Then you can swap shoes without swapping pedals.
Likes For Koyote:
Expired Member
Quoted: 3667 Post(s)
Liked 5,420 Times
These are decent if you want just one pedal for both types of riding. A compromise for sure but maybe better than switching out the pedals regularly.
Likes For shelbyfv:
SE Wis
Quoted: 2746 Post(s)
Liked 3,390 Times
Likes For dedhed:
Quoted: 836 Post(s)
Liked 1,061 Times
You can also get clip in flat platforms for most types of pedals now so you won't have to change the pedal each time. Just do a search for whatever style pedal you have. Cheaper, easier than getting a second pair.
Likes For Crankycrank:
I found the old style toe clips best for in city riding. I would leave them loose enough that I could get out easily but tight enough that they provided at least some upstroke value. They let you press hard on the downstroke without fear of slipping off. And if they aren't too tall you can ride the flat side without them. Mine will scrape the ground slightly so I don't do that much.
Likes For zacster:
Likes For fietsbob:
Quoted: 106 Post(s)
Liked 8 Times
Yeah it's standard any flat pedal should work.
I have dual sided flat/SPD on my roadbike, this is great and I recommend it. I got the ones from decalthon, they kinda look like road pedals, it doesn't bring the look of my quite high end roadbike down
Quoted: 41 Post(s)
Liked 28 Times
You might look at MKS GR-9's with or without toe-clips. Not as "fred" as most platforms for road bike considerations. I used to ride clipless but now ride flats.
GCN did a video last year "Are road pedals faster than flat pedals?". There was a 30 second difference during the 3 km hill climb they did, with the clipless being faster. Though the to me the difference was attributable to 10rpm more with the clipless.
Likes For ups:
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
You don't mention which clipless standard you're using. If you're using 'road' pedals, it's possible that you're using SPD-SL cleats like these.
Three bolt SPD-SL cleats
There are a few choices for blocks that clip into the pedal and act like a platform, though I'd expect them to hurt after a while because they're still narrow. I personally find double sided pedals annoying because you need to make sure you're using the right side to clip in .
If you're using the two bolt cleats, you could purchase 'mountain' bike shoes which usually keep the cleat recessed in the sole, enhancing walkability. That's the solution I use for my commuting and touring, rather than tearing my road shoes up or using platform adapters, which tend to hang upside down when used. To sweeten the deal, a member here has some old store inventory in many sizes he's selling for around half off. That thread is here.
Quoted: 1943 Post(s)
Liked 2,164 Times
Any 9/16” threaded platform pedal will work.
Important part is they have right hand (drive side) and left hand (non-drive side) threading. You will never get the non-drive side off of you use righty-tighty-lefty-loosey.
Also grease the threads before you install them and make sure they go on straight.
John
John
Likes For 70sSanO:
Bikes: 82 Lotus Unique, 86 Lotus Legend, 88 Basso Loto, 88 Basso PR, 89 Basso PR, 96 Bianchi CDI, 2013 Deda Aegis, 2019 Basso Diamante SV
Quoted: 943 Post(s)
Liked 172 Times
Quoted: 2952 Post(s)
Liked 3,106 Times
I just got these for my CX/commuter: https://rideissi.com/pedals/issi-flip
https://pedal-plate.cc/
iv been getting on great with these. When I’m riding stop start to the gym being on flats is much more convenient. but then come the weekend or lovely summer evening ride I’m back in clipless.
sure you can ride short distances with casual shoes ontop of spd-sl pedals but it’s not ideal and will wear the pedals in an odd way. The pedal plates also act to protect in my case very expensive pedals.
Likes For Roobz:
Quoted: 4559 Post(s)
Liked 2,802 Times
I still prefer platform pedals for my hybrids and occasionally switch a road bike to platforms if I plan to do a lot of urban group rides. I don't like foot retention in stop and go traffic, especially in casual group rides with some rookies.
I've had a pair of iSSi Thumps for a year on one bike and like 'em. A little large but great ergonomically with pretty much any shoe. After a year and a couple thousand miles the right pedal feels like something needs to be tightened a bit, spindle or bearings, not sure. It uses sealed cartridge bearings. So far, so good, worth the $40. I'd already worn out a set of lightweight aluminum Wellgo platforms and Stolen Brand Thermolites (which are great for only $15 and should last a year or so, a few thousand miles).
Likes For canklecat:
I have dual sided Funn mambas. I have big feet and often wear work boots. I love them there perfect for me.
Bikes: my bikes: Old: 1965 Schwinn 10 speed, 72 Monshee 12 speed, 77 Norco 12 speed, 95 Trek 850, two Specialized Crosstrails, 2016 Specialized carbon Sirrus. New 2020 Trek FX1
Quoted: 54 Post(s)
Liked 36 Times
I have these, Shimano PD-T421 Pedal, and they're great, had them on three different bikes so far and very pleased, a big plus is they also look great!!
