which side do you have your rear brake lever ?
Bikes: Wife says I have too many :-)
Quoted: 327 Post(s)
Liked 250 Times
Some of the guys I ride with have their brake lever for the rear brakes on the right side. Some have it on the left side. Where is your rear brake lever ? Mine is on the left side, I thought this was the "standard" but maybe I have mine set up wrong. I would like to set it up to what the norm is so that if I ride someone elses bike it is the same and if someone borrows mine ditto.
Likes For tyrion:
Expired Member
Quoted: 3657 Post(s)
Liked 5,394 Times
It's normally on the right. Seems I've heard some Brits do it the other way. Also there are some folks who ride motorcycles and are afraid the difference will confuse them in a moment of panic. Interesting there is such variety in your group.
Mad bike riding scientist
Quoted: 6201 Post(s)
Liked 4,204 Times
Unless a customer specifies otherwise, the hand lever that operates the rear brake must be on the right handlebar. The lever that operates the front brake must be on the left handlebar.
Stuart Black
Stuart Black
Likes For cyccommute:
Quoted: 327 Post(s)
Liked 250 Times
Most people are going to have it on the right. The Consumer Product Safety Commission requirements are the following
Most bikes are going to be set up with the rear brake on the right side of the handlebar for the store and most people leave them that way. Some motorcycle guys will swap them but I would say that 99% of all bikes have a right/rear brake setup.
Quoted: 980 Post(s)
Liked 580 Times
I have the front brake on the right on all my bikes. Partly because I was a motorcycle rider, and partly because I wanted to have the strongest brake available if I were momentarily riding one-handed, for example when signalling. Maybe also, theoretically, if someone stole my bike they might get a little surprise! That's never happened.
As Cyccommute indicates above, this position is legal according to the CPSC if "a consumer specifies otherwise". When I bought my Airborne, the reversed lever position was an option; all my other bikes I switched myself.
Quoted: 2026 Post(s)
Liked 1,095 Times
I believe the vast majority of riders have the rear brake lever on the right side. Bikes automatically come set up that way from the shops and almost all riders leave them that way. As noted, brifters and their cabling work best that way too.
Motorcycles do indeed have their front brake lever on the right since the clutch is operated by the left hand and the rear brake by a right side foot pedal.
Quoted: 645 Post(s)
Liked 797 Times
Liked 4,204 Times
Standard setup in the UK and Ireland is front right, rear left, which makes the most sense to me as a right-hander. Since your front brake does the majority of the braking, logic would suggest that it should be operated by your dominant hand - the hand that has the most strength and control.
Stuart Black
Stuart Black
hoppipola
Bikes: fausto coppi
Quoted: 512 Post(s)
Liked 227 Times
When you ride one handed, you better use the rear brake, not the front one. That's what should decide whether the rear goes to the left or to the right... unless you have very weak muscles and you need the stronger arm to control the front brake.
I mix it Up, I have both, using both any how, its unimportant..
mostly it's Moto ..
Touring , grabbing the left rear , let me catch my breath on a super steep hill in 'the 2 foot gear' & not have the bike roll backwards.
Last Long Tour Was in a drive left country, Irish Isles, & Scotland..
mostly it's Moto ..
Non omnino gravis
Likes For DrIsotope:
Quoted: 4195 Post(s)
Liked 3,837 Times
Left is rear for a few reasons that some might not care about, on my bikes. Andy
AndrewRStewart
AndrewRStewart
Bikes: 89 Paramount OS 84 Fuji Touring Series III New! 2013 Focus Izalco Ergoride
Quoted: 285 Post(s)
Liked 74 Times
Seems like with downtube shifters, easier to brake using left hand front brake while shifting with right hand.
scott s.
scott s.
Front right, rear left. I am right handed and want the front brake to be operated by my dominant hand. Lots more control that way.
Likes For rmacdona:
Stevoo
Old moto and bike guy here. Moto is right hand front brake. All my bicycles have alwsys been right hand rear brake. Brain adjusts fine . Never an issue.
Rode a friend's mtn bike that was set up "moto style" and I struggled with it as my brain was in bicycle mode when on the bicycle . Go figure.
But, rode Japanese and old Spanish motos a lot back in the day. Foot shift and brake controls are swapped between them. Never any issues jumping between them. The brain is interesting.
Quoted: 254 Post(s)
Liked 182 Times
Explanation I have heard is that "proper" bicycle turn signalling in countries that drive on the right is done entirely with the left hand, so CPSC mandated rear braking for the hand still on the bars (ie right hand) because of a (misplaced) fear of the danger of stopping with only the front brake (the logic being that beginners have trouble modulating front brakes and stop too quickly and get thrown). In places like UK where they drive on the left, the reverse applies, and right hand is rear.
Cyclocross riders often switch the sides, depending on which side they typically dismount on for a bike-carry.
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times
Maybe if you learned on a motorcycle a long time ago.... Back brake was on the left, gear shifter on the right. Front brake on the right.
Panic stop... go to the left, Clutch, back brake.
"Imagine a bike with gear shifting on the left"... well that's what motorcycles have today.
hoppipola
Bikes: fausto coppi
Quoted: 512 Post(s)
Liked 227 Times
LR÷P=HR
Quoted: 862 Post(s)
Liked 1,195 Times
+1 Brit's are Left/Rear Right/Front
I is one, but now in California.
So I let my USA R3 keep it's USA config and just deal with it.
Barry
Barry
Liked 1,095 Times
As usual for government agencies, the CPSC ignores us left-handed riders and doesn't seem to care for our safety.
Likes For HillRider:
I have always ridden dominate hand for front brake. In my case that puts the rear on the left. I always ignore the CPSC.
1984 Cannondale ST
1985 Cannondale SR300
1980 Gary Littlejohn Cruiser
1984 Trek 760
1981 Trek 710
Pics
1984 Cannondale ST
1984 Trek 760
1981 Trek 710
Pics
Every bike I ever bought was R-R. Either way; dumb accident
I was riding through this small town on a tight road. I grabbed my water bottle with my right as per habit, just then a cat darted out in front of me, having only my left hand on the brakes, I applied too much pressure and flew over the handle bars.
Lesson learned. Grab water bottle and other things with front brake hand.
And just to make it controversial, some bloke accused me of not paying attention to the road because I should have seen the cat before it darted out from under that car.
Not lost wanderer.
Quoted: 885 Post(s)
Liked 987 Times
Right front like a motorcycle.
