Wheel circumference
Quoted: 7 Post(s)
Wheel circumference
I use an Edge 530 and a Forerunner 920xt.
I have Continental GP4000 s2 700x25c
My Edge 530 is set to auto calibration (value 2134mm).
My 920xt is manually set to 2105mm
Interestly, I always get higher distance with my 920xt, even if the circumference is set to a lower value...
Anyone could explained that?
Bikes: 1987 Pinarello Montello, 1996 Litespeed Classic, 1996 Colnago Master Light, 1997 Litespeed Ultimate, 2006 Opera Leonardo FP, 2006 Pinarello Paris FP, 1984 Pinarello Record, 89-ish Cornelo Profilo
Quoted: 148 Post(s)
Liked 119 Times
Is this indoor or outdoor riding? If outdoor, your Edge 530 should be using GPS data for distance.
Non omnino gravis
If outdoor, you should be using the calibrated speed sensor as source #1 , and the GPS as data source #2 . Because consumer GPS is decent at locating a stationary target, and pretty spotty when moving at +20mph-- as it polls once a second, and you're moving ~30 feet per second, so the GPS accuracy is +/-30 feet @ 20mph. It gets worse under trees, in canyons, next to tall buildings, etc, etc.
Get a string, wrap it around the tire, lay the string out flat and measure the string, input that number. My Edge 520 was set to auto-calibrate and shorted me ~4% mileage for 2 years.
Quoted: 7 Post(s)
About the Speed and Cadence Sensors
Cadence data from the cadence sensor is always recorded. If no speed and cadence sensors are paired with the device, GPS data is used to calculate the speed and distance.
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 266 Post(s)
Liked 447 Times
I like to get on the bike and roll at the desired tire pressure to measure circumference. Makes a slight difference. Use a metric tape measure. I tried putting line chalk on the floor and roll through it but could not get it to mark the tire. Helps in a garage so I see the string would work in doors.
example
Road Bike Aeolus R5 wheels
Rear Conti 4000 112 psi 2110mm
example
Bikes: 36" Unicycle, winter knock-around hybrid bike
Quoted: 930 Post(s)
Liked 393 Times
In terms of rotation counter computers, something that's useful is to reference known distances.
I've now got mine dialed in to the point where I can do a 48.8 mile ride and be off the official trail distance by maybe two tenths, which is really in the range of choices I made at water stops and taking a road around a downed tree.
A *good* GPS track would have 1% error, and often they're worse.
Quoted: 1324 Post(s)
Liked 927 Times
When I was using a regular bicycle computer and wanted the most accurate measurement of distance I could get, I'd get on the bike with the load I intended to carry and then roll forward whilst a friend measured the distances of three completer wheel rotations. I'd divide that by three and input that distance into the computer as the circumference. I don't know it that'd work for you.
Cheers
Cheers
Likes For Miele Man:
Advocatus Diaboli
Quoted: 4729 Post(s)
Liked 1,531 Times
Non omnino gravis
No, your ride could be +/-30ft if your activity was 3 seconds in duration. Any or all of the three polling points could be off by +/-30ft. That's why we see people get PRs/KOMs on streets they didn't even ride on-- there's just a line moving straight through buildings, because the head unit lost the satellite for a few seconds. On a mountain ride a few years ago, my Edge 520 lost the satellites, got confused, and added 22 hours to my moving time. I basically time travelled to the next day. Had to fix the time code error in FitFileTools. Ever since, it's been a speed sensor on every bike.
Quoted: 365 Post(s)
Liked 418 Times
There was a lady (this forum? Bicycling forum? other?) a few years ago who would argue that bike computers using wheel sensors were always inaccurate because the track of the front wheel is not the same as the rear wheel, and the front wheel is not always tracking in a straight line. So, in her view, the distance measured by bike computers overstated the distance actually traveled. (I wondered what she looked like on a bike, we've all seen those riders who weave back and forth with every pedal stroke - I figured this was probably her.)
I'm not all that concerned with accuracy, myself. I get that some riders really get into the data, and that's great, but for me whether a ride is 40 miles or 40.359 miles is immaterial. I generally measure rides by time anyway, since that is what matters for me (I have 2 hours to ride before I have to be somewhere, or I have the energy to ride 3.5 hours but not 4 hours today, etc.).
Quoted: 1814 Post(s)
Liked 923 Times
I know a guy who habitually rides in a serpentine line. Riding behind him on a fog line I was able to estimate that it was about 6" per pedal stroke. He rides a lot of DCs, & by measuring a piece of string laid out in that pattern I estimated that he added 2 miles to a DC (IIRC). Since I was observing the back wheel, perhaps his front wheel traveled even further.
Quoted: 6173 Post(s)
Liked 4,790 Times
This is the number on the devices and not when you view the ride activity that has been uploaded to a site or software?
While we would expect that the auto calibration number is used to correct miles that you've already ridden, I personally doubt that it does. And some devices might auto calibrate several times on a ride.
This is with the devices on the same bike and not on a trainer..... right? If on a stationary trainer, auto calibrate is not going to work and the decision process it's program uses to provide you with a number is even more a guess to us.
It'd be interesting to know what happens if you put the 530 to manual with the same setting as the 920xt. Likewise if the 920xt will auto calibrate, what's the result with both in auto calibrate?
And even so, the differences in the wheel circumference are only 1 percent.
Advocatus Diaboli
Liked 1,531 Times
Quoted: 7 Post(s)
I have putted 2105mm in my Edge 530.
I tried pedaling inside and I got exactly the same distance on both devices.
I did not tried the auto calibration on my 920xt.
Bikes: yes, i have one
Quoted: 1134 Post(s)
Liked 1,179 Times
Liked 1,179 Times
Liked 1,179 Times
Ok got it.. but don't the various sites recalculate your distance, and therefore your speed, by actually comparing your ridden route to the mapped distance it should be? Ie. isn't this why Strava relies on GPS for all of its segment times, since it feels that a speed sensor unit can be more likely incorrect (intentionally or accidentally)?
unrelated but equally interesting is this: https://support.strava.com/hc/en-us/...-Your-Activity
Bikes: Too many.
Quoted: 92 Post(s)
Liked 174 Times
Liked 4,790 Times
What is unknown in relation to the OP is whether this was on a trainer or out moving in the real world.
I wouldn't expect a mileage value for riding nowhere on a trainer.
Quoted: 7 Post(s)
